sleag40
I've no longer space for any more!
Nov 14, 2015 18:31:10 GMT
I got the front suspension stripped pretty quickly - after struggling to make a spring compressor, I ended up doing it "gypsy" style. (Undoing the lower wisbone pivot bolt, withdrawing the pivot bolt at arms length, and boioioing!) This gives me time to find the correct tool, as there is absolutely no way it can be assembled without one. All the ball joints were pressed out/unbolted pretty quickly, but the rubber bushes - it took two hours of cutting and hammering to get just one out without damaging the wishbone! Theres 9 more to remove
Last Edit: Feb 18, 2020 16:42:19 GMT by sleag40
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1973 Renault 15TS 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
Nov 14, 2015 20:01:11 GMT
What blinding progress mate, nice to see it's being fully stripped down. Now i'm assuming the front suspension items are getting blasted and satin black powdercoated Also engine mounts should be mid blue too.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
steveg
Nov 14, 2015 21:21:01 GMT
Your getting on well with this. I did work experience at A Vauxhall dealership and they had a Manta in for major body repairs. The lower suspension arm had nee badly bent and the springs was almost going to pop out. Their preferred method of removal was the longest lever bar they could find (about 6 ft) and open the workshop door. Needless to say it came out quite easily and headed at speed straight out the door and didn't hit anything fortunately. .
sleag40
Nov 17, 2015 18:46:53 GMT
What blinding progress mate, nice to see it's being fully stripped down. Now i'm assuming the front suspension items are getting blasted and satin black powdercoated Also engine mounts should be mid blue too. It will all be getting blasted, but I'll probably use POR15 black. Your getting on well with this. I did work experience at A Vauxhall dealership and they had a Manta in for major body repairs. The lower suspension arm had nee badly bent and the springs was almost going to pop out. Their preferred method of removal was the longest lever bar they could find (about 6 ft) and open the workshop door. Needless to say it came out quite easily and headed at speed straight out the door and didn't hit anything fortunately. . Nice - good of them to show you how its done! Got the last two out in a little over two hours - I must be getting more proficient The rear two were by far the hardest, but not likely to be a problem for me any more - a full set of polyurethane bushes will be fitted when it goes back together.
Last Edit: Feb 18, 2020 16:44:24 GMT by sleag40
Nov 18, 2015 13:39:42 GMT
CIH ftw
sleag40
Nov 22, 2015 18:14:03 GMT
Took out the servo and brake lines today, was cold as a penguin's chuff! I then took a wire wheel to the Swan neck areas of the chassis. Both sides of the passenger side were spot on. The driver's side wasn't so good. The list of stuff for my main welder bloke to do just got bigger! (He's gonna do it all over Christmas due to being super busy.) Made myself busy with some more stripping now that theres nothing in the way any more. Made a start on the engine bay. On the way out there was some kind of aviation based witchcraft going on in the sky!
Last Edit: Feb 18, 2020 16:55:02 GMT by sleag40
Nov 22, 2015 22:17:41 GMT
Bad news about the swan necks but it'll repair. The above photo appears to show a welded joint, i can't imagine this would be factory.
sleag40
Nov 22, 2015 22:21:53 GMT
The nearside inner wing and chassis leg was replaced after a crash in the mid 80s. The entire nosecone/front end was replaced too!
Nath
Memory is blank
Nov 23, 2015 12:36:28 GMT
Everytime I come back something more has been removed...keep up the good work.
Loves anything Retro - Hates Toyotas.
Nov 23, 2015 18:02:55 GMT
never been under a mk1 cav, but have a few manta's, even so i think youve got off lightly there on the chassis rails !
Last Edit: Nov 23, 2015 18:03:42 GMT by darrenh
sleag40
Nov 23, 2015 18:51:05 GMT
never been under a mk1 cav, but have a few manta's, even so i think youve got off lightly there on the chassis rails ! Definitely!
sleag40
Nov 26, 2015 19:44:47 GMT
Found another couple of hours to spend on this today - I brought a borrowed engine stand to the unit, then got stuck in cleaning the engine bay back. I hope to have the whole engine bay done over the weekend.
Last Edit: Feb 18, 2020 16:57:00 GMT by sleag40
gtrea
With the spring compressors I just use regular ones you would buy from Halfords but with about 1/3 cut off the length of them Placed in the 10 to 2 position on the spring, with the tensioning bolt facing downwards the thread of the compressor then pass's thru the gap between the spring and the upper wishbone without fouling on anything. Not entirely ideal, but i have had my springs in and out about 5 times now and it works pretty well
1978 Opel Manta SR Berlinetta 1UZ-FE 2013 Opel Insignia OPC 2016 Skoda Octavia Scout +Vans and Trucks and stuff.....
sleag40
Nov 27, 2015 20:19:47 GMT
Cheers for that - it gives me a plan if I can't find the correct tool when the time comes!
sleag40
Nov 29, 2015 17:42:49 GMT
Last Edit: Feb 18, 2020 17:00:27 GMT by sleag40
Nov 30, 2015 20:05:26 GMT
Just lacquer that engine bay as is.......
sleag40
Just lacquer that engine bay as is....... I'd like to do that on something one day, but this is not the car for that look. I got the chance to make a start on the front panels this evening. I need to do a load of overtime at work for the next couple of weeks, so may not get another go at it for a while.
Last Edit: Feb 18, 2020 17:02:09 GMT by sleag40
Yep its a toss up between earning it and spending it.......
sleag40
Last Edit: Feb 18, 2020 17:04:01 GMT by sleag40
cavman
feeling inspired :)
You have a lot more patience than I have!
'78 Mk1 Cavalier Coupe - I wish I had a pound for every time someone told me "my dad used to have one of those"!!
