Sept 7, 2015 20:59:43 GMT
went to beaulieu auto jumble this weekend looking for rare car parts and ended up buying this Raleigh vektar i love the look of this bike but i know nothing about them I'm hoping there are some bike experts on here does this bike share parts with other Raleigh models? the crank is seized solid at the moment so it looks like it needs new bearing also missing a brake lever and stand but these parts might be unique to the vektar? does anyone know where i might get parts for it? any help would be appreciated
Last Edit: Sept 7, 2015 21:01:20 GMT by vauxviva
awoo
Sept 7, 2015 21:51:38 GMT
i woudlnt worry about the stand but i think its essentially a raleigh burner under all the plastic.
the brake lever looks unique to that but Raleigh used to share parts across models so you may pick one up off another kids bike.
the thing with these primarily are if the circuits are still working, thats what people want mostly from these vektars.
woodenspatulas
Retro in ways you can't imagine
Sept 8, 2015 13:03:09 GMT
amazing that is all
1999 Vectra Estate + 1995 Saab Engine = Good Times
Sept 9, 2015 20:02:48 GMT
Thanks for info just ordered some burner crank bearing so hopefully they should fit i got this bike for a good price so bought it expecting the electronic bits not to work the battery box needs work first before i can try it as some of the spring battery tabs are missing
turbom
Sept 9, 2015 20:38:41 GMT
Cool bike remember seeing them in look in Have you tried contacting raleigh? ?
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Sept 10, 2015 9:52:04 GMT
I wanted one of these so bad when I was a kid. A local show off had one in white and it looked awesome in that 80's futuristic style. Does it have radio and sound effects thing?
Sept 10, 2015 12:07:49 GMT
I remember someone with a white one, maybe it wasn't one of these but it looked similar. Except it had suspension and disc brakes. This was around 1982.
'98 e36 316i lux '97 mx5 harvard '87 Saab 900 T16s
focusmk1
Rust lover
Sept 10, 2015 19:20:44 GMT
I remember someone with a white one, maybe it wasn't one of these but it looked similar. Except it had suspension and disc brakes. This was around 1982. No way
Sept 11, 2015 8:36:53 GMT
I had 2, red and white Vektars. They were 3 speed bikes. I believe that the black bikes were all single speed, and had the similar mag wheels as on some Raleigh Burners
The frame is different than the Burner. The forks are longer, so the headstocks higher, and there's mounting points for the body work.
The Raleigh Wildcat had a similar frame
There was a special tool to get the electronics open. 2 prongs go into the rectangular holes above the speedo. I got that off with a couple of screwdrivers. Marked up the plastic a bit tho, be careful.
The seat pin is 28.6mm diameter. As used on lots of Raleighs, such as, Twentys, Mk1 Burners, Mk1/2 Choppers. Its a common size for MTB seat pins these days. So you can get longer plain steel and alloy micro adjuster seat pins. If your wanting to run a regular saddle at a reasonable height. Those wide, strange shaped foam saddles aren't good to ride on for long. Oh yeah, the seat clamp size is 31.8mm diameter, another common size on modern bikes.
Sept 17, 2015 13:36:16 GMT
there is a white one on display in Coventry Transport museum
Jez
Sept 18, 2015 11:54:40 GMT
I wanted a white one of these SO bad!
I could be wrong, but I think these share parts with the Grifter? That's what I had back then and I seem to remember noticing the part sharing. Grifters are just as desireable though so it may be just as hard to find parts for them!
1990 VW Golf GTI G60 2014 Skoda Octavia RS
Sept 22, 2015 19:39:07 GMT
Thanks for the info guys done a bit of work on the vektar fitted new crank bearings after fixing a broken wire the computer module is full working order pic shows the battery box that needs repair before i can try the sound effects and radio does anyone know where i can get new wheel ball bearings? i have a few missing in each wheel
1980's Raleigh VEKTARfr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Sept 23, 2015 12:13:50 GMT
I wanted one of these so bad when I was a kid. A local show off had one in white and it looked awesome in that 80's futuristic style. Does it have radio and sound effects thing? same for me too sadly i was in your shoes and not the show offs with the white vektar, i do know that he drives a normal car now though and i have a vektar-like car so i win.
lightyearman
GYJDM - Grimsby based Japanese car club - Find us on Facebook
Sept 23, 2015 23:39:34 GMT
Thats all the cool. I had a Grifter when i was a kid (this was in the mid-late 90's so it was retro then!) I gave it to a mate to restore and have a play with about 5 years ago and it got pinched
'89 Honda CRX siR Glassroof Flint black fully restored track beasty '90 Nissan S13 Pignose - pass the mig wire '86 Mini - matt orange, 13" Wellers, Project 2018 '97 LDV Convoy home built camper/tramper van '04 Saab 9-5 Aero HOT. Anyone want it? '91 Honda VFR400 NC30 17,000 km from new '87 Honda XR80 4 stroke baby crosser '03 Mini Cooper S - honestly, they are fun... '15 VW T5.1 LWB daily brick
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
1980's Raleigh VEKTARretrolegends
@retrolegends
Club Retro Rides Member 94
Sept 24, 2015 6:11:45 GMT
I had a thread on these a couple of years ago, if I can work out how to link it I'll put up
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
gse
Jun 21, 2016 12:15:25 GMT
Looking for one of these myself!
I can see its been a year or two since it was the subject of discussion, so if anyone has got bored of their Vektar (white model) and wants to find it a loving home where everything 80's is cherished, please PM me!
Last Edit: Jun 21, 2016 12:47:54 GMT by gse
Pid363!
Madness is all in the mind!
Jun 21, 2016 19:51:22 GMT
I remember them i also wanted one many years ago i think they were pre burner? An up dated Grifter with Kitt type gadgets!
Stupid is as stupid does!
Jun 22, 2016 10:50:24 GMT
i woudlnt worry about the stand but i think its essentially a raleigh burner under all the plastic. the brake lever looks unique to that but Raleigh used to share parts across models so you may pick one up off another kids bike. the thing with these primarily are if the circuits are still working, thats what people want mostly from these vektars. These are nothing like a burner under the plastic. Totally different frame tubing and geometry. They share some similar parts but are a different bike.
awoo
Jun 22, 2016 21:45:55 GMT
i woudlnt worry about the stand but i think its essentially a raleigh burner under all the plastic. the brake lever looks unique to that but Raleigh used to share parts across models so you may pick one up off another kids bike. the thing with these primarily are if the circuits are still working, thats what people want mostly from these vektars. These are nothing like a burner under the plastic. Totally different frame tubing and geometry. They share some similar parts but are a different bike. He was asking about parts, not the geo of the frame. Raleigh used the same parts over many different bikes. I'm pretty sure it would share lots with the burner. Except for the frame. I doubt that's a part he will be replacing. Not that it even matters any more it was from last year
Jun 23, 2016 14:40:04 GMT
These are nothing like a burner under the plastic. Totally different frame tubing and geometry. They share some similar parts but are a different bike. He was asking about parts, not the geo of the frame. Raleigh used the same parts over many different bikes. I'm pretty sure it would share lots with the burner. Except for the frame. I doubt that's a part he will be replacing. Not that it even matters any more it was from last year I wasnt having a dig, they just don't have much in common with a burner. Bearings are the same but most everything else is different. My friend had one a few years ago and we compared it to my burner. It was top of the page so I didnt look at the date.
