Nov 21, 2016 18:22:03 GMT
Keep at it... we all have periods of low mojo with cars we're working on when things feel nearly there then seem a million miles away. Got the same with my Datsun at the moment, so trying to keep things small and achievable. These are such lovely cars, I really want one! thanks for this
fulvia series 1 1200. rolling restoration fulvia series 1 1300. definitely in bits golf Mk4 v6 4motion. weekend fun T4 transporter. daily
Nov 21, 2016 18:26:34 GMT
Enjoying this thread. Keep at it, you'll have a fantastic car. thanks guys ...yep need a bit of a lift with it all at the moment. Still could be worse, I could have nothing to cobble an engine together with. AND Ive got plenty of interesting options with what Ive got.....So onward and upward.
Nov 28, 2016 20:26:01 GMT
Finally got out the nasty self tapping screw the was in the end of the crankshaft gear oiler nozzle. Now to try to put it back together and hopefully there will be a bit more oil pressure.
2 full engine gasket kits have been ordered , one from Germany for the 1300, one from Surrey UK for the 1200. We will see which gets here first !!! The Germans say its "dispatched" and the guys up the road "processed" the race is on ...
The guys in surrey won the gasket race .....but only by a few hours. heres some of the start of engine rebuilding. New crankshaft gear oiler nozzle ordered should be here tomorrow. I'm saying as I go Clean it again, Luke, and then clean it some more......
Dec 11, 2016 18:12:47 GMT
Last Edit: Dec 14, 2016 20:26:22 GMT by lukestew
Dec 14, 2016 20:28:09 GMT
having a few troubles with images disappearing when they come off google drive but think its sorted??
Dec 17, 2016 19:55:50 GMT
Ive just been watching youtube about engine building because I thought the crank was a bit tight. I should be able to turn the crank easily by hand shouldn't I?? Think I definitely need to clean those bearings off again. Got to be clean clean clean. A bit of lube too. Whats the point in doing it if its not done as well as I can, right?
Dec 18, 2016 18:03:11 GMT
heres why the crank was tight. The thrust bearing on one side has a big scratch down it. It must have moved and got pinched when I put it in. Another is now fitted and the crank moves smoothly by hand now. The fulvia thrust bearings are a bit fiddley to fit and I found that a bit of assembly lube holds them in nicely to the cap while the crank goes in. Need less to say they are really clean now and third time assembled they feel nice and smooth when I turn the crank by hand. So torque wrenched up and so now to get the block installed onto the case. Shall I use the pistons and block that are from the seized engine and just need rings and a good clean up.... or get the block bored out to fit the biggest size overbore pistons Ive got from the original engine...or shall I use the slightly bigger block and pistons from the 1300 that I hope to get from another lancia guy in a little while.... or shall I splash out for the (supidly expensive) 80mm high compression pistons from italy and have the block bored to fit to make a race engine? Easy and get it done or bigger and a whole load of work but more grunt??
Dec 24, 2016 13:26:23 GMT
whats happening this Xmas eve.... well I'm putting fulvia engine bits in the dishwasher of course... Before one of my customers old dishwasher goes to the dump Ive set it up in the garden to dishwash some bits of engine. Pistons at the top where the glasses and mugs go, crank case and rocker covers at the bottom on a 70 degree intensive cycle also added some soda crystals to help de-grease. hopefully that will work???
Last Edit: Dec 24, 2016 13:29:37 GMT by lukestew
Dec 24, 2016 16:46:40 GMT
yeah it works although i've noticed you end up with deep water horizon spec oil sludge around the filter basket
Dec 24, 2016 18:20:34 GMT
Interested to see how well this dishwasher works :-)
I've kept our old dishwasher that has a small water leak, for the very same reason.
I tried it with mine. Didn't go down very well!
Dec 25, 2016 16:02:16 GMT
Get it going, then build another engine later.
Dec 30, 2016 13:32:07 GMT
Get it going, then build another engine later. Yep you're right. I need to get the spare block machined to fit the good set of pistons and get it together and then vavoom
Dec 30, 2016 14:53:20 GMT
My engine was tired so I bought a spare to rebuild. I didn't want the Fulvia to inoperable that long, it's just too much fun to drive. A straight swap can be done in a weekend.
Didnt even know there was aluminium towers in the suspension there was so much crud all over it.
Last Edit: Feb 5, 2017 20:19:14 GMT by lukestew
