Ryannn
Evening all, quick question.
I have 2 HIF44 carbs in front of me, of different ages. The first has 3 pipes on it, fuel inlet, crank breather inlet and fuel/vapour outlet, this runs under the wing to the carbon canister.
The 2nd carb is older, has the fuel inlet and the gas inlet, but nothing else. Is this normal? I'm worried that petrol will explode from it if something goes wrong! Lolll
Gas inlet, gas from where?
Fuel inlet and overflow/ vent.
Last Edit: Nov 10, 2015 0:53:19 GMT by Deleted
Ryannn
Gas inlet, gas from where? Fuel inlet and overflow/ vent. From the crank case breathers.
adam73bgt
Club RR Member Number: 58
Have you got a pic of the carb at all? as far as I know it should have an overflow or return of sorts
Ryannn
Am I an idiot? Lol I've just taken a photo of the carb, rather than a vent into a pipe, I'm assuming it vents to the air through the hole above the SU logo? This looks like it has had a cover over it at some point as well which has snapped off under that flat headed screw?
Last Edit: Nov 10, 2015 16:01:08 GMT by Ryannn
Ryannn
This photo shows the vent where I was expecting it :/
Nov 12, 2015 17:25:52 GMT
Lower, left hand pipe is the fuel inlet. Larger one to the right and up is a for a crankcase breather. The overflow is probably out through the air filter mounting face which is also the float chamber vent.
Nick
