joeytalent
ITB Everything.
Those look really comfortable and the corduroy inserts should look at home, puts me in mind of Mk3 Honda Prelude interiors, which are one of the most comfortable places I've spent time as a passenger. This is probably the most comfortable car seat I've sat in apart from Volvo ones, which don't stand a chance of fitting (and wouldn't look right anyway). I wish Cobra had the same selection over here as the UK, as I would've probably got a different finish, but the cord does look nicely 70s and matches the carpet colour.
joeytalent
ITB Everything.
Feb 16, 2018 14:24:12 GMT
Happy Valentines Day to me. Should ship from Japan towards the end of March.
joeytalent
ITB Everything.
Feb 19, 2018 18:26:37 GMT
Power steering pump exploded doing 70 in the Jeep. The pulley decided it didn't want to be part of it any more - looks like the bearing in the pump seized. Took it to a garage to get fixed, beginning to hate the Jeep.
joeytalent
ITB Everything.
Feb 20, 2018 21:00:23 GMT
Found 5 minutes to drop the seat in. I'll try and get some time to put all the bolts in this week.
joeytalent
ITB Everything.
Feb 25, 2018 16:23:07 GMT
New ECUI have long terms plans for keeping this car, so maintenance, cost and availability of parts is always a concern. Thankfully, there's a solution - enter the FAST EFI kit. This replaces all the sensors in the engine bay with newer, cheaper, and readily available (as in walk in to Autozone and buy a replacement that day) GM parts. The rest of this post isn't going to be very interesting, as it's more for my reference later on if I need to buy anything. The nice thing about this kit is it comes with all adapters you need to hook straight up to the L28 engine, which is a huge convenience. First up, coolant sensor and thread adapter: TPS sensor, adapter and wiring loom adapter: MAP Sensor: Idle valve and K&N filter: And a couple of elbow joints with barbs for routing this to a vacuum point: Air intake temperature sensor: The MAF is deleted - there's a nice aluminium pipe for that: A load of vacuum points will also be blocked off, as all the cold start stuff comes off as well: Fully labelled loom (yes, all the sensor wiring is also replaced throughout the car): Wiring for the touchscreen: RPM Converter: Spare wiring conduit to tidy everything up - I really appreciate small touches like this: O2 sensor - if anyone knows the part number for this, I'd appreciate it! The ECU and touchscreen display: And finally, the first thing I can actually tackle... the O2 bung: Next up will be removing the exhaust manifold to have the O2 sensor bung welded in.
joeytalent
ITB Everything.
Mar 10, 2018 10:43:14 GMT
Did a purchase. Arrived 10 minutes before I had to leave for Munich for a fortnight with work. Instructions are very thorough I think... At least there are pictures.
vulgalour
Club RR Member Number: 146
Mar 10, 2018 21:05:09 GMT
That looks good enough to hang on the wall, almost a shame to hide it by fitting it to the car.
joeytalent
ITB Everything.
That looks good enough to hang on the wall, almost a shame to hide it by fitting it to the car. I know! Once they're all fitted, I'll try and get some nice B&W shots to have printed at least.
joeytalent
ITB Everything.
Mar 23, 2018 14:05:41 GMT
I went to the storage unit yesterday - car hasn't been started for probably 4 - 6 weeks (and it's been cold as eff). After digging a ton of snow and ice away from the door, I had to jump the battery and the car warmed up absolutely fine... however...
There was a small amount of steam coming from somewhere near the thermostat housing. There's also a small puddle of coolant under the radiator. I'm hoping that it's just the cold cracking the hose a little, as the radiator is pretty new (and the hoses are not!). So, replacement hoses, clamps and a thermostat gasket ordered.
I was being super lazy about not wanting to take the inlet manifold off to get to the exhaust manifold, so I didn't have to drain all the coolant - looks like the car has decided that for me.
On a side note - is there anyone here that could possibly aid in translating some Japanese instructions?
vulgalour
Mar 26, 2018 16:48:41 GMT
I bet if you post in the General Board someone can. Fingers crossed the new hoses and clips sort the steam out.
Mar 28, 2018 19:42:20 GMT
From what I can read, its just marketing hype, especially in the second section.
Talks about improved response and power, and the 34, 38 are the carbs (if you hadn't figured that out already)
joeytalent
ITB Everything.
Mar 28, 2018 19:49:30 GMT
From what I can read, its just marketing hype, especially in the second section. Talks about improved response and power, and the 34, 38 are the carbs (if you hadn't figured that out already) Thanks! - that's what I figured for that page. I created another thread here that I have more specific questions in. The Google docs OCR has got me most of the way, but there's some handwritten notes I'm stumped on. I'd really appreciate it if there's anything you can add there!
joeytalent
ITB Everything.
We just had another 8" snow and another week of hitting below -10°C, but I'm hoping to get to the storage unit tonight to do a bit more. At least shoveling warms you up! I believe I now have everything required for fitting the ITBs. The last part was figuring out the fuelling - I could just try and reuse the stock fuel pressure regulator, but it isn't adjustable, and if I need more fuel pressure, I'd have to upgrade anyway... so I've got an Aeromotive 30 - 70 PSI unit which will accept my fuel pressure gauge. Another issue is getting rid of the charcoal canister - I did this on my NA MX5 without thinking, but in the 280Z it's a bit more of a contentious subject. The fuel tank has a vent that runs under the car, into the charcoal canister (bottom right of this image): This is quite important for relieving pressure from the tank, especially on long drives. The vapour travels through the line from the tank, and is captured in the charcoal canister. On top of the canister, is a pressure operated valve that takes a vacuum line from the inlet manifold, and another hose that vents the vapour into the throttle body. When the car is running, the valve opens, and the vapour is burned by the normal engine operation. Wonderful. However, converting to ITBs, there's no logical place for this to go. The car absolutely stinks of fuel after a long run anyway, so I'm fairly sure something in the system leaks. So I've ordered one of these: A remote fuel tank vent, with a roll over valve. It needs to be mounted the same height or higher than the fuel filler, so I'll start looking for a suitable spot next time I'm under the car. I also picked up a new tool chest for $99 on clearance, which is going to hopefully tidy up my working area a lot (lol jokes, I'm just going to fill it with more tools).
joeytalent
ITB Everything.
280Z ITBs - PartsI hadn't really planned on doing this for the 280Z, it was more of just a long term dream. But then the exchange rate was good, so I pulled the trigger on some ITBs from Japan: The kit came with everything you could possibly need - including this nifty vacuum block: The quality of the ITBs is excellent, I can't wait to get these on the car. One key component that's not included is the fuel injectors. I picked up some second hand RX8 injectors, which should give me plenty of fuel flow: I had the injectors cleaned and flow tested, all six of them getting a clean bill of health with matching flow rates. It's still regularly snowing in Minneapolis, so anything I can do indoors is welcomed right now. With that in mind, I spent a pleasant Sunday morning fitting up the fuel rail and injectors. Next up was changing the TPS connector over for a plug that matches the rear of the wiring loom: Bottom is the TPS adapter for the GM unit I won't be using, top is the ITB TPS. Finally, I looked at figuring out the fueling situation. The FPR on the car right now isn't going to cut it, as it's hard to relocate (plus it's ancient). So I've picked up a Aeromotive unit that will give me 30 - 70 PSI: Fitted up the fuel fixtures using Permatex No. 3: And the plan for the fuel system looks like this:
vulgalour
Slightly off topic, but what camera are you using for these pictures? They look really good. I'm in need of a new one as the 8 year old one I've been using has started to literally fall apart now.
joeytalent
ITB Everything.
Slightly off topic, but what camera are you using for these pictures? They look really good. I'm in need of a new one as the 8 year old one I've been using has started to literally fall apart now. Thanks - I have an Olympus OMD EM1 MK1. I bought into the micro 4/3rds format over ten years ago, and have a selection of lenses that I've gathered whilst getting more and more into landscape photography. I actually dropped and broke my Olympus OMD EM5 last year and was gutted, but found a EM1 second hand as a replacement and have been very impressed by it.
vulgalour
That's probably more camera than I really need, but I'll add it to the list anyway, just in case one pops up since I can see it's a good bit of kit.
joeytalent
ITB Everything.
Apr 15, 2018 22:25:18 GMT
Hope you're all enjoying spring - we're in the middle of a two day storm that's dumped at least 12" snow on already icy roads. Even for Minnesota, this is unusual for April. Beginning to get a little stir crazy! Good news on the garage front - my buddy that lent me his space when I first bought the car has just had an offer accepted on a new (epic) house. I'll post some pictures once he's moved in, but the key feature of interest here is that is has two double garages - one built in to the house, and one separate. After some complex negotiations involving beer, plans and far too much generosity, I'll be renting the separate double as soon as he gets the keys. Moving from a unheated, no power storage unit to a heated, and hooked up garage that's twice the size is going to be awesome. Hopefully I'll even be able to drive the 280Z there instead of having it towed...
vulgalour
Apr 15, 2018 23:37:45 GMT
Just steal some trays from McDonalds and sled there! Geez, there's no need for that much snow in April, not even in Minnesota.
Apr 21, 2018 22:41:19 GMT
It’s been a weird spring, we had an inch of snow on weds and thurs mornings but it got into the 50s during the day so it just made a mess. Good news on the garage, lock ups stink for long term tinkering.
