Remembered the camera this time so on with the valve assembly. Before I put the valves in I want to scrape off the debris that forms on them. It's a kind of carbon build up but there was quite a lot on some of the valves. I used the Dremel at first but it didn't cut through it so moved onto a blunt chisel that got through the scale but didn't cut the valve:
The adjustment for the tappet is here on the top. This is shown with the cam lobe up, when it's down this is all down the hole:
Getting the new spring in is a bit awkward. They are longer than the originals and a lot stiffer so I reckon the stock springs could be forced in by hand. Not these. With the valve up I hooked the end of the spring over the bottom of the stem and over the valve guide. The spring holds that in place too:
Then I get the cup on the bottom of the spring compressor round the bottom of the spring and with all my strength yank the spring up into place. This is a sitting on the floor job with the engine clamped between your legs and your arms round it:
Then to get the spring cup on the bottom of the valve it's a matter of jam the compressor between two bottom coils and compress the spring as normal so I can slot the cup in
I tried loads of ways to try and do the valve clearances. The problem is in the valve closed position the securing nut on the adjuster is buried down the tappet bore. The other problem is the nuts are very thin and all my spanners were too thick to get in there. The only way I could see round this was to modify a couple of spanners. Got the grinder out and minimised them a bit.
Before:
After:
This was better but to tighten them up full the valve needs to be in the open position and then the hole through the tappet is out of reach so I can't stop it turning in the bore. After much head scratching the only way round this I could think of was to set all the tappets with zero gap, then take all the valves back out so I can measure the length and subtract the gap. Then it's a matter of tightening it up at the adjusted length outside of the engine then re-assembling. I did one of them but it was getting late and a valve spring pinged down onto my thumbnail so I called it a night before I got too hurt.
Before:
After:
