Oct 12, 2015 12:01:42 GMT
in it for updates. i'll be keeping a close eye on that patina to make sure it stays - if only for the sign-writing and oh so old phone numbers
voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
Oct 12, 2015 15:51:42 GMT
I was not aware of the Stag wheels? that's great! and yes, lots of possibilities! Thank you. The chassis is SOLID!!!! the cradle for the gearbox is very basic, but again, Solid! wire brush and a paint should do the job, Thanks for the kind words guy's. And thanks for the photo randywanger, i will be sending that to the Laindon/Basildon history page.
voodoo57
Oct 12, 2015 15:56:49 GMT
Apparently a Triumph P.I 2.5 had deep dish rims as well so keep an eye out chaps!
Oct 12, 2015 16:04:38 GMT
There was a Pro Street one of these being built somewhere, never seen it finished so probably still in a garage.
Bioshock
It aint hip to be square.
Oct 12, 2015 16:06:00 GMT
That really is all kinds of awesome..
Almera GTI = ugly bird who turns out to be great in the sack = Win
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Oct 12, 2015 17:06:28 GMT
That is a lovely little van, They are properly rare as they seem to rust way faster than any other Standard Triumph vehicle ever made! Literally only a handful left I believe. The patina and old signwork looks brilliant and if you can keep that it'll make the whole thing eleventy billion times cooler! You're a brave man, but good luck with it
voodoo57
Oct 12, 2015 18:32:38 GMT
Thanks again! Just been speaking to a guy with a pickup model! but i think this is destined for greener pastures!But he will be helping me out with odds and sods, i will look on the net to see how many there are left in the U.K.
Oct 12, 2015 22:07:16 GMT
Great van, look forward to seeing more of it
vulgalour
Club RR Member Number: 146
Oct 13, 2015 12:42:51 GMT
How many left? They're almost extinct, a very endangered species. You're unlikely to ever encounter one in the wild and it's rare to see them at shows, even ones that are aimed directly at Standard, Triumph, etc. They survive in tiny numbers due to being underpowered when new, being used heavily because they're a commercial vehicle and chronic rust. It's remarkable any have survived at all to the present day, much less that there's three or four out there that are in virtually as-new condition.
From what tiny amount I know about Atlas vans, the easy bit is the mechanical side of things as for the most part that's all Triumph, some Herald heritage in there too I think. The problem comes with trim, body panels and glass, none of which is going to be anything other than a battle to source without a lot of luck. Absolutely worth saving even with that having been said, the rot doesn't look as chronic as usual for Atlas vans, they still look like vehicles rather than a teabags!
I really, really hope you can stick with at least one of them and get it back on the road. It will be excellent to see a bit of incredibly rare British motoring out there doing its thing.
hamps
www.medwayrscentre.co.uk
Oct 13, 2015 13:16:19 GMT
Bookmarked this
voodoo57
Oct 13, 2015 16:06:43 GMT
I spoke with a guy a few weeks ago, and apparently a chap had 3 containers full of parts all for the Atlas models, they were sent to India! Yhen again, this was about 10 years ago! So much interest in this! Looking at less than a year before it's out and about.
Cheers for the support folks!
eternaloptimist
Oct 13, 2015 18:10:52 GMT
They carried on building then in India for a fair while.
Oct 13, 2015 19:56:39 GMT
You'll probably be aware Stag Mk 1 14" steels have the right pcd. Aren't all Stags the same PCD? 4 x 4.5" (4 x 114.3mm) In which case there's all sorts of things that share the same PCD: everything from Triumph 2000s, MGBs, Scimitars, TR6s, Lotusus (Lotii!?), loads of older Japanese stuff (plenty of aftermarket rims) and later stuff like four-stud Volvo V40s and Primeras.
camper damper
Another car bites the dust
Oct 13, 2015 20:08:43 GMT
My granddad had one of this about 25 years ago he turned it into a mini bus with houses window on the side and some old transit bench sit in the back was in his back garden for years till the scrap value went up and then it got crushed never knew what it was till I saw the picture
eternaloptimist
Oct 13, 2015 20:38:18 GMT
You'll probably be aware Stag Mk 1 14" steels have the right pcd. Aren't all Stags the same PCD? 4 x 4.5" (4 x 114.3mm) In which case there's all sorts of things that share the same PCD: everything from Triumph 2000s, MGBs, Scimitars, TR6s, Lotusus (Lotii!?), loads of older Japanese stuff (plenty of aftermarket rims) and later stuff like four-stud Volvo V40s and Primeras. True - but I was thinking banding and original Standard hub caps. Stole the idea from someone who's restoring an Atlas on the Standard owners forum.
voodoo57
Oct 13, 2015 21:01:16 GMT
There are a couple of spare wheels with it, I was thinking the same, banded steels, but I will leave the wheels til last and get an idea of what i think looks best going by the choices I now have thanks again chaps!
Looking at less than a year before it's out and about. Cheers for the support folks! Target = The Gathering 2016 then?
voodoo57
Oct 14, 2015 15:55:29 GMT
Lets just say if my enthusiasm and lack of sleep just thinking about it keeps up, I guarantee I will be there!
leaky
Bookmarks can't wait to see how this turns out!
1962 Morris Mini Traveller 1973 Commer Suntor 1979 Mini Clubman Saloon 1983 Austin Mini City e 1988 Austin Metro L 1989 Austin Metro 310
Oct 16, 2015 22:53:35 GMT
Nice. Bookmarked. Don't let us down.
No pressure mind. :-)
