Jul 19, 2016 17:56:27 GMT
Some tasks seem to take for ever. Removable section of rear panel needed to be extended so that it overlaps the fixed section. Mind you, this is the one time when fibreglass beats carbon. From cutting the corex support to peeling it off - less than one hour Whilst waiting for FG to set I dry fitted other panels, coming along.
Last Edit: Jul 19, 2016 18:09:51 GMT by nalesutol
Jul 21, 2016 19:04:02 GMT
Three sections of the rear interior panel finally as good as they are going to get prior to fitting. Weight 1.4Kg Used the new centre console as the former for the mould for the console extension that will be fitted to the removable part of the rear panel, if that makes any sense :-)
Last Edit: Jul 21, 2016 20:06:11 GMT by nalesutol
Last Edit: Aug 3, 2016 22:19:12 GMT by nalesutol
4th - Removed bagging materials and released carbon fibre from mould. The finish is as I expected. It is not the glossy finish you expect to see when watching YouTube videos because to achieve the glossy finish straight out of the mould you need a glossy mould (which I haven't got) and a gel coat prior to laying up the carbon (which I don't do). Even if you do all the proper preparation post cure fettling is often still required, be it repairing pin holes, flow coating a glossy layer on or polishing. As I am painting all my carbon matt black a glossy finish isn't required. That's my excuse, anyway, and I am sticking to it :-) Look closely as the last photo and you will see the yellow wax used to form the internal radii. As it stands (with wax scraped off) it weighs in at 598gms. It still needs to be trimmed to size, sanded, filled and painted, but it should stay around that figure.
Last Edit: Aug 4, 2016 15:09:57 GMT by nalesutol
Aug 15, 2016 14:34:49 GMT
Last Edit: Aug 15, 2016 14:35:57 GMT by nalesutol
Aug 15, 2016 17:48:27 GMT
As ever - great work, and an author too.... So how do we, mere mortals, buy a copy???
Aug 15, 2016 18:04:40 GMT
As ever - great work, and an author too.... So how do we, mere mortals, buy a copy??? Thanks, buy why on earth would you want a copy? This was done by simply unearthing old photos, adding memories (hopefully reasonably accurate) and sending off to Vistaprint. 10 days later it arrives, the only copy :-)
Aug 15, 2016 19:15:59 GMT
I quite enjoyed reading the page you put up
fer4l
Testing
Club RR Member Number: 73
Aug 15, 2016 21:41:26 GMT
Looks really great! I'd have a copy Cheers Matt
Davenger
It's only metal
Club RR Member Number: 140
Aug 15, 2016 22:11:31 GMT
As ever - great work, and an author too.... So how do we, mere mortals, buy a copy??? Thanks, buy why on earth would you want a copy? This was done by simply unearthing old photos, adding memories (hopefully reasonably accurate) and sending off to Vistaprint. 10 days later it arrives, the only copy :-) Because what you're doing is brilliant and fascinating.
Aug 15, 2016 23:05:33 GMT
This car is looking to become amazing. So much great engineering. You seem to be a CF wizard, so what sort of figure would it cost me to make a carbon bonnet at home for an old mini, including consumables? Excluding costs of a vacuum pumpsince I've got that. Best of luck Leo
Darkspeed
Club RR Member Number: 39
Aug 16, 2016 14:07:35 GMT
I will have to have a closer look at the Vistaprint photo books - the medium size seems nice idea and pretty sure that an average sized restoration thread could be quite easily stretch to a 120 page book covering the restoration of a model with key information for a car club. £12! I think my Stratos restoration looks like it would run to a series of volumes though May have to also come up with a Pen name though. Andrea Ferraio sounds a good version Thanks for sharing that.
Aug 16, 2016 14:21:15 GMT
I will have to have a closer look at the Vistaprint photo books - the medium size seems nice idea and pretty sure that an average sized restoration thread could be quite easily stretch to a 120 page book covering the restoration of a model with key information for a car club. £12! I think my Stratos restoration looks like it would run to a series of volumes though May have to also come up with a Pen name though. Andrea Ferraio sounds a good version Thanks for sharing that. No problem. They do a fair number of book sizes from 130mm x 100mm to 390mm x 290mm. Min page number is 24 but not sure of max. As this book covers the period up to breaking the car in 1985 I only had enough info to fill the minimum number of pages. The size I chose was 280mm x 210mm and cost £34, including front cover photo, glossy paper and shipping. I had no problem with this volume, but the next one will be more difficult. As it will cover the build documented on here I will have too much info and too many images so a lot of culling will be required.
Aug 16, 2016 14:24:38 GMT
Thanks, buy why on earth would you want a copy? This was done by simply unearthing old photos, adding memories (hopefully reasonably accurate) and sending off to Vistaprint. 10 days later it arrives, the only copy :-) Because what you're doing is brilliant and fascinating. Gee, thanks. I am gobsmacked the people are interested in this book as I only did it for fun and to bring all of the info and photos together. The cost of the book is £34 (see posting above for breakdown) so not worth buying just to look at. If anyone is interested I can photograph the rest of the pages and post on here.
Aug 16, 2016 15:27:42 GMT
. If anyone is interested I can photograph the rest of the pages and post on here.[/quote]
That's a "Yes please" from me!
Aug 16, 2016 16:51:16 GMT
This car is looking to become amazing. So much great engineering. You seem to be a CF wizard, so what sort of figure would it cost me to make a carbon bonnet at home for an old mini, including consumables? Excluding costs of a vacuum pumpsince I've got that. Best of luck Leo Right, where is my piece of string so I can measure its length? :-) Assuming bonnet is 1 square metre. Carbon fibre £30-35/m2. So four layers, giving a bonnet thickness of around 1mm = £120-140 Release film £16.50 Perforated film £4.80 Breather cloth £9.00 Vacuum bag £14.88 Vacuum bag sealing tape £5.99 Release agent £6.80 Resin £20.10. This assumes that you can get away with 1kg Brushes £7.08 Vacuum pipe £7.14 Through bag connector £19.80 Vacuum valve £3.60 Barbed connector £1.80 £230-250. However, this is just for the finished bonnet. If you make a mould you will have to add fibreglass mat, resin and a lot of work. If making more than one item, the cost comes down quite a lot as there will be some consumables left and the hardware is reusable.
Aug 16, 2016 18:17:06 GMT
. If anyone is interested I can photograph the rest of the pages and post on here. That's a "Yes please" from me! [/quote] And me
Darkspeed
Aug 16, 2016 18:56:45 GMT
Everybody loves a back story -
fer4l
Testing
Aug 16, 2016 20:49:39 GMT
. If anyone is interested I can photograph the rest of the pages and post on here. That's a "Yes please" from me! And me [/quote] And me please
ndg
That's a "Yes please" from me! And me And me please [/quote] If you download the app 'Office Lens' to your phone it will flatten any photos out as far as possible
