1990 white Eunos Roaster
It has about a months worth of mot, i wont lie. It is unlikely to pass another one for these reasons
1. It doesnt have a fog light, but good news the wires are there and they do work with the appropriate switch in the car.
2. The exhaust has a blow in it.
3. It doesnt have a handbrake, having had a look i think the cable has stretched, one of the calipers is a year old and the other also works.
Apart from those i don't believe there to be any major sill issues or rust that could cause a failure, however i would say it needs attention before the winter.
There is some bubbling on the front wing that i noticed the other day.
Some Good Bits.
It has factory Bilstein shocks and springs, the car is rather stiff and handles corners like you wouldnt believe.
It also has a factory LSD but don't get your hopes up about buying this car to drift unless its wet and you have bald tyres it is quite difficult.
For added stiffness it has front strut brace, lower brace, and harness bar.
The roof was replaced at some point and has a glass window instead of the awefull crackable plastic sort.
Being an import it does have speakers in the headrests and they work!!
Electric windows work too!!
The wing mirrors arnt seized solid nor do they break off in your hand when you want to adjust them.
It has a factory momo steering wheel and cover!
Bad bits
Like i said the front wing has a little bubble come up.
Unfortunately i bought it from a cretin who painted it white its not the worse job in the world but it definatly isnt the best and it shows in some places.
The engine has beeing replaced as the original had crank wobble it was replaced with a similar engine, which doesnt appear to have the wobble, although can be hesitant at low revs
The wheels in the photo are from my nova i don't intend to keep them on the car as they are 13" i will source some steel wheels for.
Reason for sale is the car doesnt get used because i just don't have the time.
Any questions feel free to ask.
Thanks for looking.
Some Good Bits.
Bad bits
Thanks for looking.
