mylittletony
Club RR Member Number: 84
Chromed plastic refurbmylittletony
@mylittletony
Club Retro Rides Member 84
Apr 19, 2016 19:44:35 GMT
Does anyone have any tips for renewing or refurbishing chrome plated plastic parts? E.g. grill edge trim I'm planning on using a spray can, but wondered if anyone knew better.
Apr 19, 2016 21:03:34 GMT
I am trying some chrome body wrap material on some platic trim around my windscreen which looks just like chrome, my trim is fairly flat, something with more form may be difficult.
Apr 19, 2016 21:07:47 GMT
"To Big block or not to Big block?" Thats the question!
Wilk
Apr 19, 2016 21:42:33 GMT
Remember a similar thing years ago with some plastic for a motorbike. The owner contacted Hornby or Airfix as they both produce chromed plastic parts for their goods
HTH
Last Edit: Apr 19, 2016 21:43:01 GMT by Wilk
Apr 21, 2016 13:02:13 GMT
You can actually get plastic re-chromed, depending on your budget. It might be worth asking some platers, or instrument/gauge specialists.
mylittletony
@mylittletony
Apr 21, 2016 13:09:51 GMT
cheers folks, definitely some food for thought. I'll have a good look and try and find some budget!
Apr 22, 2016 10:56:40 GMT
The other thing to look at is whether any of the headlamp refinishers can do it. The company I used - Dual Metallising in Bromsgrove - also refurbish reflectors for MGFs among other moderns, which are plastic. I believe it's a process called aluminium vapour deposition. There's also electroless nickel plating, though one plating company I talked to suggested it didn't last very long.
