Kieran
More front subframe preparation. Now fully stripped ready for etch primer and satin black top coat. Got creative with the CAD and tin snips Ready to box the flimsy top wishbones Just tacked on for now, I'll run round with the Tig to pool everything together nice and neat, avoiding distortion. Next job was to file the top wishbone mounts in my order to gain a little negative camber to help turn in Bottom modded, top standard. As standard hex head bolts are used, but by using cap heads and filing the slots, you can bring everything in a couple of mm gain a degree or so of camber. Every little helps!
Last Edit: Feb 3, 2016 0:29:16 GMT by Kieran
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Kieran
In other news, I Picked up a 160 VVC cylinder head.
The 1.4, 1.6 and 1.8 cooking K series all use the same head.
The VVC models use a better ported head with bigger valves (31.5/26 compared to 27.5/24) but use a split inlet cam with an hydraulic eccentric adjuster that varies cam duration from 220 degrees to 295.
You can get a VHPD head that has fixed cams but VVC sized valves, but they are very rare.
If you watch videos on how it works, it is amazingly clever, much more so than vtec.
The problem is I want to run bike Carbs and Megajolt. It is possible to lock the vvc system in a fixed place, but where is the fun in that!
I'm planning to run the VVC in an 'off' or 'on' switched stage (ie normal and sport mode), but either having a manual switch, or having the Megajolt giving me a switched output at say 4000rpm.
Should be interesting, and an entertaining way of testing the transaxles strength.....
Kieran
New (to me!) seats!
Getting there mate, part by part
1974 Skoda S100 tarmac car 1998 BMW 750 daily 1994 Mitsubishi Evo2
Kieran
Had a day off today, so thought I'd have a go at trying to make some real progress on the K-oupe. Looking a little sorry for itself Starting on the inner wing bottom Tank out, hello big hole! Out with the magic sparkly stick Next, be nice to have a platform to hang the wings on Ta Daaa! Bit of under body paint to finish off A quick splash of etch primer and a dash of colour.... Tonight she sleeps.....
Last Edit: Feb 4, 2016 18:59:28 GMT by Kieran
Kieran
Delivery!
In other news, I Picked up a 160 VVC cylinder head. The 1.4, 1.6 and 1.8 cooking K series all use the same head. The VVC models use a better ported head with bigger valves (31.5/26 compared to 27.5/24) but use a split inlet cam with an hydraulic eccentric adjuster that varies cam duration from 220 degrees to 295. You can get a VHPD head that has fixed cams but VVC sized valves, but they are very rare. If you watch videos on how it works, it is amazingly clever, much more so than vtec. The problem is I want to run bike Carbs and Megajolt. It is possible to lock the vvc system in a fixed place, but where is the fun in that! I'm planning to run the VVC in an 'off' or 'on' switched stage (ie normal and sport mode), but either having a manual switch, or having the Megajolt giving me a switched output at say 4000rpm. Should be interesting, and an entertaining way of testing the transaxles strength..... Emerald ecu's have VVC control, if thats within budget. they do plug and play ecu's for elises
Kieran
Feb 25, 2016 10:01:02 GMT
Yes, I was speaking to Dave Andrews about this. I like carbs though (much to DA's dismay!), so for now we will run it manually.
Kieran
Feb 26, 2016 19:05:06 GMT
More boring welding done today Chop chop Weld weld Etch prime, paint. Repeat Tried on the kit briefly to see how much work is need. - lots! Narrow track comedy! Front requires plenty chopping to allow it to sit right Line of best fit I reckon!
Kieran
Received a new 120L5 flywheel amongst other bits from Skudman. Drilled the spacer and flywheel so that all good. JikovRon made a good point, the 8v fabia flywheel would be a good doner, it already has 6 holes that need minor slotting. There is a 4mm height difference though, and the rwd release bearing isn't directly compatible with the pressure plate fingers. Still, it's a good point. Not much weight difference either, both are around 7.2kg
Last Edit: Mar 2, 2016 6:36:15 GMT by Kieran
Kieran
Managed a little bit of Bodykit manipulation tonight. Bonnet on Wing thrown on Massive door gap...! Managed to have a play with my spray gun!
vulgalour
Club RR Member Number: 146
That door gap isn't just massive, it's all sorts of wrong. Still, with the work that's happened so far I have no doubt you'll make it right in no time. Looking forward to more updates on your progress.
That door gap isn't just massive, it's all sorts of wrong. Still, with the work that's happened so far I have no doubt you'll make it right in no time. Looking forward to more updates on your progress. If that was a Land Rover it'd be well within factory tolerances!
That door gap isn't just massive, it's all sorts of wrong. Still, with the work that's happened so far I have no doubt you'll make it right in no time. Looking forward to more updates on your progress. If that was a Land Rover it'd be well within factory tolerances! Not just within tolerance, the fitter would've been given a raise!
Kieran
Small update, been busy working on other Skodas, The Discovery and motorbikes. Front wishbones fully boxed in, welded, blasted, etch primed and sprayed in Satin black.
Kieran
Mar 14, 2016 23:27:25 GMT
Another small update (battling ill Heath at the minute...!) Lower wishbone boxed in And then etch primed and painted Lower damper mounts reinforced too
Kieran
Mar 19, 2016 18:10:32 GMT
More progress. Stuck on the rear wing and tried the engine lid. Er, needs a bit of hinge fettling! Better! Not looking too bad, lots of fettling needed! Then removed the false bulkhead from the bay, to make room for some POWAAAAH!
Last Edit: Mar 19, 2016 20:04:01 GMT by Kieran
vulgalour
That's a really smart kit, fitment issues aside. It looks like someone bothered to actually design it with the shape of the car in mind.
Hi Kieran, I appreciate this thread was last active some time ago, but if you read this, can you let me know where exactly you ordered the body kit from? I've found a couple of companies but they sell it in the region of £800, and I don't think it can be just the inflation over the last 2 yrs... Cheers, Szabi
