May 26, 2024 21:31:47 GMT
Time to do a trial fit of the door gubbins then. I decided to start with the passenger door as this was the one that was on the workmate. the first issue I encountered was with the plate that holds the winder mechanism and the interior door handle. For those of you that haven't been with me since day one, I should explain that each of these steel plates had rotted excessively at the bottom. I had cut the rotten bits off and replaced them with new steel. Unfortunately I'd used one side as a template for the other. I know that the driver's side fits. However, the passenger side was WAY out. So much so, that I flattened it out, and cut a strip off the bottom, before re-bending it to fit correctly. Once I knew that it fitted properly, I drilled holes in the bottom flange to match where the holes on the door shells are. Originally these were riveted on. I shall probably re-rivet them as I am not keen on using screws, but for the sake of this mock-up, I did chuck some screws in. Next on the list was the window winder mechanism. I ended up wasting a significant amount of time with this. Why? Bolts. The Ford Fiesta winder bolts to the Midas-specific plates with short M6 bolts. I have saved these somewhere. That somewhere, like many archaeological missions, has been lost to time, and 2 garages, as well as a house move. They're doubtless stored safely in a small box or bag in a safe place. Which is nowhere I can remember. I also don't have many M6 bolts. I have found about 5, just one of which was the right length, so I spent some time shortening 3 of them in order to bolt everything together properly. By the time I had done this, it was pretty straightforward to line everything up and attach the cradle which holds the glass. This included the interior door release handle, which clips in the slot on the door plate. I say it clips in - it's a struggle to get it in there... 2 final things that I did. Firstly I draped the door card over the top, which looked good. I will have to find some spacers for the winder handle (or maybe make some?) but everything seems to go together nicely. I also had a look at the door frame. It was painfully obvious to me from this point that the frame MUST go in first - with the glass installed - everything else will then fit around it. It's a bit of a pain, and likely to need those 12 hands I mentioned previously, but it has to be done a specific way. At least this was a trial run - I would have been super-annoyed drilling out 20 -odd rivets! Additionally, I only had one of the surrounds for the door release handle, and that was broken. Luckily, it had a part number on the back of it. Turns out it's Mk2 Escort. I had a look on Ebay - yup, Ford tax. So I've ordered a couple as I can't get them anywhere else. Ah well... Door plate finally in place after some surgery. It has since been repainted. ![](https://i.imgur.com/yqFPMtQ.jpeg) I chopped this bit off the bottom then re-bent everything to make it fit properly. ![](https://i.imgur.com/821uUS2.jpeg) Winder mechanism in place. ![](https://i.imgur.com/lQL4R5r.jpeg) Much modified bolts in place - these caused me issues thanks to my poor memory. New ones are on order. ![](https://i.imgur.com/TADk4F2.jpeg) Door release handle finally in place. This is a proper backside to fit. ![](https://i.imgur.com/sC8pd3c.jpeg) Cradle to hold the glass. ![](https://i.imgur.com/JGwS5pi.jpeg) Door card draped in place. Liking the look of this. ![](https://i.imgur.com/hCC46WH.jpeg) Door frame - needs to go in first. Hmmm. Still, at least this is only a mock-up. ![](https://i.imgur.com/SMqRBao.jpeg) And finally, the broken surround for the release handle (no clips). This is an old Ford part, so it's expensive to replace. It's also Mk2 Escort. So it's now more money. I dislike Ford tax. ![](https://i.imgur.com/XDISdR8.jpeg)
May 31, 2024 13:12:09 GMT
Don't you just love it when you order something and the wrong item turns up in its place? Apparently, this is a pair of Mk2 Ford Escort interior door handle surrounds. Nope. I'm pretty sure it isn't... I've contacted the seller and they were very apologetic and confirmed they're re-sending the correct items. Still irritating though.
The garage was in an absolute state, so I have spent some considerable time cleaning it up. Once clean, I then proceeded to make some more mess. I have no spacers for the window winders. Being Mk1 Fiesta items, there will be Ford tax. I had a look around the garage to see if there was anything I could use. I have cut two rings from a pipe I had lying around (a bit of RC40, possibly), which I may modify. It's also possible I may just use them as a template to make a fibreglass buck. I am undecided at present, but as always, I'll figure something out. The replacement bolts for the winder mechanism turned up - some lovely short stainless M6 Bolts. They're all fitted. Murphy's Law dictated I immediately found the old ones, in a pot marked "winder bolts". On the shelf where I was convinced I had already looked. Ah well. The stainless ones look nice. And will be in a place where they cannot be seen. Awesome. I also gave the door lock knobs a quick rub down and a coat of black as they were dirty and covered in overspray. They now look rather swish. Potential winder spacers. Or the start of potential winder spacers, anyway. ![](https://i.imgur.com/NB00HTU.jpeg) Shiny new bolts! ![](https://i.imgur.com/hEgCeBr.jpeg) Old bolts located, just after the new ones arrived. Now, what was I thinking about? Oh yeah, that's right. Yeehaw. ![](https://i.imgur.com/vhwGgvG.jpeg) Swish knobs. ![](https://i.imgur.com/UxDxw5g.jpeg)
Jun 13, 2024 16:32:47 GMT
More door stuff, then. I had an idea in my head of the order which everything needs to be done in when putting these doors back together, but thanks to my brain telling me not to rush things, there were a couple of bits I remembered that needed to be done first. Which, for some reason, took WAY longer than necessary... Number 1? The waist seal. Luckily, I did have new ones in my big bag full of new seals, and, as per the original one, these were to be riveted on. I did consider using sealant, but the seal had been left wound up so keeping it in place would have been awkward. Plus I got to use my new riveter. Due to using the original holes in the door, and the seal constantly moving due to its natural curve, this took significantly longer than expected to line up. Still, I eventually sorted all the holes. Out came the rivet gun and it all fitted together. And yes, I did remember to check that the edge hadn't curled under. I had to follow this up with the door hinges, as trying to fit these with all the door mechanisms in place would be more than awkward. It turns out that trying to fit them without said mechanisms in place is also awkward. It was really difficult to get my fingers in there to get a nut and washer on the back of each bolt. It was a REAL struggle. Still, it's now done, and I don't really want to do it again... I have drawn a blank for finding some spacers for the window winders. So I may as well make something - but from what? I had those two rings I'd cut from pipe, but I knew these weren't right. However, cutting them and expanding them slightly made them the perfect size for a mold. So I got some parcel tape, and some card, and made 2 little non-stick "pools" for resin. Of course they weren't quite liquid proof, but because I made a "hot mix", it only leaked a little bit before settling. Finally, the door handles turned up. These were 3D printed by the look of things, but were generally pretty good. I gave them a quick sand and gave them a coat of textured paint. Lovely. I might try putting a door together soon... Waist seal. Of course it wouldn't stay in place... ![](https://i.imgur.com/tAxQLGc.jpg) It does when it's riveted! ![](https://i.imgur.com/QaWR4th.jpg) Taping a nut to the spanner in an attempt to get it on the hinge bolt - this failed... ![](https://i.imgur.com/OkSRffd.jpg) EVENTUALLY got the hinges on... ![](https://i.imgur.com/7atiZCk.jpg) Molds ready to receive resin... ![](https://i.imgur.com/OequMYF.jpg) ...and full up (with some small leaks). ![](https://i.imgur.com/6sCQfII.jpg) And lastly, new door handle surrounds, which have been painted. Excellent!
Jun 14, 2024 18:17:33 GMT
Great work buddy she’s coming on nicely
Fraud owners club member 2003 W211 Mercedes E class 1998 ex bt fiesta van
Jun 15, 2024 21:19:39 GMT
Great work buddy she’s coming on nicely Thanks Dan - as usual, it's a struggle, but I am getting there! Before I did a "dry" fit of the door and its associated hardware, I took a cutting disc to the sides of the molds I'd made for the homemade winder spacers. They cracked open beautifully and I am pretty pleased with what I have created. They're slightly different sizes, one being slightly thicker than the other, but that is nothing that a bit of sanding can't cure. I'll get back to these later. So back to the doors: I wanted to do a dry fit to make sure everything lines up and also to make that mental note of the order they have to be reassembled. I needed to reattach the cable to the latch mechanism, but i could not properly do this until the pull handle was carefully slid home into the door plate. And when I did manage to get the cable in its hole, it pushed the grommet out and broke it, probably because it was 45 years old and as brittle as a 1970s Christmas decoration. Luckily I have a box of more recent grommets, so I sorted a replacement for both this door and the other, as that one would almost certainly be as bad. It was. Having got the rod in place, I gave the mechanism a shot of white grease, before sliding the door frame into place. I needed to amend the edges of the waist seal as they both fouled. Not a huge undertaking, but still something that needed attending to. Having attached the frame with some screws, I then realised that there was a step I 'd missed: I cannot attach the mirrors with the door cards in place, so these need to go on first. Luckily, these actually were in the box marked "Mirrors". They still need putting together, but this was an easy formality. I just need to sort the bolts to permanently attach them, which have to be screwed in from the inside of the door. Note to self: don't break the mirrors, as finding a replacement from a Renault 14 is somewhat difficult. I got my passenger one as a lucky find from Ebay in France about 12 years ago. Finding one today is as likely as me going for drinks with Gemma Arterton, and Hayley Atwell. At the same time. It isn't an impossibility, but it is rather improbable. Damn. I then disassembled the door as I will need some sealant to put under the bottoms of the quarterlights and under the front of the door frames. I don't have any, so I will need to get some. More shopping I guess... Molds "popped" ![](https://i.imgur.com/oUdDhLH.jpeg) Cable not quite in place... ![](https://i.imgur.com/GDlO8kw.jpeg) ...as it needs to be fitted to the door plate. ![](https://i.imgur.com/ZXvuFYm.jpeg) A 45-year old grommet self destructed. Well that's a surprise... ![](https://i.imgur.com/RFsgNto.jpeg) Grease is the word... ![](https://i.imgur.com/C6Q9t1f.jpeg) Adjustment needed here... ![](https://i.imgur.com/4g4HVnB.jpeg) ...and here. ![](https://i.imgur.com/lRxDbRU.jpeg) Frame temporarily in place. And looking pretty good. ![](https://i.imgur.com/3rWCP4v.jpeg) Mirrors located, and put together. They reflect, which is a good thing! ![](https://i.imgur.com/nIyvEA6.jpeg) Aaaaannnd everything is in bits again. I need to go shopping. Again. ![](https://i.imgur.com/TXilWql.jpeg)
Jun 16, 2024 14:49:58 GMT
Just a very quick little update, and it's something I have been meaning to do for AGES. That little some was to sort an earthing point on the front subframe. So in I went with a drill and made a hole for an appropriate bolt. The more difficult thing was to get an tool in place to clean off the paint surrounding the hole. Sounds easy in practice, but when there's 1293cc of BL's finest and a Midas bodyshell in the way, it makes it a bit awkward. Eventually I managed to get in there by removing the coil and its bracket plus taking the entire filter system off the Powerfile. I ended up with about 3mm clearance, but this was enough room to attack the paint with 8 grit belt. Paint removed, I used a couple of star washers and nipped it up. Now any earth leads can terminate here and be secured with a nut. Excellent. ![](https://i.imgur.com/JTuMykB.jpeg)
Last Edit: Jun 16, 2024 14:51:11 GMT by mrbounce
Jun 16, 2024 15:44:20 GMT
I got a good tip recently for earth connections. It’s a bit “bodgy”, but if you can get in with a drill to drill the hole, then just go all the way in and use the jaws of the chuck to neatly take the paint off in a circle around the hole.
Jun 17, 2024 11:45:07 GMT
I got a good tip recently for earth connections. It’s a bit “bodgy”, but if you can get in with a drill to drill the hole, then just go all the way in and use the jaws of the chuck to neatly take the paint off in a circle around the hole. Believe it or not Glen, I could not get the drill down that far 😆 But still, good to know for the future.
