Jun 28, 2017 19:25:31 GMT
So one bonnet with the profiles completed Profiling is well advanced on the offside front wing, A post & offside bulkhead And a start made on the offside door
Last Edit: Jun 28, 2017 19:27:00 GMT by Deleted
Ether
Jun 28, 2017 22:01:30 GMT
Smashing stuff.
Jun 29, 2017 20:53:15 GMT
Wing profiling completed A post & bulkhead very close to completion Offside door also well on it's way and will get completed in the morning So with all the outer panels just about completed the wings could start to be removed to allow the flange edges to be finished and the undersides to be prepped, treated & painted I will make up some hinge location templates for the doors in the morning prior to removing them to allow access to the door & sill apertures so that they can be prepped
Last Edit: Jun 30, 2017 21:10:00 GMT by Deleted
Jun 30, 2017 20:44:39 GMT
Last Edit: Jun 30, 2017 21:12:04 GMT by Deleted
vulgalour
Club RR Member Number: 146
Jun 30, 2017 21:14:12 GMT
Those hinge location templates are a really good idea!
Jun 30, 2017 21:39:09 GMT
Those hinge location templates are a really good idea! For 5 minutes effort and a throw away cereal box they save no end of heartache when it comes to reassembling a freshly painted car - main thing being you can confidently hang hinged panels and get them to the point that may require very minor adjustment - but at least you are hanging the door and not fearing damaged paint has you attempt to close it - especially on something like this that has a very close tolerance on the door gaps.
Lots happening in preparation of primer coats - Offside wing now off both prepped and masked up, seam sealer & stone chip protection applied to the undersides Bonnet removed - prepped and seam sealer applied to seam edges as required Which means I can also start to prep the bulkhead area now I have the access Prep work continues on the nearside door apertures now that the door is removed and allows access
Last Edit: Jul 3, 2017 20:40:14 GMT by Deleted
Loads more loose ends tied up Approx 20 redundant holes drilled in the bulkhead were welded up & dressed back The new aperture for the hinge box on the nearside required alteration - requiring a plate to lower edge and the elongated bolt holes closing up a little The slot is a drain - otherwise the hinge boxes fill with water on occasions if the car is used in driving rain Then just a skim of filler where required - once the car is fitted back up the bulkhead is barely visible The bulkhead side return panels get hit by all the debris thrown up by the road wheels so I applied a stone chip coating to these The bonnet / wing end flanges would also get peppered by the road wheel debris so these also got the stone chip coating applied The profiles to the offside A post & door are now completed Made up the hinge location templates prior to removing the door to allow access to prep the apertures Meanwhile the aperture on the nearside is now completed The last of the panels were removed namely the offside rear wing And the spare wheel flap Which leaves me to delouse the cockpit and sort any prep work for primer Along with sorting a few loose bits - windscreen frame and dashboard closing panel along with the two door capping's Meanwhile my quality control inspector 'Sid' paid his weekly visit - thankfully he was fine with everything but clearly indicated that I need to start getting some paint on the car
Last stint of prep work Old door lock aperture required welding up / dressing back on both the aperture & door And that is the final piece of welding on the car completed Offside door aperture was then prepped ready for primer & the rivet nuts to retain the floor drilled & fitted to the sill Door frame apertures now completed Windscreen frame prepped Bulkhead to windscreen closing panel and the two door capping's were bare metaled - they just need a rub over where minor defects have been skimmed Removed all loose parts out of the cockpit and had a major clean up / blow off of any lose dust So 12 weeks in of fabrication / welding / panel fitting & panel profiling It's ready for the first coats of primer (with exception of some masking up first) Plus I managed to get a colour swatch painted up in order to confirm the paint order - it's a very fine metallic (probably not visible in this pic) created through the use of silver tinters rather than pearlescent tinters that would be used in a modern vehicle finish More tomorrow
Last Edit: Jul 5, 2017 22:03:07 GMT by Deleted
vulgalour
Woo! No more welding! That swatch almost looks like flat paint rather than metallic... almost. Very subtle effect.
Woo! No more welding! That swatch almost looks like flat paint rather than metallic... almost. Very subtle effect. Metallic finishes were in their infancy when this car first came to the market - whilst the car carries several modifications - to put a modern colour on it that has a bright sparkly pearlescent metallic finish to it would make it look like a 'circus wagon' - it should look great with the fine subtle metallic finish on it that I planned and let the rest of the cars style do the talking
Last Edit: Jul 5, 2017 21:39:14 GMT by Deleted
eurogranada
Wow, has it really been twelve weeks? Life is really moving fast these days because it doesn't feel like much over a month!! Your steady (and in my book quick) progress must have thrown me off. Especially considering this is both fabrication and welding works as well as the body work of which it is fair to say that you have taken every care to work out as much damage in the metal itself so all fillers etc. are nothing more then skims!
I'm just wondering here, but will you be building the car after paint as well? Or is this, apart from paint, the last we're going to see of it?
Any new projects waiting in line? I just love to follow your work...
Last Edit: Jul 6, 2017 22:10:43 GMT by Deleted
Wow, has it really been twelve weeks? Life is really moving fast these days because it doesn't feel like much over a month!! Your steady (and in my book quick) progress must have thrown me off. Especially considering this is both fabrication and welding works as well as the body work of which it is fair to say that you have taken every care to work out as much damage in the metal itself so all fillers etc. are nothing more then skims! I'm just wondering here, but will you be building the car after paint as well? Or is this, apart from paint, the last we're going to see of it? Any new projects waiting in line? I just love to follow your work... Alex - Once painted I will fit the panels to the car and undertake the rustproofing - then it is going back to the owner and he will complete the fit up and refit the rebuilt engine - The owner is a very good friend of mine so I will post pictures of it to the thread once the car is complete and returned to the road There is quite a list of projects due into the workshop over the next 6 - 8 months- in fact I am so busy that I am going to have to sell a couple of my own projects has I will never get the chance to get them done whilst I am this busy! 1947 Jowett Bradford Utility - Full rolling body restoration & paint / some trim - Thread already running retrorides.proboards.com/thread/196036/1947-jowett-bradford-utility-vanFord Corsair - Panels, fabrication, welding & full bare metal paint job (RR car) 1929 Jowett Long 2 Tourer - Rebuilt chassis & new body - In for concours paint job (has already been in another bodyshop who has made a mess of it - it is coming to me to be sorted out properly) 1968 Mk1 Mini Copper - Body shell - New floor pans, inner & outer front wings, fabrication, welding & bare metal paint job 1974 Alfa Romeo 2000 GTV - Full bare metal paint job, welding , fabrication, panel work etc - provisional booking at present
Last Edit: Jul 6, 2017 22:08:56 GMT by Deleted
vulgalour
That last shot especially highlights why all that prep work was done. This is going to look unbelievably good in shiny paint.
It make me think of a grown up Frogeye Sprite.
Great work.
It make me think of a grown up Frogeye Sprite. Great work. Thanks - Or maybe a two thirds scale Jaguar XK ?
Last Edit: Jul 7, 2017 22:01:08 GMT by Deleted
How much longer do you estimate the concours car to take compared to this one?
How much longer do you estimate the concours car to take compared to this one? I take it that you are referring to the 1929 Jowett Long 2 Tourer that is en route to me - Well no where near has long has the Jupiter restoration has taken me - It's a fully restored chassis with a new ash frame / alloy skinned body on it - I have yet to see the car in the flesh however - its a matter of rectifying someone's poor quality paintwork - I am aware of a couple of deviations in the lid of the dicky seat (boot lid) and the bonnet I already have with me and ready for primer - so it's matter of flatting back, priming, paint & polish - so pretty straight forward in my book and should not be exhaustive in time / hours spent The Jupiter has been a very different bag with custom fabrication & repair, welding, profiling, paint etc - it takes far longer to profile a multiple & complex curvature bodyshell such has the Jupiter than it does a straight sided box saloon due to the fact that the vast majority of the work has to be undertaken by hand rather than by machine - panels that are flatish in profile can just have a powered flat bed sander do the lump of the work and then just be finished off by hand
Last Edit: Jul 8, 2017 11:39:23 GMT by Deleted
