aws
Just smile and wave boys. Just smile and wave.
Not so manu updates. Still waiting for head gasket to arrive. Engine block has been put together. Pistons on, crancshaft in. and engine in as well. Gearbox connected. Propshaft connected. Starter motor in. Generator in. Changed the steering shaft rubber ring. And waterpump in as well Thats all I can add on the engine before head comes on.
aws
Got an engine headgasket today. So it did not laid down for long With gasket installed ir was time to move to Simons exhaust Since I have towing hook on my car, I need to modify bracket that holds rear silencer And doesnt ir look gorgeous?
aws
And after some fidling
It runnnnsssss
Last Edit: Aug 12, 2016 4:46:56 GMT by aws
aws
So here is new Simon exhaust
eternaloptimist
Aug 11, 2016 11:19:03 GMT
Looking good!
aws
Aug 11, 2016 13:16:09 GMT
Today I went thru car registration office. First of all VIN check. And then thru MOT. No advises. Perfect.
Last Edit: Aug 12, 2016 4:45:21 GMT by aws
I see nothing. But good to hear everything went to plan.
aws
I see nothing. But good to hear everything went to plan. Yes sorry. Seems that I have done something wrong with google photo access. Now it seems to be OK. And specially for you small video from MOT brake test.
aws
aws
And some Simons sound on idle. Will make a better videos later on. Now it was more to rush and go thru MOT to get it legal.
aws
Yesterday was time to adjust valve clearance again. Since car has been running for a while. So valve cover off. 0.40 and 0.45 out for go no go adjustment After adjustment engine was running way more silent and no tapping noise. Next thing was to adjust ignition timing, since I was not happy how the car was running. First I found a great article on the internet. Volvo Ignition 101Since I was disassembling the engine, my shaft for the distributor was off the desired position. So moved this anti clockwise a bit and changed ignition points as well. After the new timing engine feels to be more happy, but I am not satisfied with idle still. It sounds uneven. So will see what could be done there.
Last Edit: Aug 17, 2016 6:16:35 GMT by aws
aws
Aug 16, 2016 16:50:52 GMT
Was on my way home and standing in the queue needle was creeping on its way up. Found good article on this type of temperature indicators. Www.sw-em.com/temperature_gauge_notes.htmSo will need to check what is actual temp versus reading on the dash.
