Nov 12, 2018 20:51:51 GMT
A car heavy post this time. Not "in" to bikes but this is nice! DSC_3428 by quickrack, on Flickr This was parked a bit further up the street. 2 interesting vehicles in one day! I nearly got excited. DSC_3430 by quickrack, on Flickr At work I saw a very sick Sprite :-( DSC_3433 by quickrack, on Flickr DSC_3436 by quickrack, on Flickr DSC_3434 by quickrack, on Flickr And then a few days later a Hyabusa powered Fiat!! DSC_3441 by quickrack, on Flickr DSC_3442 by quickrack, on Flickr And a Landie being saved (or scrapped) DSC_3444 by quickrack, on Flickr Brought a car for scrapping and picked some tat up while there This will be my new garage stove. Freebie from the scrappy along with some old outboards. DSC_3455 by quickrack, on Flickr DSC_3456 by quickrack, on Flickr DSC_3457 by quickrack, on Flickr DSC_3458 by quickrack, on Flickr DSC_3459 by quickrack, on Flickr More as and when....
Nov 13, 2018 12:13:06 GMT
You're not my Dad reincarnated are you? He had a penchant for old outboards. Seagulls by the dozen. Always liked them though, helped me win my first Menai Straits raft race! His favourite, although got knows why, was a 6.5hp Perkins. Huge thing and couldn't pull the skin off a rice pudding. Not that it ever really had the chance, it was always in bits!
Last Edit: Nov 13, 2018 12:13:54 GMT by georgeb
Nov 17, 2018 12:16:28 GMT
You are a genuis quickrack!!! I have been thinking about a sing from the eighties for a very long time nw. Couldnt remember songtitle or artist,but could sing it in my head.
With your lictures,it came back!!
Seagull....
Wait.... A flock of seagulls,with : the more you live,the more you....
Genius you!
Inside the tank was all this yummyness DSC_3461 by quickrack, on Flickr Drilling a chimney hole. DSC_3487 by quickrack, on Flickr DSC_3488 by quickrack, on Flickr DSC_3489 by quickrack, on Flickr Old bit of 2.5" ID exhaust DSC_3490 by quickrack, on Flickr Looking where it may go. This is one side of the entry door and 90% of the time I am the other side as that's where the bench/vise etc is. DSC_3511 by quickrack, on Flickr My airflow control. The top screw turns and moves the smaller tube out and it has a slot in. The plan is, the further you open it the more of the slot is exposed giving the fire more air and vise versa. DSC_3537 by quickrack, on Flickr Thats it on, plus you can see the door is started. DSC_3549 by quickrack, on Flickr DSC_3550 by quickrack, on Flickr DSC_3551 by quickrack, on Flickr Covered the door cuts to help control airflow DSC_3554 by quickrack, on Flickr DSC_3555 by quickrack, on Flickr DSC_3556 by quickrack, on Flickr Knocked up a bit of a catch and receiver. DSC_3557 by quickrack, on Flickr DSC_3558 by quickrack, on Flickr DSC_3559 by quickrack, on Flickr "Just" need a 6" disc of heavy(ish) steel to finish off the top now. I hope to do the top and test it tomorrow. DSC_3560 by quickrack, on Flickr More as and when....
Last Edit: Nov 29, 2018 1:56:38 GMT by Deleted
Nov 30, 2018 16:01:48 GMT
Got a piece of 8mm steel for the top. My question is should I preheat it to get some penetration??
Nov 30, 2018 19:41:47 GMT
Are you putting a grate in this? Burning coal type fuels? With the air inlet at the bottom it would naturally prefer them over wood. Might be worthwhile adding a small permanently open air inlet or another top inlet. However,the flue is tiny so it may not be happy like that.See how it goes with the air inlet, you may need to close it down alot or fit a bigger flue.
Last Edit: Nov 30, 2018 19:45:14 GMT by VW
Nov 30, 2018 21:54:48 GMT
Are you putting a grate in this? Burning coal type fuels? With the air inlet at the bottom it would naturally prefer them over wood. Might be worthwhile adding a small permanently open air inlet or another top inlet. However,the flue is tiny so it may not be happy like that. See how it goes with the air inlet, you may need to close it down a lot or fit a bigger flue. I am building a grate and I intended to burn scrap wood like broken pallets etc. I have a 4" ID pipe i could replace the current flue with?
Nov 30, 2018 22:04:33 GMT
Would be better, yes. Wood likes to get its air from above and is happier sat on a bed of its own ash. Coal based fuels like to get their air from below and needs an open grate. Your building a multifuel stove more suited to coal but plan to burn wood. don't get me wrong, put fuel and fire in it and stuff will burn, just pointing out a few design considerations. I fit solid fuel appliances for a living
Would be better, yes. Wood likes to get its air from above and is happier sat on a bed of its own ash. Coal based fuels like to get their air from below and needs an open grate. Your building a multifuel stove more suited to coal but plan to burn wood. don't get me wrong, put fuel and fire in it and stuff will burn, just pointing out a few design considerations. I fit solid fuel appliances for a living I don't mind. Good advise is great to get. I'll need to figure out a top air feed but I like to learn. Thanks! More pics when the mods are complete then
Dec 10, 2018 10:24:19 GMT
Re bookmarked as it's seems to have dropped off my "recent threads" list.
Jul 12, 2019 12:29:04 GMT
Its been a while. My depression was pretty bad last winter and spring but I currently have a grip on things. So A mate rang "You know I'm getting divorced? Well I have a car transporter trailer. Want it for 300? Needs a bit of tidying" I said yes and this got dropped off.
Jul 12, 2019 12:30:51 GMT
Jul 12, 2019 12:32:44 GMT
Then it's first, mildly illegal use. Mudguards ordered. And lights are repaired and functioning. Will fit better rear load legs and a jockey wheel next
Jul 12, 2019 12:36:14 GMT
Jul 12, 2019 12:38:20 GMT
mungo
Jul 12, 2019 12:57:58 GMT
Our Giant Jersey Chicken, all damn near 3 ft tall of him is breaking the hips of the brown hens while rapeing them and needed separating.
56' bug 2332 +ida's 56' lowlight ghia 72' bus 1600 devon 67' type 3 square - gone 83' gti - gone 90' gti 16v - gone 82' chevette - gone 70' GP1 Beach buggy -gone 78' lightweight landrover 3L v6 -gone 89' gti - gone 83' gti - gone
Jul 15, 2019 21:52:28 GMT
Its been a while. My depression was pretty bad last winter and spring but I currently have a grip on things. Good to hear. So a mate rang "You know I'm getting divorced? Well I have a car transporter trailer. Want it for 300? Needs a bit of tidying" I said yes and this got dropped off. I can see why he'd want to out that before his ex battled in court for it!
Jul 16, 2019 21:34:21 GMT
Its been a while. My depression was pretty bad last winter and spring but I currently have a grip on things. Good to hear. So a mate rang "You know I'm getting divorced? Well I have a car transporter trailer. Want it for 300? Needs a bit of tidying" I said yes and this got dropped off. I can see why he'd want to out that before his ex battled in court for it! To be fair it's in better nick than it looks. My main issue is my welder is playing up, yet again, and I cant repair it, so i cant move on with several jobs incl this thing!
Last Edit: Oct 9, 2019 19:43:00 GMT by Deleted
I sold off loads of bits. Most of the cash went back into the house but I kept enough to buy this. IMG_20190904_183254 by quickrack, on Flickr Last bits to get it working are in the post. Cant wait to try it. GrumpyNortherner recommended it and I cant find a single poor review anywhere! In separate news i found a Ford Model A axle and the owner gave it to me for free, he was that glad to find someone who wasn't going to weigh it in. IMG_20190906_154845 by quickrack, on Flickr A buddy was at the NEC earlier this year and picked me up a new fuel cap for the estate. NOS Ford! I was very impressed at the price. IMG_20190921_022731 by quickrack, on Flickr IMG_20190921_022805 by quickrack, on Flickr Bought a box of sockets at the market for a fiver. Got a lovely few useful bits out of it. IMG_20190921_140330 by quickrack, on Flickr IMG_20190921_140324 by quickrack, on Flickr Last sunday I worked, I passed a market and stopped for a quick browse. Found this decent Reel and the cable tie gun thing for €8 IMG_20190929_190226_513 by quickrack, on Flickr More, as and when!
Oct 29, 2019 12:14:53 GMT
Last Edit: Nov 18, 2019 18:05:42 GMT by Deleted
