Getting rid of some parts in the garage. All prices plus postage. Collection from North London N13, if you wish for items to be posted it will be recorded delivery. More will be added periodically.
Mk3 capri indicator assy, genuine ford, no chips or cracks. £10
Genuine Wood and Pickett rear nudge bar, for mk1 minis I believe. Some marks on the rubbers, but all original! £40
Brand new never fitted 14x6 Mr. Gasket alloy drag wheel. Never seen another one of these, dated stamped 1982 IIRC. Polished alloy with some weird spongy metal insert, would make a good table!Bit of surface corrosion but nothing a bit of wet and dry couldn't sort! £35
Cortina/Capri/Escort clock, tested and working, one of the bulbs doesn't illuminate though. Comes with wiring. Good condition, some marks but nothing major. £15
'60s ford clock but 52mm so can fit most cars. Fomoco marked on the back. Brilliant condition, looks like new, untested as I don't have any spade connectors to hand. £20
Cortina mk4/5 headlights, like new, excellent condition they seem to never have been fitted. One Lucas, one Carello, both Ford Halogen marked. £20 each or £30 the pair.
Pair of Escort RS Turbo ECUs. Blue red white removed from early s2s, no knock sensor board so can be used on any s1 or s2. Both have no chips but have a 40 pin socket installed for the main chip to allow quick removal of the chips. Also have an Ahmed Bayjoo chip but this is faulty and an original ford chip which had 15 or so of the pins broken off. Ideal for keeping as spares, getting harder to find now. £25 each or £40 for both.
mk3/4 Escort strut brace, was going to fit this to my RS but don't want to drill holes in her, alloy is polished but scratched, still usable £30
Small Compton compressor. Runs off 110V yellow box, excellent working order, ideal for small bits and bobs around the garage. £35
Mountney steering wheel with horn push. Brand new in box. £25
