Hello guys,
I haven't been on here for a while sorry.
Everything is still available, let me know if you still need anything.
Apologies again!
Dom
Yes please mate as per previous post
I'd like 6m grey no lugs needed
dodgeroverDid you want both lengths in 35mm? Also, I believe I only have the 35mm in blue and grey. However I do have plenty of heatshrink in various colours if that helps with labeling it. Paul Barrett£24 posted for the 6m in grey. I'll do free postage for a while as an apology for the delay! Cheers guys.
Hi in the 35mm 1 -ve at 90cm with an 8mm fitting at one end and 10mm at the other 1 +ve at 95cm with 8mm fittings both ends please If you have a bit of heat shrink to colour code each end, that would be handy but not the end of the world if not.
If you could pm me your PayPal address and I'll get the money sent ASAP thanks Giles
Do you still have some cable left? Sent a PM thanks. J
Pid363!
Madness is all in the mind!
Oct 20, 2016 18:52:49 GMT
Do you still have some cable left? Sent a PM thanks. J I wouldnt bother I'm still waiting for mine 10 months done the line.
Stupid is as stupid does!
Oct 20, 2016 18:58:09 GMT
just easier and safer to either do the job yourself, or go to your local independent battery/alternator shop and get them to sort you out. that's what I do
Oct 20, 2016 19:19:55 GMT
I never got anywhere with what I wanted either, just bought 70 mm sq welding cable and fitted my own lugs
Oct 20, 2016 22:46:39 GMT
Yep done the job myself as had no reply.
