Nov 27, 2016 12:27:10 GMT
All good! Being German-born and raised, I can read the text just fine! Those old Mopar 360s are pretty solid motors; I have the later 5.9 Magnum V8 in my Dodge Durango. Not the quickest, but definitely lots of low-end torque meant for pulling things, not going fast. Love the ratrod, but really love that gray one. For now I'm still leaning toward the original look with a surprise under the hood kinda deal, but that stance is realllly hard to argue with! R107 parts and the 126 parts will be easy for me to come by, and I'm intimately familiar with both; 6.3 parts not so much! Looking at the photos, it looks like they only cut into the firewall of the gray one just slightly to give the Alfa V6 some more space. However, looking at this one: www.mercedes-fans.de/magazin/auto-der-woche/die-besondere-lebenz-art-das-zweite-leben-eines-mercedes-oldtimers-als-mercedes-tuning-noch-customizing-hiess-1952er-mercedes-170-s-hot-rod.780Using a small-displacement Rover V8, they didn't cut it back at all! Perhaps there is hope to retain it! That said the M117 is a rather LONG and FAT motor... I should do some measurements between my 5.9 (which looks to be shorter and narrower, but taller) and the M117 to see what I get. Love what they did to the seats in that orange car though. According to the article, at the time of the writing, that redone interior had already been through 25 years of use! Quality work done, for sure.
'85 Euro 190E 2.3-16 '84 Euro 500SE ~100k miles '51 Euro 170S M117 Swap Project?! '97 Jeep Wrangler Sport ~42k miles '09 E350 ~51k miles '98 Dodge Durango SLT+ 5.9L Magnum V8 ~Josh
Nov 27, 2016 23:00:40 GMT
That's a great move. With the torque and power from the M117 what will you do for brakes and suspension? Rock on! On that I'm not really sure yet... it had drum brakes up front, don't remember what the rear had since that whole assembly was sold from underneath me. I really don't know about the suspension. Front is an independent deal (the rear was too), and all that needs is some refreshing of the components. Considered a solid rear axle from a small pickup, but likely need to do some sleuthing around the web to see what people have done with the rear-ends of these cars that chose to go for a larger motor. What I do know is that I'll be able to make a lot more space with the M117 by losing the power steering pump (the steering in this car is surprisingly easy to manipulate, very smooth even after all these years) and the AC compressor which is failing anyway. I'm looking for suggestions on the rear suspension matter, so I think what I'll do is take a photo of where the factory subframe would sit, and see what the consensus is as for what I should roll with. I'd have grave reservations about not having PAS. And since this is a major build it might seem wise to fit AC, in for a penny in for a pound! How about using the rear floor pan section from a W201 and it's multi link suspension plus you are bound to get a suitable diff ratio too. Keep up the good work.
I could honestly live without the power steering; like I said, the steering box in this car is surprisingly smooth and easy on the arms.
I'll see what I can do about the AC; I'd imagine to preserve these components I will need to cut into the firewall.
The biggest issue with the W201 rear subframe is the same issue I ran into when trying to use the Miata rear subframe. both are meant to be bolted to a perfectly flat section, but the rear frame of the 170 is shaped like a giant wave. I'm going to get a photo of it tomorrow. Would have been nice to see build threads for the example cars pictured here to see just what exactly they did with the rear!
Then of course there will be the whole conversion from 6V to 12V, fuse box and wiring, etc. I know a lot, but I have even more to learn! Thankfully I enjoy this, hehe.
So here's what the rear looks like, I could probably stand to get even better photos. The rear fenders have been removed, so you kinda lose out on how much space you have and how it's shaped:
smeden
"Full throttle until you see God,then shift to second"
Nov 29, 2016 10:53:17 GMT
Why not go the way of all other rodders and try finding an xj6 rear end! It's got all what you need. I like your car! Nice build! The rusty 170 is ace!
Keep up the good work and greetings from Denmark
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
Nov 29, 2016 19:28:56 GMT
I hadn't considered a Jag rear end; should be easy to find around here, actually.
I'll be needing to make a run to the yard soon, so I'll be checking there to see what I can find.
Dec 12, 2016 17:36:27 GMT
I'm at a point now where I just need to find a new place to work on the car; somewhere with easier access. Can't bring it home as I've no space here.
Not much to update right now, been fairly busy with the recent time off! Tomorrow I'm going to attempt to get my spare M117 long block in to see how that works out.
Honestly, I wish I could trade this chassis for a W120/121 ponton! Or even try to score a W186/189 (the Adenauer favorite).
I'm torn!
We'll see where I end up tomorrow.
Well, today I was able to get that Miata plant and gearbox out to start with the M117! There are some clearance concerns, but I may actually be able to fit the motor with no other modifications beyond making a custom oil pan! Right now that can't clear the front crossmember (a friend of mine cut the brackets while I was working with the steering column) because of the oil pan. Should that be moved more toward the center of the motor, you could swing it under and clear both the steering box, and that crossmember! Worst case scenario, I may notch the front two crossmembers if the motor needs to sit a little lower. I'm going to bring my spare heads and intake and valve covers to put the motor together to get a better idea of the overall size. This is definitely doable! I'm actually super excited! The more of the body I can preserve, the better. It's really fascinating to examine the front suspension of this car; all it would need is beefier springs! I'm also looking into converting from drum brakes to discs up front. Should be able to work some magic with the front wheel assembly, but I'm going to pull one side off to see what I've got. It's a shame that rusty ratrod 170 doesn't share photos and details of merging R107 discs to the front. I will need to do some research. I think now I will look into sending the wheels off for paint, so I can get some new rubber on them in anticipation for setting it back on the ground once the rear suspension has been addressed.
Dec 31, 2016 10:35:05 GMT
"Worst case scenario, I may notch the front two crossmembers if the motor needs to sit a little lower. I'm going to bring my spare heads and intake and valve covers to put the motor together to get a better idea of the overall size."
What about a dry sump setup?
Dec 31, 2016 10:55:04 GMT
This is an extremely exciting build. Can't wait to see the progress unfold
Dec 31, 2016 16:28:24 GMT
Hmm, I may be needing a few things here and there in the future, but I can't think of anything just yet! Mostly everything I have is in good shape and just needs to be refurbished or cleaned up. "Worst case scenario, I may notch the front two crossmembers if the motor needs to sit a little lower. I'm going to bring my spare heads and intake and valve covers to put the motor together to get a better idea of the overall size." What about a dry sump setup? I considered a dry sump setup similar to that of the 6.9L M100 V8, but I think I can make it work with just a custom oil pan. This is an extremely exciting build. Can't wait to see the progress unfold Yes! This latest development is actually exciting! Got a ways to go, but now there's a solid, more tangible plan, and having a spare motor to play with makes all the difference.
Jan 17, 2017 17:55:42 GMT
Went and did some cutting on the oil pan today. Pretty much all I have to do is turn the sump around. However, it's looking to still be very tight. Really didn't have much of a chance to get it set in properly, as I need to still cut off the dipstick tube. You can see the bottom of the timing gear and where the pickup is; stock pickup location will work by simply redesigning the sump and moving it back just a bit: Here it started going with the heads set on: And this is how I've left it for the day: I just set the valve covers on top as well, and you can see just how wide/tall this thing actually is. It can certainly fit, but space will likely have to be made. I wanted to avoid cutting into the firewall, but that may just have to be the way to go. Clearance up front for the alternator bracket looks nonexistent. I'd rather not abandon the V8 idea since I'll have a fresh one from my 500SE when it gets an SBC, but I'm beginning to wonder... I'm going to see if I can make some more test-fitting progress tomorrow and hopefully have an extra set of hands to guide things around.
I've done some more fiddling around recently, and it seems the motor is just too big! Compared to say an SBC, or a small-block Ford, or even the Chrysler LA motors like the 5.9 in my Durango, this M117 is just massive. It's pretty much a big-block without the awesome amounts of displacement you'd expect.
Back to the drawing board!
M111 is still on the table, but finding a manual donor car in the US is just impossible (or it's in great shape and too nice to rip apart).
I suppose cutting into the firewall is still an option, but if you look at the bay itself, you can see the lower portion of the firewall is the floorboard! Can't have that going back any further or I'll have no room at all. It's also just too wide up front, and I don't want to chop the wings; if I were going for the ratty rod look, I wouldn't care, but I want this to look as stock as possible except under the hood.
Buddy of mine floated around a Supra motor, but that I6 is even longer than this thing!
Going for an OM615/616 4-cylinder is looking like it may be back on the table as well. Looked into the OM601, but with the intake it's awfully wide as well.
At this point, I'm kinda stagnant, and I hate it. I've had this car since 2012 and haven't made any progress whatsoever, but as they say, Rome wasn't built in a day.
Feb 13, 2017 11:05:46 GMT
M111 with a six speed manual box from a W203/210/208/R170?
Feb 13, 2017 12:40:53 GMT
M111 with a six speed manual box from a W203/210/208/R170? Hard to find for a reasonable price around here because they are exceedingly rare; Americans are lazy and have to have a burger in one hand and big gulp in the other. They come up for sale from time to time through LKQ, but often times they need a rebuild or components are missing. That's why I'd like to have an entire donor car, but $6000 for a donor vehicle is steep, and this $500-1500 W203s don't exist here yet. Unfortunately we were never lucky enough to get manual 210s here in the US either, or the 208s for that matter. R170s in decent shape are starting to go for money again too. This is why I miss living in Europe; manuals everywhere.
Feb 13, 2017 16:28:27 GMT
have you considered a engine swap from a chrysler crossfire, they came in manual and the v6 isn't that large
Feb 13, 2017 17:28:22 GMT
have you considered a engine swap from a chrysler crossfire, they came in manual and the v6 isn't that large I worked on a Crossfire with the M112, and never again! That V6 is actually fairly wide, I thought about it too.
Feb 13, 2017 19:32:50 GMT
Actually, looked at the car today, and an old idea from previous years came up again; BMW 4cyl motor!
Sacrilege, I know, but I enjoy both BMW and MB, and finding a small BMW motor with a manual box is actually fairly easy here in the US. If it counts for anything, it all stays German instead of rolling with the original Japanese V6 option.
Brings to mind a guy here in the US that's LS-swapping his E30 over LS1tech; very cool project.
