Nov 24, 2015 17:18:27 GMT
The clips that go around leaf springs that keep the leaves together have broken. They appear to be riveted into the leaf itself. How is it best to replace them?? The springs themselves are in good condition so no point in sending them off for refurb. Springs are off a 49 chevy pickup. Thanks for any ideas.
sowen
Club RR Member Number: 24
leaf spring rebound clipssowen
@sowen
Club Retro Rides Member 24
Nov 24, 2015 21:05:02 GMT
I re-packed a set of leaf springs and for the clamps I folded some mild steel flat bar into shape and used countersunk bolts with the heads ground flush to hold them on.
Dez
Club RR Member Number: 34
leaf spring rebound clipsDez
@dez
Club Retro Rides Member 34
Nov 24, 2015 22:41:14 GMT
As above really. They're countersunk clout rivets usually, which aren't too hard to get, or you could use a countersunk pop rivet or bolt. Drill or grind and drift the old ones out first obviously. Io think Chevy ones bend all the way round don't they? You could change to the type that just come up the sides then are drilled for a bolt over the top to make them easier to reassemble.
Last Edit: Nov 24, 2015 22:43:12 GMT by Dez
Thanks for that, and yes Dez you are correct the chevy ones go all the way round.
Thanks again.
Last Edit: Nov 25, 2015 6:53:29 GMT by Deleted
