The new bushes weren't quite hardcore enough so I've gone fully rosejointed on the front end
This has gained me some castor by moving the wheel forward on the tie bars
More filing of the turrets has allowed me to move the topmount inwards to get my desired camber
And to set it up side by side I made a cheapo turn plate out of thick steel, skateboard griptape and grease between the two. It works well.
It's now running 1.5 degrees camber, 2 degrees caster and 1mm toe out up front and it feels awesome. Real test will be at Cadwell in a week's time.
