Jan 29, 2016 11:56:55 GMT
agree, plus theres no load on the engine.
if you are getting through the static test by the skin of your teeth, probably gonna get nabbed on the driveby
longman
Club RR Member Number: 3
Jan 31, 2016 14:43:42 GMT
agree, plus theres no load on the engine. if you are getting through the static test by the skin of your teeth, probably gonna get nabbed on the driveby Not so sure about that , I've recently done a 101db day at Bedford , mine measured 103db but they let me on and told me to look out for the noise meters , I lifted at all of them in the morning and went full bore all afternoon , not a peep from the meters , they are pretty hot at Bedford for noise as well..
Last Edit: Jan 31, 2016 14:44:02 GMT by longman
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
Thanks for all the comments and ideas.
I have created my own "db killer" and managed to get the sound level down to 96db (from 105db!). No pictures I'm afraid, but it was a curved pipe which fits in the back of the tail pipe with a perforated pipe inside stuffed with wire wool. The car is noticeably quieter but doesn't seem to have lost any power, although I can now hear it pinking slightly - I don't know whether this is just 'cos I couldn't hear it over the exhaust or something caused by greater back pressure.
I'm going to go down to Goodwood to get the sound level tested - as I don't want to find my sound level meter is inaccurate when I get to the track day!
cheers Cortinaman
Old Fords never die they just go sideways
Is there any official moto-x practise tracks near you, some of them will have a Db meter, especially if they are anywhere near residential properties, they should be give you a measurement for the price of a drink...
sonus
Are you sure you measured the noise with the correct dB-scale weighting? There is A B c and D scale - en.wikipedia.org/wiki/A-weighting I don't know what weighting the track uses, but as you can see low frequency noise has quite a marked difference in the different scales
Thanks for all the info and ideas folks. I'm popping down to Goodwood on Friday to get them to check the noise level - that way I know its being checked by the same meter and same people who will do it on the day - so no chance of issues due to different equipment, db weighting etc.
Wish me luck!
Cortinaman
Well, I went down to Goodwood on Friday - and a very nice Lady called Judy checked the noise level on the Cortina and.......it passed!
It was apparently not even hitting 90dB, and that was without me fitting my super noise reducing tail pipe! I guess the Maplin cheapy noise level meter was not that accurate!
So all is well!
Thanks for all the help along the way folks!
Cortinaman
Feb 10, 2016 21:43:57 GMT
arent some people these day making the tip of the exhaust point to the floor in the hope it absorbs some noise?
gil
Kinda New
Feb 14, 2016 17:32:01 GMT
You've solved things but for the record if someone ever needs noise reduction somewhere, I've seen a lot of these SuperTrapp baffles at race tracks in NA. Easy to add on & remove when needed. ![](http://www.supertrapp.com/images/product_sections/27.jpg)
Gil Fiat & Abarth kinda guy Province of Canada
Feb 14, 2016 17:57:08 GMT
Supertrap is a guaranteed way of reducing noise , used one on a bloody AC Cobra to get it low enough for goodwood , nothing else worked [ short wheel base to fit silencer in ].
As a note, you can get a Db meter app for your phone instead of buying a meter.
alex
Feb 15, 2016 21:43:42 GMT
Are those DB meter apps roughly accurate? I'd be interested to see what levels my Rover is at.
1974 Rover P6 4.6V8. Land Rover Series 2A 2.25 "overland spec". RRC V8. Celica GT4 ST205 Garrett 3071R 366BHP.
sb
Feb 15, 2016 21:56:29 GMT
Are those DB meter apps roughly accurate? I'd be interested to see what levels my Rover is at. Depends on your phone. I know mine wont go higher than 77db
alex
Feb 15, 2016 22:44:49 GMT
Oh.
Feb 16, 2016 21:08:44 GMT
I have seen someone at work using one over 100Db
