Jan 18, 2016 13:15:41 GMT
Boring bulb time! The switch panel bulbs (and some others) on the 940's are a Volvo specific one which you can't buy anywhere easily.... I've found them on the net at a couple of places but at £10 each minimum plus postage (I need 3!) is mental! The bulb at the top is complete, I took one apart which is the middle and bottom one. I went to an auto electricians and they said they could cut the wire and solder in a new bulb for £5 each. However I thought "if they could do it....".... A normal LED bulb would be best to use as they won't burn out BUT they are 2.4v ish. After a Google search I found that Maplin do a 12v LED, which has the required voltage limiter inside it already, which means I won't have to solder a resistor in as well as the bulb into a very tight spot. As the LED's are only 79p each I'm off to buy some and try it myself - what could possibly go wrong?
The Millenium Volcon"Get yourself a Volvo if that's what you really want, you might be dead next year. In the meantime, you could be going sideways in a gigantic land barge."
Jan 21, 2016 20:40:22 GMT
Got some V70 windscreen wash nozzles which are miles better than the rubbish standard ones which weren't working properly anyway.
Sorted the rear washer which after starting from the front of the car and working back I found that it was the rear nozzle which was blocked. Should have started from the back!!
Tightened alternator belt which was slack, a car mad friend of mine gave me a hand with that as I didn't know how tight to go.
Jan 26, 2016 13:16:23 GMT
The next stage in finding the water leak was to look under the scuttle. Here is what you see when the panel is removed..... The plastic panel to the left of the pic has been moved out of the way. Water goes into the scuttle panel and drains out the side around the heater fan inlet which has a "funnel" on it to divert the water around it. If any water comes through the windscreen rubber seal with the scuttle (or elsewhere maybe) then the plastic panel stops the water going directly into this heater fan: The problem was that the seal the plastic panel had with the bottom of the windscreen surround had failed along 50% of its length. So I am hoping that now I have resealed with windscreen sealer (horrible stuff, wish I hadn't got it on my fingers!) the water ingress will have stopped. here is a wider shot of the area under the scuttle:
So hopefully that is sorted - was a bit awkward getting the scuttle on and off but did it in the end. I then realised when it was all together again that I had forgotten to stick down the metal mesh bit you can see in the pics so it will all have to come off again - doh!
steveg
Jan 26, 2016 14:18:53 GMT
Glad to hear you have found what could be the cause of your leak. I had mine apart years go now and I didn't take any pictures. Pretty much forgotten what it all looks like under there now !
I have soldered some new bulbs into the holders but it's a bit of a challenge. Next time I just bought some new ones from Volvo but if you can get the LED's to work you won't have to ever do them again.
The washer jets didn't seem great on mine. My solution was to remove the headlamp washers and wipers so all the squirt from the pump went to the windscreen. Lost of faffing about involved and it leaves a hole in the panel below the headlamp. You can get genuine blanking covers to fill them up though.
Last Edit: Jan 26, 2016 14:24:16 GMT by steveg
Front end looks a lot better now with clear indicators (we're on 940 celebrations of the same year) with Osram night breaker bulbs and all new other bulbs - old ones were a bit dim and these new ones are way brighter and the front end looks a lot better now. Still need to get the new number plates on - can't stand Euro ones myself.
I still haven't found the leak 100% yet. Seems to leak a bit then nothing for ages.
sridgett
the only way is Dagenham
Lovley car you have there sir! Allways loved these. What are your plans for it?
Mk3 capri, escort xr3i, mk2 fiesta,mk5 escort rs2000
Feb 16, 2016 14:55:33 GMT
Keep it standard really but make sure everything is running 100%. A friend did a photoshop of what the grille would look like painted. That is what the earlier models and the 740's grilles look like. There's too much chrome in it as standard I think - there's no chrome on the rest of the car so it looks out of place.
Feb 16, 2016 16:17:31 GMT
Definitely paint it...
Feb 16, 2016 17:55:22 GMT
I think I will!
sridgett
Feb 16, 2016 17:57:14 GMT
Very cool that grill
I have a company car for work purposes so I don't need this car as a daily. However I was very tempted to use it this morning as it was looking mean and moody frosted up!
Instrument panel bulbs. Two of these had blown and from taking apart the glovebox and cigarette lighter I found 2 more of a similar design. The problem with these bulbs is that they are a special Volvo one which cost £10 each. You can swap the connectors for 740 items but when was the last time you saw a 740 in a breakers yard? I had seen someone who got some standard LEDS and soldered them in with a resistor to step down the voltage. I thought that was a bit fiddly so I had a search and found some 12v LEDS from Maplin which could solder straight in. This is one of them. I pulled the original bulb out and tried to fit the LED in but the holes for the wires weren't big enough. Using my dremel I made the holes bigger - doesn't look pretty but it worked. After soldering a LED in (this is a different one to above): It was a bit messy so I used the sanding disc on the dremel to smooth everything over. I hadn't done any soldering since school (loved it) so was chuffed when all the bulbs worked first time. You can see in the pic above the connector which acts as a "light tunnel" to light up 2 switches with one bulb. Switch panel now lit up! Next job was the steering wheel. It was rather polished and shiny and a bit sketchy to use as it was so slippery. Read a few online guides and started off. Got some cheap tea towels which I soaked in hot water and Meguairs all purpose cleaner. I then wrapped these around the steering wheel to draw the dirt out and open up the leather grain. Also gave it a scrub after the towels had been on a few minutes. Steering wheel did look like this before I gave the wheel a thorough rubbing with the tea towels - A decent amount of dirt did come out as can be seen on the cloths. Afterwards - not much more grippy but better. Looks miles better now though. Next job was the airbox. I have read you can open it up underneath by drilling holes to let more air in. I had also read that there is a cold air inlet that comes in from the drivers wing which you can connect up through a blocked hole in the airbox. Removed the top of the airbox and the filter and saw this The lump is supposedly where you can plumb the new better fresh air inlet into. I thought I would have to buy some hose and cobble something together but when I removed the air box I found this on the side of it: Why on earth was this blocked up inside the air box? (Incidentally the current air inlet was a small one in the front which I haven't pictures but gets its air from inside the engine bay) Even more so when you look at the inner wing and see this: Already plumbed up to extract air from the inner wing area (I checked and there is a vent into it). So I did this Bolted it all back together and yay! Makes a slight whooshing noise but not loud, hopefully this helps the engine breath a bit better. I have read that cone filters don't really do anything with these engines and this solution is as good if not better. While the air box was out I saw this bit of rust. I think it's just surface rust but I have no experience of dealing with rust. What's the best option? Use a wire brush to get rid of it then treat with Kurust and a spray of some stone chip?
foeux
Mar 27, 2016 20:50:52 GMT
Lots of nice info here but I will be trying your steering wheel technique tomorrow...
Thanks,
F
Mar 27, 2016 21:30:26 GMT
I'm watching this as I'm very tempted to get one of these myself n yours looks great
Mar 27, 2016 21:59:14 GMT
Lots of nice info here but I will be trying your steering wheel technique tomorrow... Thanks, F Thanks. It definitely did work a fair bit but I might do it again to see if I can improve it a bit more.
Mar 27, 2016 22:01:26 GMT
I'm watching this as I'm very tempted to get one of these myself n yours looks great Thanks. It's not perfect, there's a few minor dings and a couple of very small rust spots under the paint - tailgate and back of wheelarch but it's only very minor. This car had £10k spent on it in the 5 years before I had it so it's a great base to start from. I'd say wait for a cherished one, they are around, and get a later one as the engines and gear boxes are the best.
Mar 27, 2016 22:01:56 GMT
More jobs done this weekend.... When I replaced the window guides I forgot to reseal all the window gaskets. So I did this properly today - I can get those door cards off in seconds now! Annoyingly I did too good a job and the central locking didn't work on the rear doors so I had to take it all off again and adjust my taping around the lock buttons. I had a good clean of the engine bay with Gunk (which didn't work as well as I had hoped) and Meguiars MPC. Certainly not perfect but a fair bit better. Next was the grille. I originally wanted an egg crate as most people do but they aren't cheap. So after a good clean I used some Matt PlastiKote paint (used it a lot on bikes) to paint the inner section of my grill black. This is similar to early 740's and I really am pleased with how it looks. Masking then Paint (in the street!) At the same time I wanted to remove the headlamp washers and wipers. They really are a pain and although my motors work they never seem to sit right. Wasn't that difficult but the front end looks a lot better now. I think the windscreen washers are a bit more powerful as all the fluid goes to them now. All removed so the end result for the front end is below.... Before: After: I also think I've fixed the water leak into the passenger side with a new door seal so I put the carpets and sound deadening in. Changed the air filter too but didn't manage any more jobs. This is what is on the list to do, pretty much in this order. Camber mod Re centre number plates Remove tow bar (tried but couldn't shift rusted bolts - NEED 6 SIDED SOCKET OR POWER) Take off mudguards and clean underneath thoroughly. NEED TO CUT OFF REAR BOLTS Fit new ARB bushings Fit new droplinks Sort out black plastics on bumpers and mudguards Oil and filter change Change spark plugs Change dizzy cap and rotor Change HT leads Add MBC Clean and treat and rust in engine bay Clean interior thoroughly Sort out scratches on paintwork Full valet, machine polish, wax including all shuts etc Change shocks and springs Remove dents from body work Sand back, treat and repaint rust on wheelarch Sort out paint on tail gate So much to do on my own, could really do with some help with some of the above, especially the suspension. I'll battle through though!
Busy days over the weekend! First of all I managed to get all the carpet off the door card inserts. That was not fun. I then covered them in 3mm scrim foam using permanent carpet adhesive. This is the leather I bought to do the job. Half way through... I didn't have time to stick the leather on but I tried the colour in the car and...... oh dear. It's looks awful. There's a brown tinge to the leather which really looks out of place against the plain grey and black. I'm going to have to reconsider what I'm going to cover the panels with. Next job - Stage 0 tune up. I've already put in a new air filter and here I put in a new dizzy cap, rotor arm, dizzy seals and ignition leads. I think the leads are the original ones so due for replacing. The dizzy cap had a bit of oil in it but not too bad. The rotor arm was past it though. Fitting wasn't the complete nightmare I expected it to be. You HAVE to have a ratchet 8mm spanner though, I honestly don't think you could do the job without one. Old and new. Cleaning up. Back of the engine. All the parts used were genuine Volvo parts or the best I could buy if they aren't. I also put the new leads on - the ones I took off were Volvo marked Bourgicord ones. A quick drive and I thought it felt a lot smoother, not done the plugs yet as the NGK ones I ordered haven't arrived yet. The Volvo ones I bought I have been advised aren't that great so I'm keeping those as spares. I then took it down to the hand car wash, then renewed the black plastic bits with linseed oil and tyre shined it up and I think it looks pretty good! The pictures are very flattering though. The paint has loads of scratches and dings and poorly touched up bits and swirls like you wouldn't believe!! There's a couple of bits of rust which I plan to sort out, needs a machine polish and some attention to the scratches and dents to make it perfect. Last job was to replace the ARB bushings. That was done, as all my jobs are, on the side of the road this time in the dark! Anyway removing the old ones revealed how cack they were. The knocking has gone from the front end, and with the camber mod which I have done makes the car sound and handle miles better and I haven't even fitted the new shocks and springs yet. Next jobs are the oil change and plugs.
Apr 17, 2016 11:01:37 GMT
This was a job which I wasn't looking forward to but it had to be done - the towbar is a particularly ugly thing on this car. My modern car has a hideaway one but this one sticks out like a sore thumb, even though the previous owner has removed the actual towball as they kept banging their shins on it. The bits you could see were the electric sockets and rusty bits of metal sticking out. To be fair it is a proper genuine Volvo towbar which cost a fortune when it was installed, so I'll keep it for the next owner. It will need paint though. The bolts were mega rusted up. I thought they were 18mm but I couldn't budge them with a 18" breaker bar so I took the car to my friend at the local marina. Gareth helped me out as he is a great engineer and he soon figured it was actually a 17mm size. We managed to loosen them with my breaker bar with an extension but there was 2 further 10mm hex head bolts which we couldn't shift with a regular long Allen key. So off to Halfords to buy a 10mm 1/2" socket driver. In Halfords car park I eventually managed to get the 10mm hex bolts loose and drop the whole thing off after cutting the wires (I had to!). Looks a lot better now!!! Next job was to replace the spark plugs. I bought some Volvo ones but was recommended NGK ones as much better and at £7 for a set was pretty cheap. Old plugs all looked like this.... pretty happy with that!!
