New project this I don't have any pics yet but will update once I get going properly A while ago a Honda s2000 came up for sale on this forum with no engine It was on here for over a month and was within 10 miles of my house I tried so hard not to buy it But in the end I could resist no longer It's turned out to be a bit of a gem with adjustable bilstiens new ferrodo track pads and disc polly bushed throughout
I already had a Volvo 760 t with a 182 hp turbo engine So it only seems natural to graft them together
I started to strip the Volvo selling a few bits as I went I needed to get the engine loom separated from the rest (what a job that was) And today removed the engine from the car
So the plan is Volvo engine with Volvo M90 gearbox and a manual boost controller and chip in ecu And use as many Volvo bits as possible to make the conversion reliable
Last Edit: Jul 9, 2016 15:28:28 GMT by Bozwell
This sounds very interesting, I will be following You can get a bsr chip that gives the b230et an extra 60hp and an extra 50nm en.bsr.se/tuning-kits/t/757The ET will have weak 9mm rods though so if you are tuning it then I would invest in some stronger connecting rods. 13mm ones can be had from the later FT or H beams are available from America.
🇿🇼Kingludba🇬🇧
If in doubt... flat out !
watching eagerly......
`99 BMW 528i auto - current `01 Merc C320 - Gone `01 Forester S-Turbo - Sold `89 BMW 320i Convertible - Sold(shoulda kept it ) `88 Toyota MR2 T-Bar - Sold `89 BMW 325i touring - Sold `89 BMW 535i - Let her go too early `85 BMW 320i 2 door - Rust = character `00 Subaru Impreza Turbo wagon - Sold (engine failure) `93 BMW 325i - Sold
This sounds very interesting, I will be following You can get a bsr chip that gives the b230et an extra 60hp and an extra 50nm en.bsr.se/tuning-kits/t/757The ET will have weak 9mm rods though so if you are tuning it then I would invest in some stronger connecting rods. 13mm ones can be had from the later FT or H beams are available from America. Yes I found bsr and will be investing once it's all up and running as I understand it the rods should be fine with there stage one and mild boost increase
This sounds very interesting, I will be following You can get a bsr chip that gives the b230et an extra 60hp and an extra 50nm en.bsr.se/tuning-kits/t/757The ET will have weak 9mm rods though so if you are tuning it then I would invest in some stronger connecting rods. 13mm ones can be had from the later FT or H beams are available from America. Yes I found bsr and will be investing once it's all up and running as I understand it the rods should be fine with there stage one and mild boost increase I wouldn't trust it, I know of someone who wheelspan a standard 740 turbo and sent a rod through the block, I think 87 was an especially bad year for them IIRC, they always seem to be extra weak.
Jul 14, 2016 12:46:11 GMT
That's ok then mines a 89
alx
Club RR Member Number: 21
Jul 14, 2016 14:24:41 GMT
OOOh a big swede into a sexy japanese model, I'll be watching eagerly.
AL.
Jul 14, 2016 20:07:58 GMT
Love the sow of this I'm running a 940 turbo so I know the tuning ability of these engines Light sports car with boosted red block = serious fun
Jul 26, 2016 19:45:29 GMT
Engine mounts are made and tacked in place Engine fits nicely and box fits well to I had to convert engine to front mount dizzy and slim down the front pully http:// ~original
Jul 26, 2016 20:18:20 GMT
Bookmarked!
Volvo power in a lightweight 2 seater shell reminds me of the original Marcos GT :-)
fer4l
Testing
Club RR Member Number: 73
Jul 26, 2016 22:51:52 GMT
Filed under 'yes of course why ever not'! Can't help wondering what an s2k brick would be like by comparison! Cheers Matt
Sept 10, 2016 16:43:23 GMT
Progress has been good gearbox mount and linkage have been made, propshaft is at the engineering shop, wiring is nearly done , coolant and fluids in clutch bleed I will get a few more pics up next week Soon be ready to try and fire it up
Sept 10, 2016 21:01:52 GMT
Nice work
Sinky
Run Baby Run......Please!
Sept 10, 2016 21:06:17 GMT
as above ^^^^^^ with a very at the begining
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
Sept 11, 2016 10:04:23 GMT
Genuinely thought this would be the Honda engine in the Volvo. This is way better, moar pics!
MK2VR6
Mk2 Golf GTi 90 Spec
Sept 11, 2016 10:17:47 GMT
I spotted the S2000 rolling shell on here - great to see that you've put it to good use. Nuts!
Sept 11, 2016 12:55:44 GMT
Now this is what i come here for!
Managed to get some time on it yesterday with a mate And it now runs But not very well suspect fuel pressure fault but ran out of time Gonna fit the Volvo fuel pump and filter tomorrow and just use the s2000 pump as a lift pump So when it's moving around under its own steam progress will be a bit quicker
Oct 10, 2016 20:04:53 GMT
Had a bit more time today and running issue now sorted So it's nearly back on its feet and be able to move around the yard on its own Still abit more wiring to tidy up and alternator to sort all small jobs in the grand scheme of things I will try and remember to take a few more pictures for you
