Dec 18, 2016 23:13:50 GMT
Mounted fuel and air pump system and fuel tank. Both are mounted on anti-vibration bushes. You are probably asking why I made 3 fuel tank brackets? Well, the right hand one was easy to measure but the other side wasn't so I made a rough one blind which allowed me to see where it was too long/short and then make one that fits. This worked fine. However, when it came to rounding off the edges and lightening I picked up the test bracket by mistake! Before everything is fitted permanently, I will be tidying up the boot and giving it a light coating of matt black paint.
Last Edit: Dec 18, 2016 23:18:02 GMT by nalesutol
Dec 19, 2016 13:20:26 GMT
What's the air pump for? You could have lightened the fuel tank by drilling lots of holes in it
mk2cossie
Club RR Member Number: 77
Dec 19, 2016 13:25:27 GMT
What's the air pump for? You could have lightened the fuel tank by drilling lots of holes in it I was going to say does the tank not need something a bit more secure to locate it with fuel sloshing around inside it...but that's either not a very big tank or a massive swirl pot in the boot
Dec 19, 2016 15:44:29 GMT
Martin from MJS Fabrications came over and finished off the parts of the roll cage that we couldn't get to originally due to the floor and sills being in the way. Also added a bar between the rear uprights, stiffening wedges in the top wishbones to compensate for the sections I took out to clear the damper pushrods and the driver's seat bracket supports. I can now crack on as the floors, which were holding up the installation of the dash and rear panels, can be installed.
Dec 19, 2016 18:46:21 GMT
What's the air pump for? You could have lightened the fuel tank by drilling lots of holes in it I was going to say does the tank not need something a bit more secure to locate it with fuel sloshing around inside it...but that's either not a very big tank or a massive swirl pot in the boot 11 litre tank and 1.5 litre swirl pot. No sloshing as tank is foam filled. Sideways movement is restricted by filler, return and feed pipes. However, once bolted down I will assess whether additional support is required.
Last Edit: Dec 19, 2016 18:51:55 GMT by nalesutol
Dec 19, 2016 18:48:45 GMT
What's the air pump for? You could have lightened the fuel tank by drilling lots of holes in it Pneumatic gear change, throttle blip and parachute release. I will drill some holes in the flanges :-)
Now there is a phrase that I am pretty sure most of will never use!
Dec 21, 2016 22:19:57 GMT
Gluing in passenger floor.
Dec 21, 2016 22:20:59 GMT
Roll cage has certainly stiffened up the chassis. One arm of the lift isn't doing anything :-)
Dec 22, 2016 17:35:26 GMT
Gluing in driver's floor. You may notice that I have only drilled holes in the passenger steet bracket supports. This removed 70gms, or 10% of their weight. They don't form part of the structural integrity of the roll cage, but are acting as seat bracket supports as well as additional support for the floor (they are glued to it) I had the driver's bracket supports welded in before I decided to drill holes. As they are not glued to the floor I will probably leave them as is.
Dec 22, 2016 19:15:01 GMT
Still quite a large hole to fill :-)
Dec 24, 2016 17:51:33 GMT
Last Edit: Dec 24, 2016 17:53:00 GMT by nalesutol
Dec 25, 2016 11:40:57 GMT
Tyres...bloody tyres, still trying to work out the best combination. I thought I had finally cracked it after years of searching with the Michelin TB5s. However, the size options for 15" rims are restricted and the smallest size for the front is a little high on the aspect ratio (50) than I would like, the 225mm width option is only 5mm smaller in diameter than the 285 rears I planned to use. Pirelli do a P7 Corsa Classic in 305/35 and 235/45 with diameters within 1mm so similar difference but they come in three softness grades. What I can't find out are the Mu values so I can compare 'stickiness'. One of my main tasks at the NEC in January is to discuss this problem with both Pirelli and Michelin to see if I can resolve my (potentially expensive) dilemma as the tyre size dictates wheel width as this has to match the footprint width in order to wring out the maximum grip.
Dec 26, 2016 22:22:29 GMT
Seats fitted. Driver's is very rigid. Passenger seat (the one I made out of 2 layers of carbon fibre) is a tad floppier :-) The bum part is pretty good but the back section could do with a little support, which I will sort out. However, I won't be siting in it much so no rush :-)
Dec 26, 2016 22:25:20 GMT
Vroom Vroom! :-)
Dec 27, 2016 13:05:22 GMT
Fitting rear wing struts: Home made carbon angle for fitting centre console fixings to: Plenty of consumables for next year :-) :
v8
Dec 27, 2016 14:07:51 GMT
Looking good Shame a Millington Diamond block is so damn expensive ! Would save a lot of weight ....
Dec 27, 2016 18:34:30 GMT
Are those wooden rear wing support struts a bit high? Are they balsa wood for lightness too?? Seriously... all the best for 2017.
Last Edit: Dec 27, 2016 18:35:49 GMT by flyingphil
Dec 27, 2016 23:27:25 GMT
Are those wooden rear wing support struts a bit high? Are they balsa wood for lightness too?? Seriously... all the best for 2017. I needed to get the wing into clear air for it to work properly. Thanks, you too.
Looking good Shame a Millington Diamond block is so damn expensive ! Would save a lot of weight .... There are a few aluminium blocks about, but they are expensive and save 'only' around 22Kg. However, at around £4500 - £6500 plus cost of engine rebuild, this can wait until my existing engine needs attention or more power :-)
Last Edit: Dec 28, 2016 10:24:57 GMT by nalesutol
