shoey
Oct 10, 2016 16:52:22 GMT
Fitted both bumpers to check fit,not sure whether to rechrome or not,not to bad for 45 year old chrome fell really lucky with both front wings,because of poor image on ebay they looked rotten,got them for starting price of £50,had to go to Lake district to collect though. they have never been weld on only bolted so done same on Toledo
Oct 10, 2016 17:30:39 GMT
Does this engine turn anti-clockwise, if so how have you overcome that, just flipped the diff over?
shoey
Oct 10, 2016 17:46:33 GMT
Does this engine turn anti-clockwise, if so how have you overcome that, just flipped the diff over? Hi no it rotates clockwise no what you mean though,think some other fwd hondas are anti- clockwise
shoey
Oct 10, 2016 17:49:33 GMT
Flipped blower linkage round 90 deg to give better cable run
Bookmarked, I used to have a toledo 1300. Are you a member of the Facebook group? "Toledo Triumphs"
danb93
Very nice. I will be watching with interest. I have seen an F20 2 door Toledo before, there's at least 1 other. I've just finished this: Oh and if you're not using one already, you will need a Sprint axle to take the power.
Last Edit: Oct 12, 2016 7:01:27 GMT by danb93
shoey
Oct 12, 2016 14:31:31 GMT
Bookmarked, I used to have a toledo 1300. Are you a member of the Facebook group? "Toledo Triumphs" No but will check out though,didn't realise there was that much interest in them.
shoey
Oct 12, 2016 14:36:33 GMT
Very nice. I will be watching with interest. I have seen an F20 2 door Toledo before, there's at least 1 other. I've just finished this: Oh and if you're not using one already, you will need a Sprint axle to take the power. wasn't this one?
shoey
Oct 12, 2016 14:45:48 GMT
danb93
Oct 12, 2016 15:08:08 GMT
Ah yes that's the one I remember seeing on eBay! Mine has a CA18DET around 230hp on a stage 1 setup.
Oct 12, 2016 16:03:49 GMT
nice ! 20XE on carbs and what looks like MBE ignition ?
shoey
Oct 12, 2016 16:30:07 GMT
Ah yes that's the one I remember seeing on eBay! Mine has a CA18DET around 230hp on a stage 1 setup. Try getting that out of a sprint engine reliably ,what have you done with your brakes?
shoey
Oct 12, 2016 16:34:19 GMT
nice ! 20XE on carbs and what looks like MBE ignition ? Yes MBE,so easy to wire up even I could do it,Manta 1800 g/box and sump,had to cut and shut it though to fit sprint subframe.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Oct 12, 2016 16:38:28 GMT
Well, this is looking excellent!
Carry on.
shoey
Oct 12, 2016 16:48:04 GMT
had a go plumbing fuel line,started off with this that came with tank bent to shape made simple bracket might of been better brazing to look neater drilled boot floor awaiting fuel pipe off ebay
danb93
Oct 12, 2016 17:08:09 GMT
Regarding brakes I am using 4 pot Austin calipers and Corolla AE86 discs made to fit for the front. The Sprint rear drums are plenty big enough.
For my fuel return I routed it through the car and welded a union onto the filler neck.
shoey
Oct 12, 2016 17:31:10 GMT
Regarding brakes I am using 4 pot Austin calipers and Corolla AE86 discs made to fit for the front. The Sprint rear drums are plenty big enough. For my fuel return I routed it through the car and welded a union onto the filler neck. Heard of people using them on Triumphs before,definitely have to change wheels to fit though,did that filler neck trick on last car but this later engine hasn't got return for some reason.
triumph toledo s2000fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Oct 12, 2016 23:54:02 GMT
In this for updates...
One of my favourite cars was a custom Toledo roadster that was in triumph world mag in the late 90s.
Wish I hadn't sold my mags when I discovered eBay!
Oct 13, 2016 18:55:10 GMT
home made bulkhead fitting is a neat idea! (banked)
Tarka
Oct 13, 2016 21:56:54 GMT
Wow - I love this. Toledos look fantastic - especially 2drs and this one will go nicely too! Looking forward to watching this.
Sharks in the garage.🐬🇩🇪 I'll finish my projects when you've finished your's!😎😜
