After todays´antics the estate is definately looking a bit worse for wear There´s one panel i´ll be able to fix and reuse... but the rest of the rear valence and strengthening plates will need replacing... I ordered a 6x3´sheet of 1mm steel panel this morning, looks like i´d better get some grinding discs on order too
Seth
I like how you've done the measuring of the C pillar after you've started cutting both cars up Look forward to watching you work your magic on this one. Maybe we'll have to stop in in the Summer to check on progress?
Fantastic, a new Oldbus lets change something into something else thread. I've missed these. Bookmarked!
I'm in!....following.
man you are brave!
JP
eternaloptimist
That looked quite tidy before you started cutting it up! Looking forward to this.
A two door estate? Excellent! I can see it in my head but I know it'll look even better in reality
PhoenixCapri
West Midlands
Club RR Member Number: 91
Feb 10, 2016 10:26:45 GMT
Excellent, speedy progress as usual - looking forward to keeping up to speed with this.
Can totally see why you're converting the two door as well, not just the rust, but really should be easier as not messing around with door apertures.
Question is, what's going to be powering it? Or is that a secret for another day?
Feb 10, 2016 10:31:15 GMT
Question is, what's going to be powering it? Or is that a secret for another day? Thought I saw mention of a V6 somewhere?
Feb 10, 2016 15:02:01 GMT
Oldbus thread = Bookmarked.
Feb 11, 2016 18:55:09 GMT
I like how you've done the measuring of the C pillar after you've started cutting both cars up Look forward to watching you work your magic on this one. Maybe we'll have to stop in in the Summer to check on progress? Well you know what i´m like Seth, in my defence though i did compare one or two photos before i bought the cars and reckoned it´d be ok and at the end of the day it wouldn´t have been a major problem to sort out. You´re more than welcome to pop round for a brew if you´re local. I´ll get some more welding gas in just incase the Hillmann needs sorting again Fantastic, a new Oldbus lets change something into something else thread. I've missed these. Bookmarked! Nice one George, thanks mate. I'm in!....following. man you are brave! JP ...or just plain daft when it comes to rusty old bodywork That looked quite tidy before you started cutting it up! Looking forward to this. The 2 doors ok Nigel and well worth saving but the estate is BLR as we used to say in the REME (Beyond local repair) and only looks ok in bad light from about 10 foot away. A two door estate? Excellent! I can see it in my head but I know it'll look even better in reality I´d do you a photoshop Darren but with my computer skills (or lack of) i´ll be quicker doing it for real. You should get a rough idea what it´s going to look at once i swap the roofs over this weekend. Excellent, speedy progress as usual - looking forward to keeping up to speed with this. Can totally see why you're converting the two door as well, not just the rust, but really should be easier as not messing around with door apertures. Question is, what's going to be powering it? Or is that a secret for another day? Cheers mate, for a start i´ll be refitting the 1600 to get it through it´s TÜV but after that i fancy a converting it to a V6. Not the fastest of engines but they sound fantastic. Oldbus thread = Bookmarked. Always up for a rusty old Ford thread eh Time for a bit of an update. The boot floor in the estates area little bit different to the ones in the saloon. Ford used the saloon same floor panel with spare wheel well and then added a second floor on top to make it all nice and flat. So i´ve been chopping out all the estate bits so that you can´t tell the difference once i´m finished off bodging the 2 door. Once i´d cut out the rear left hand panel i found that the D post was only being held together with foam... The pics just don´t do it justice, glad i´m not trying to restore this one. Well i´ve finished chopping out all the estate goodies for the meantime... and as you might have noticed the roof is missing That´s because it´s filling up the back of the garage waiting fo me to get my finger out getting it ready for refitting to the 2 door. Whilst looking at that last photo, anyone know where i can get a new headling made? Mines definately seen better days Cheers, Dave
Last Edit: Feb 11, 2016 18:57:19 GMT by Oldbus
Feb 11, 2016 20:16:51 GMT
Ooomph, you weren't over in Ireland recently incognito on a MK2 Transit Van were you, progress is just as swift. I love these 'get stuck in' it's only metal threads. V6 2 Door Estate is going to make a few people look twice when it is done........did they or didn't they
Feb 11, 2016 20:53:24 GMT
I am playing with the idea to convert a Sierra Station wagon to a two door using the two door sedan's wider doors and B pillar - subject to availability of the latter. Will thus watch this with keen interest.
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
Feb 11, 2016 20:59:26 GMT
not sure if anyone makes the headlining but I believe the material was the same as used on Escorts of the period and is widely available, any trimmer should be able to make a new one with your old one as a pattern.
Mike
Feb 11, 2016 21:36:49 GMT
I like how you've done the measuring of the C pillar after you've started cutting both cars up Look forward to watching you work your magic on this one. Maybe we'll have to stop in in the Summer to check on progress? Well you know what i´m like Seth, in my defence though i did compare one or two photos before i bought the cars and reckoned it´d be ok and at the end of the day it wouldn´t have been a major problem to sort out. You´re more than welcome to pop round for a brew if you´re local. I´ll get some more welding gas in just incase the Hillmann needs sorting again Fantastic, a new Oldbus lets change something into something else thread. I've missed these. Bookmarked! Nice one George, thanks mate. I'm in!....following. man you are brave! JP ...or just plain daft when it comes to rusty old bodywork That looked quite tidy before you started cutting it up! Looking forward to this. The 2 doors ok Nigel and well worth saving but the estate is BLR as we used to say in the REME (Beyond local repair) and only looks ok in bad light from about 10 foot away. A two door estate? Excellent! I can see it in my head but I know it'll look even better in reality I´d do you a photoshop Darren but with my computer skills (or lack of) i´ll be quicker doing it for real. You should get a rough idea what it´s going to look at once i swap the roofs over this weekend. Excellent, speedy progress as usual - looking forward to keeping up to speed with this. Can totally see why you're converting the two door as well, not just the rust, but really should be easier as not messing around with door apertures. Question is, what's going to be powering it? Or is that a secret for another day? Cheers mate, for a start i´ll be refitting the 1600 to get it through it´s TÜV but after that i fancy a converting it to a V6. Not the fastest of engines but they sound fantastic. Oldbus thread = Bookmarked. Always up for a rusty old Ford thread eh Time for a bit of an update. The boot floor in the estates area little bit different to the ones in the saloon. Ford used the saloon same floor panel with spare wheel well and then added a second floor on top to make it all nice and flat. So i´ve been chopping out all the estate bits so that you can´t tell the difference once i´m finished off bodging the 2 door. Once i´d cut out the rear left hand panel i found that the D post was only being held together with foam... The pics just don´t do it justice, glad i´m not trying to restore this one. Well i´ve finished chopping out all the estate goodies for the meantime... and as you might have noticed the roof is missing That´s because it´s filling up the back of the garage waiting fo me to get my finger out getting it ready for refitting to the 2 door. Whilst looking at that last photo, anyone know where i can get a new headling made? Mines definately seen better days Cheers, Dave Hey Dave!! you made it ...........
Mike
Feb 11, 2016 21:38:30 GMT
Ich bin fassungslos :-)
conair
Feb 11, 2016 22:12:41 GMT
Awesomeness
Feb 12, 2016 14:15:16 GMT
wowzers...great progress....this is so cool!
JP
BLU
Feb 12, 2016 16:39:12 GMT
Oh yeah, this is the sort of project I love Can't wait to see the finished article!
The future's bright, the future's BLU
Silver 1987 MK2 Fiesta Ghia White 2006 MK6 Fiesta ST150 Yellow 2007 MK6 Fiesta Zetec S Anniversary #279 Green 2007 MK6 Fiesta Zetec S Celebration #471 (diesel conversion) Red 2008 MK6 Fiesta Zetec S Anniversary #893
Feb 12, 2016 17:21:35 GMT
Although I'm sad the 2dr is dying, this is going to be absolutely awesome! Very cool
Feb 12, 2016 19:40:37 GMT
Thanks for all the kind comments. I´ve been busy in the garage today but i´m a bit pushed for time so i´ll have to update the thread tomorrow. In the meantime i´ll just leave this here......
Last Edit: Feb 12, 2016 19:41:54 GMT by Oldbus
