Oct 17, 2015 18:44:27 GMT
I tried a cheap machine mart scissor-type one on my Saab track rod ends and it broke. I have a fork-type one but it's no use where I'm mot scrapping the joint anyway. I have one of these: [img src=" i1378.photobucket.com/albums/ah88/keefilton/temporary_zpsyogxbrdy.jpg" src=" " alt=" "] But it's too small to be any real use. What I'm looking for is a scissor-type one that will withstand any abuse I throw at it. Any recommendations?
Jaguar S-Type 3.0 SE
Oct 17, 2015 18:47:43 GMT
I find a sharp hit with a heavy short handle lump hammer is enough to dislodge ball joints most of the time.
Oct 17, 2015 18:51:23 GMT
I used to find that too. But I've come across a couple of late where it hasn't worked. The Saab in particular doesn't respond to that approach.
Oct 17, 2015 18:51:11 GMT
Oct 17, 2015 19:01:31 GMT
Oct 17, 2015 19:02:13 GMT
I've had a relatively cheapo "Laser" scissor type splitter for many years. But admittedly I've never had to use more than a ratchet to break the tapers it's been thrown at. It has however, split a balljoint that knackered my hammer-split type, and with utter ease too.
Might've been a case of a one-off dodgy casting?
Oct 17, 2015 19:55:17 GMT
Any of them , all great quality and made to last
Wilk
Oct 17, 2015 20:00:18 GMT
If it's REALLY stuck, put some pressure on it with scissor type or put it under load/tension. Then place lump hammer on one side of knuckle to take the reflective impact and give the opposing side a good clout with another big hammer. Works every time
Once had a bottom ball joint on a front hub on a BMW mini well stuck. Ended up with mate hanging off a 4ft lever bar wedged in gap in bottom arm and me smacking the side of the ball joint knuckle like a loon (been in trade 30 years and well used to wielding a hammer on a daily basis so was really giving it some pain) still took several good smacks before the taper gave free
Oct 17, 2015 20:32:58 GMT
I've used the scissor ones but didn't find them that good. Fork ones always seem to do the job. Both do an equally good job of destroying rubber boots!
Midas
Club RR Member Number: 14
Balljoint splittersMidas
@midas
Club Retro Rides Member 14
Oct 17, 2015 21:05:46 GMT
I've had a Sykes scissor type for donkeys years and it has never failed to crack any joint I could get it into.
BT
Oct 17, 2015 22:33:15 GMT
I hate firm ball joints.
My method consists of a decent penetrating oil. Leave for a suitable amount of time (usually do this the night before the job). Then smack with a very sturdy lump hammer or mallet.
Sometimes it's hard to get a direct knock on the knuckle. In this case I use a bit of 19mm solid bar. I place the bar on the knuckle and smack away.
If that is no success then I get a fork type splitter. I smack this in and in most cases it doesn't totally split the joint. I then take my dad and smack it on the knuckle or shoulder this way. So far it's been successful.
Oct 17, 2015 23:24:01 GMT
If you are splitting the BJ to do suspension/ drive shaft work then don't worry about the rubber boot as you can but new ones for a few quid.
If you are splitting the BJ to do suspension/ drive shaft work then don't worry about the rubber boot as you can but new ones for a few quid. Yeah I didn't release u could for ages- now got a stash of 'em ??
sparkyt
selling stuff
Put some weight on the joint as to split it apart like a good bar or jack . .
Take two bug hammers and hit both sides of the taper socket at the same time . .
Works for me the last 20 years . . No splitting tool required . .
Oct 18, 2015 21:07:08 GMT
Always used the two hammers method if one hammer alone does not do it.
BT
Oct 19, 2015 20:06:26 GMT
Never tried the double donk method. Will have to remember that one.
double hammer method works well and if you were replacing the ball joint, a bit of heat can help release it. but usually melts the rubber boot
1972 viva 'Sparky'
Oct 23, 2015 12:10:40 GMT
The gist of this seems to be buy a bigger hammer.
Balljoint splittersChasR
@chasr
Club Retro Rides Member 170
Oct 23, 2015 20:44:33 GMT
If you are splitting the BJ to do suspension/ drive shaft work then don't worry about the rubber boot as you can but new ones for a few quid. They don't seem to last long unless you go for OE or genuine parts. It is something my MOT tester has noticed too. I have never until recently seen balljoint boots completely deriorate within 2 years. With the sciscor type of balljoint breaker I have rarely split the boots however. Sometimes the hammer technique will work but more often than not I end up using the balljoint splitter.
Oct 25, 2015 20:27:44 GMT
The gist of this seems to be buy a bigger hammer. ... so you now have 2 hammers, then use any of the "2 hammers" advice above Has worked for me for many years
