logicaluk
Aug 14, 2022 18:48:02 GMT
I've just got back from a quick lap around the block, and I'd say it seems like a success, the 18mm rear ARB was to thick and the car stayed too flat in the corner that was changed for a 16mm one and now it has a slight roll, which feels more normal, the strut brace seems to have done the trick at the back as I can't hear the glass moving, when putting it away. Dan
Darkspeed
Club RR Member Number: 39
Aug 14, 2022 21:04:09 GMT
Closing on 3.0 KG I would think
logicaluk
Aug 16, 2022 18:56:06 GMT
DS you amaze me 2.7kg which I didn't think was too bad. Dan
Darkspeed
Aug 16, 2022 20:57:09 GMT
Years of fixation on power to weight ratios.
logicaluk
Aug 17, 2022 19:39:06 GMT
And the AFR gauge is poo and won't give a consistent reading that matches the serial output of the LC-1. biscuits. Dan
logicaluk
Aug 25, 2022 21:07:09 GMT
Today I have been measuring and making poor choices.
A conversation with a chap on the book of farce, led me down a path I didn't expect, so I was telling this guy about the flow bench testing I had done with DS's help, and he swears blind his engine needed more air and the air box was the restriction, I was a little sceptical, until I realized I had taken my modified twin inlet air box to test not a standard one, bum hats. So how come his engine needs so much air, I don't hear you ask, well he's found that a late 70s civic 1500 has a 74mm piston has the correct gudgeon pin size, and there's a few sets in the US on eBay
Ooh I thought, that might be worthwhile 1428cc that's almost 100ccs more and a healthy hike in compression ratio, but then I thought head gasket, how big is the fire ring, and today I measured it to be 74mm, so today I purchased a set of 4, 74mm pistons with rings and pins for £120. Oops Dan
logicaluk
Mar 19, 2023 19:18:49 GMT
For some time I've felt Frank didn't seem quite quick as he once was, today was the Maple Garage Auto Test and I found Frank's fizz. Yesterday I got Frank ready, which wasn't much, I checked the oil level and decluttered the interior, fitted a standard exhaust manifold to quieten the exhaust a little and swapped out the 195/50/15s 5 spoke wheels for some 195/50/14 minlite style wheels. BINGO, what a difference they made, 80mm rolling radius and 15mm smaller in diameter = different car.
Today at the Auto Test I had so much fun hooning around, but seeing as I was with 3 stripped out Novas, a Mini, well a Mini floorpan and bulkhead, a Caterham, a stripped out MX5 and Toyota Yaris all with limited slip diffs and hydraulic handbrake conversions. No surprise that I came last, over all, in my road going Acclaim, But first in class. It's making me rethink Frank's future.
logicaluk
Mar 20, 2023 22:09:09 GMT
A helical LSD is only £750, pfff only £750 ive got to finish off the garden office and build the Bond first, but they are available. Dan
logicaluk
Mar 27, 2023 16:52:55 GMT
Not being one to give up any holiday day owed to me, I took my last one of the financial year today. I was hoping to take the Mrs away for a long weekend, but our son came home Saturday afternoon, having driven back from Swansea to drop his car off before leaving for that there London, on Sunday afternoon, so that didn't happen. Craig had decided to take up a last minute bargain holiday in Turkey, so I couldn't put down the floor in Tina's garden office, so I went to the scrapyard (u pull it york) and spent a not too disappointing afternoon acquiring parts, this is what £70 bought me the complete rear brakes from a Honda Jazz mk1 I had hoped to use Mk2 jazz rear brakes as measuring mine the wheel flange to axle flange appeared to be within 2mm of the acclaims, but when I got to the breakers, I found the stub axel is part of the rear beam so no flipin use, but the Mk1 stub axles are bolted on, the flange to flange is more like 4-5mm more than the acclaim, I think there will be enough room for the tiers, if not ill roll the arches further out. The stub axle bolts holes almost line up too I'm not sure how to proceed with this bit, options I can think of, A file it out with a round file. B fill the whole with some bar stock and re-drill C send it to a machine shop for them to fix. Brake hoses should be fairly easy the acclaim has braided hoses, if I can find a 90 deg banjo to brake fitting adaptor to join them or ill get the rear hoses remade. What I thought was going to be the biggest problem the handbrake, all the handbrake cables at the U pull it were seized or had the car parked on top of them, new sets are £60, I also picked up the handbrake and the bolt on cable clip that holds the ends of the cables, it looks like if I can lengthen the adjuster to go through the floor with a tube nut and some all thread that will put the balance bar on the outside it should all work rather nicely. Master cylinder I fetched a 7/8's one from the same car but didn't pick up the brake booster and of course, it doesn't fit the acclaim booster so ill have to order one of those too. Any thoughts are as always welcomed. Dan
logicaluk
Mar 27, 2023 18:43:37 GMT
got to love an ebay discount code, parts in motion has a 20% coupon "catch20" Just ordered handbrake cables, pads and a fitting kit for £60
jamesd1972
Club RR Member Number: 40
Mar 27, 2023 19:06:07 GMT
Option C sounds sensible - some quite big forces going on - going to modify the Jazz or acclaim bits to fit ? James
logicaluk
Mar 27, 2023 21:33:43 GMT
The threaded part is on the Acclaim knuckle, so ill make the Jazz parts fit the Acclaim.
Last Edit: Mar 27, 2023 21:33:58 GMT by logicaluk
logicaluk
I've been reading up on rust removal, and came across reverse electrolysis, I have a plastic bucket, plenty of steel and a power supply, the only thing I was missing was some washing soda, £1.10 later and the necessaries are in my possession. So I put this along with the rest of the parts in turn, in here this fell off then all went for a blast in here and ended up looking like this I got an acclaim rear strut out of storage and had a play The only way I can see to make it fit, means having to take the caliper off to bleed it, but thats not the end of the world. Here's my pln First the back of the acclaim knuckle needs a spacer making to fill the 42.25mm locating hole and a new one drilling out at 20mm to a depth of 10mm to suit the jazz locating pin the recess in the back of the original locating hole is about the right depth, it just needs squaring off. Get the face of the jazz spindle milled down a couple off mm to an even clamping surface, for a 5mm thick spreader plate, to bolt it to the knuckle and drill the jazz spindle out to the new bolt pattern. Please discuss. Dan
Last Edit: Apr 9, 2023 14:00:17 GMT by logicaluk
79cord
Apr 10, 2023 12:20:32 GMT
Interesting to see the Jazz rear discs. Still a little hard to understand where the calipers will end up in relation to the rear struts to understand bleed nut location difficulties, but good to see the rear hub assembly mounting holes aren't miles out & good to see it isn't a sealed spindle & bearing asm. Assumed there would not be enough track width to bolt adapter plate between hub asm & strut mtg... though Jazz does have different wheel offset than the older Civics. Thankfully I don't think most Civics really need to increase master cyl. & proportioning valve to upgrade to rear discs from drums (my Accord & 4th Civics didn't). Honda usually did so because they also gave rear-disc equipped Civics larger frt brakes & calipers with bigger wheel cylinders. A picture of 88-00 Civic rear disc/caliper/hub arrangement in case it helped any. with slight difference in fluid entry between 4th (ED/EE/EF) & 5/6th (EG/EH/EK). Wonder if the calipers could be interchangeable for alternative bleed & handbrake cable locations. I bolted a custom adapter to the calipers handbrake actuator so I could retain my original transverse h-brake cables on my '79 Accord because seatbelt mounts were directly behind it's interior h-brake lever making alternatives more challenging.
Last Edit: Apr 10, 2023 12:51:15 GMT by 79cord
logicaluk
Apr 10, 2023 21:16:10 GMT
thanks cord Interesting to see the Jazz rear discs. Still a little hard to understand where the calipers will end up in relation to the rear struts to understand bleed nut location difficulties, the calipers are switched left to right, and can only go towards the rear as the trailing arm is in the way of something everywhere else, the handbrake cable runs up the top of the trailing arm. but good to see the rear hub assembly mounting holes aren't miles out & good to see it isn't a sealed spindle & bearing asm. Assumed there would not be enough track width to bolt adapter plate between hub asm & strut mtg... though Jazz does have different wheel offset than the older Civics. the hub is already 4mm or so deeper than the drum hubThankfully I don't think most Civics really need to increase master cyl. & proportioning valve to upgrade to rear discs from drums (my Accord & 4th Civics didn't). Honda usually did so because they also gave rear-disc equipped Civics larger frt brakes & calipers with bigger wheel cylinders. A picture of 88-00 Civic rear disc/caliper/hub arrangement in case it helped any. with slight difference in fluid entry between 4th (ED/EE/EF) & 5/6th (EG/EH/EK). Wonder if the calipers could be interchangeable for alternative bleed & handbrake cable locations. I bolted a custom adapter to the calipers handbrake actuator so I could retain my original transverse h-brake cables on my '79 Accord because seatbelt mounts were directly behind it's interior h-brake lever making alternatives more challenging. I have a cunning plan
logicaluk
Apr 10, 2023 21:19:23 GMT
thanks cord Interesting to see the Jazz rear discs. Still a little hard to understand where the calipers will end up in relation to the rear struts to understand bleed nut location difficulties, the calipers are switched left to right, and can only go towards the rear as the trailing arm is in the way of something everywhere else, the handbrake cable runs up the top of the trailing arm. but good to see the rear hub assembly mounting holes aren't miles out & good to see it isn't a sealed spindle & bearing asm. Assumed there would not be enough track width to bolt adapter plate between hub asm & strut mtg... though Jazz does have different wheel offset than the older Civics. the hub is already 4mm or so deeper than the drum hubThankfully I don't think most Civics really need to increase master cyl. & proportioning valve to upgrade to rear discs from drums (my Accord & 4th Civics didn't). Honda usually did so because they also gave rear-disc equipped Civics larger frt brakes & calipers with bigger wheel cylinders. I already have extra large calipers at the front, so I hope notA picture of 88-00 Civic rear disc/caliper/hub arrangement in case it helped any. with slight difference in fluid entry between 4th (ED/EE/EF) & 5/6th (EG/EH/EK). Wonder if the calipers could be interchangeable for alternative bleed & handbrake cable locations. I bolted a custom adapter to the calipers handbrake actuator so I could retain my original transverse h-brake cables on my '79 Accord because seatbelt mounts were directly behind it's interior h-brake lever making alternatives more challenging. I have a cunning plan
logicaluk
Apr 28, 2023 19:31:42 GMT
A Little update, on Sat 15th May I ordered some parts for Frank, A bottle of Aldi's Jammy Red may have been involved in the decision. I ordered, A Gasket and a seal and bearing kit for Frank's gearbox, a NOS engine mount, and an M Factory helical limited slip diff from Civic Garage in Australia and as they were out of stock a pair of Super Pro inner poly bushes for the lower front suspension arm from a place in Yeovil. The gasket bearing and seals arrived from the other side of the world 5 days later on the same day the poly bushes arrived from Yeovil, go figure. Then today 13 days after ordering, this arrived
jamesd1972
Ooh black and shiny! Nice James
79cord
Apr 29, 2023 13:08:01 GMT
Exciting! Makes me wonder how broad the interchangeability of that Diff. centre is given how small the market would be for 2nd gen Civic would be & Honda's penchant for changes!?
