Nov 13, 2019 21:19:16 GMT
Lovely results, Peter! Great skills... Cheers! Peter you should run a separate thread for the steering wheels? Very nice work. Thanks Pete. Good idea to make a seperate thread
O.M.G! That Citroen one is freaking awesome!!!!! Thanks Marc. A sad thing is that the owner will never be able to enjoy it. He passed away 10 days ago at the age of 56. I travelled to Belgian 2,5 weeks ago to fit the Daimler steering wheel, have a look at the Daimler dash and remove the Citroen steering wheel. It was a very friendly person and we had a good time chatting about classic cars and other things. It was very unreeel to find out he passed away so shortly after we met and at such an age. Thanks Strikey. Doing some amazing work with these steering wheels! The attention to detail is fantastic Thanks! Peter
Nov 14, 2019 11:19:42 GMT
O.M.G! That Citroen one is freaking awesome!!!!! Absolutely! Sad news about the owner though.
Nov 14, 2019 13:49:18 GMT
that is so sad.... make the most of everyday... one day it will be your last!
Nov 14, 2019 23:49:54 GMT
There was a mk2 Escort that came up for auction in Chesterfield the other year. South African import but had been gone through nut and bolt. The owner had bought it and had it all done up only to promptly die before he'd had the chance to relive his youth. Very sad indeed.
Jan 19, 2020 18:54:06 GMT
Is the rover all finished? Any picture and an update please.
Jan 19, 2020 19:37:20 GMT
got all excited then...thought i had missed an update. :-(
Jan 21, 2020 18:07:17 GMT
got all excited then...thought i had missed an update. :-( Not wishing to hijack this thread but this is on UTUBE and worth a look at a nice p5b Coupe
Jan 21, 2020 21:27:12 GMT
Not much work done on the Rover as i am very busy with the steering wheels and dashboards. Its almost ready. The coach lines are not done but i am considering to not do them as i do not like them. This weekend i removed a fair bit of dust from the car and wanted to get it running as in 2 weeks i need my workshop for some spray painting and therefore i do not want the Rover to be there. The first attempt to get it running failed and then i realised the Facet fuel pump kept on ticking which means the tank is empty. After filling it up with a can of petrol, it started instantly and it was good to hear it runnning again as its runs so smooth and sounds great After that i smelled petrol and there was a small leak of the fuel filter. As the Rovers have a reserve it is pretty crowded there The leakage was soon solved. There is another job i am considering and that is to reduce the height of the transmission sump. I replaced the original 3 speed BW35 box by a 4 speed 4ZF HP22 and to this BL van box a Range Rover sump is fitted which makes it easy to fit the dipstick and it automatically gives the correct fluid level (the box is a bit rotated on the RR) but it is a bit deeper and the sump plug is now the lowest point on the car which does not feel good in relation to the speed bumps which we have a lot in Holland. My daily Rover P5B also has this ZF box but this has a Jaguar sump and it took a fair bit of work to convert the dipstick and i am not 100% sure the level is oke as on a Jaguar, the box is not rotated.
Peter
Jan 22, 2020 18:07:17 GMT
got all excited then...thought i had missed an update. :-( Not wishing to hijack this thread but this is on UTUBE and worth a look at a nice p5b Coupe Hi Steve. I believe that car on Youtube is your old car as i remember the special mirrors, the rear seatbelts, the trim on the rear wing . Was it that nice when youu sold it or did the new owner put a lot of work in it? Peter
Mar 15, 2020 22:32:46 GMT
There a new addition to the family fleet. Not retro as it is a Tesla model 3. It is my wifes compagny car It drives oke but it simply is not my kind of car because there are no V8 sound but it has tax advantages. Last weekend we attended a weight lifting contest of my son 190 km from home and as some friends of my son were joining us, we drove with both the Tesla and the P5B to the event. The Tesla had to be charged when we arrived as there was not enough battery capacity for the return trip so we had to bring the Tesla to a charging point some 5 km away from the event and the good old Rover was needed to bring my wife from the charging point to the event and later to pick the car up again. The daily Rover is clocking up the km without much trouble. I only needed to replace the horn as it was not working anymore. In the spring some work is required on the sunroof. It is not leaking yet but soon will, especially as the spring and summer sun will attack it It still amases me how reliabel this almost 50 year old car is in daily use and living outside. Also did some work on the project Rover. It had to be removed from the workshop as i needed to spray some wooden panels and steering wheel. When i drove it outside, it became clear that the brakes did not work although the pedal was very hard. After spraying, i had to drive the car back into the workshop, with some poor adjusted carbs (high revs) and only the hand brake which lead to some scary moments. Underneath a picture of my 2 P5Bs The project rover sat lower then the daily P5. These Rovers have torsional front springs with an adjusting mechanism. I like the look of the lower car but grond clearance is not enough so i set it as high as my daily rover After having the car in the workshop, i had a look at the brake booster. This was new so should not cause problems. Soon it showed, i had made a stupid mistake by interchanging the brake lines. After correcting this and bleeding the system, the brakes worked fine again Next step was to adjust the carbs as i could not get the revs down enough and it is not good to put the car in drive with 1500 revolutions Took some time to figure out what was wrong. I had rebuild the SU some time ago and all linkages were correctly adjusted so i removed the carbs from the manifold and opened them up again and after some investigation, i found out that i had forgotten to fit the jet bearing washers (pos 16) After fitting these, the car refused to start. There was a spark, so i thought the carbs caused problems. After some time and a lot of thinking, i had a look at the spark plugs which were sooted badly. After cleaning these, the car started instantly and i was able to lower the revs. The forgotten washers clearly gave a very rich mixture Also found a supplier of small stainless self tapping screws as a few were missing on the stainless trim. These were packed in boxes of 200 but only costed 4 or 5 euro per size All the trim is now fitted with the correct size of self tapping screws There still is a list of to do things which i will work on the coming weeks Peter
Mar 15, 2020 22:46:45 GMT
Seems only fitting that you'd replace the horn in the daily with one of your own creations. Perhaps something along these lines?
Mar 22, 2020 10:44:41 GMT
Seems only fitting that you'd replace the horn in the daily with one of your own creations. Perhaps something along these lines? Looking good but a bit overdone Did some small job from the "to do" list. When i drove the car out of the workshop, i noticed a scratching noise from the front wheel. Had a look underneath and saw that the steering ball joints lightly touched the rims on both sides and touched the balancing weight which were chiopped off. This was partly caused by fitting Jensen Interceptor alloys but these were also fitted to my daily Rover P5 without problems. I soon noticed that there are 2 ball joints diameters and i had fitted the larger one to my project P5B. Had a look into my assortiment of spare ball joints. and found one with a smaller diameter. All the ball joints on these Rovers are kind of bulletproof. When i bought my spares car, i also was offered a spare subframe with front suspension which had been in a field for several years and was covered in weeds. As there was room in the van, i took it. After coming home, i dismantled it to find all ball joints and wheel bearings in good condition. All the others had the larger diameters. There are 4 fitted to a Rover P5 and luckily my daily Rover had 3 with a smaller diameter so i could swap one of those. After replacing both grease nipples by a bolt, cleaned both with a rotating wire brush and gave these a coat of 2K primer with a brush After a coat of 2 K black paint, both ball joints were fitted and the wheel balancing weights which i found on the drive, were glued to the wheels . Also roughly adjusted the mixture screws on the LPG system so that the car now starts and runs on LPG
As the daily Rover is not used much due to the Covid situation, it is a good moment for some bigger jobs. The first one is to replace the Webasto roof material. I have not opened the roof for a long time as the vinyl had become a bit brittle. It did not leak but would soon do as there were some small cracks on both sides. When the vinyl was removed, it became clear that the steel frame of the foldable roof was not painted very well so there was a fair bit of rust Especially on the inside frame This rust was also visible on the inside of the headlining so i will also replace the headlining. As it was a kind of PVC coated cloth not all rust was visible from the inside of the car. As i needed to thread the rusted frame and brackets, i decided to remove the seats and carpets and started removing pieces of foam Also saw that the pop rivets where the brackets were connected to the body (near the rear window) were also broken. Removed the remains and fitted new pop rivets Then the rusted frame and brackets were attacked with a rotating wire brush, flap disk and finger sander and given 2 coats of Hydrate 80. The hydrate 80 is not common in Holland but luckily Amazon which recently came to Holland could supply it quickly All the brackets of the foldable part of the roof also showed a fair amount of rust All rust and paint was removed and given 2 coats of hydrate 80. Thats it for now Peter
Last Edit: Apr 1, 2020 21:17:08 GMT by petervdv
Peter, it's interesting to see the Webasto removed and in pieces. The bracket shown above, pop-riveted in place: is that original from Rover, or installed with the sunroof? Thanks, John
820
One of those horrible jobs you know you have to do but also know it will lead to a lot more work
Peter, it's interesting to see the Webasto removed and in pieces. The bracket shown above, pop-riveted in place: is that original from Rover, or installed with the sunroof? Thanks, John All the pop riveted brackets come with the Webasto roof. None of these are standard Rover. It looks slightly overengineered as most of these are 2mm thick
One of those horrible jobs you know you have to do but also know it will lead to a lot more work That is very true! Did not really look forward doing this but if the roof starts to leak, it will damage the interior. Also the reason why i want to do this myself. If you let an upholstery compagny do this it will look nice but either, the metal work is not done properly (and you get rust marks in a few years) or you will get a huge invoice if all the metal gets a proper treatment
Did some more work on the daily Rover. The rust on the loose parts was removed, threated with Hydrate 80, a coat of primer and a coat of black paint. The front of the sliding part has a wooden bar which houses the open and closure mechanism which was in a pretty poor condition as a lot of the layers were loose and the outer top parts were very bad as very rusted bracket had damaged the wood so i renewed some pieces All the loose pieces were glued together in a few sessions All the screws were very rusty and had damaged the wood and was not a good base for new screws. All the holes were drilled to a larger size and wooden dowels were fitted Gave the finished bracket a coat of epoxy In the meantime, the headlining material arrived from the UK. A friendly P5B owner which happens to be a professional car trimmer supplied me the original material and gave some usefull advices although he believed it was a job for a professional and also mentioned it was a 2 men job. So with a bit of i started alone as due to the Covid situation, i could not ask a friend for help. The Rover has a frame for the headlining but because of the sunroof, the connecting bars have been removed and this leaves a fragile frame The friendly trimmer advised to fit the frame to car and in the car fit the headlining. It is not posible to fit it in the original position because there is no room to glue the headlining to the frame so i lowered it a bit by using longer self tapping screws Then fitted the headlining with clips to the frame to get an idea Then pulled it all straight and glued it to the frame Pretty happy with the result. The front corners are not perfect so will see if i can adjust it a bit Then marked the cut out for the sliding part from the outside Glued the parts to the roof but have no picture of that. It is a time consuming job but pretty happy with the result so far Peter
Last Edit: Apr 9, 2020 20:39:51 GMT by petervdv
Peter - Never met you but I know through your threads that you are both diligent & practical - From what I see nothing much phases you either - Personally I have to say that I always take the challenge on 'You will never do it on your own - you can only do it with 2 of you' and just get on with it by myself - whilst it may take me longer I've never been beaten yet - hope all goes well with it
I imagine if you're cutting a gaping hole in the middle of the fabric, you'll have plenty of room to adjust the fit of the fabric!
Good on you for going it alone.
