Jul 19, 2016 19:29:14 GMT
Nice Ive never had any luck getting membrane to stick to silicone long term. Always comes off. It will stick to the door lovely though. Might be worth checking them in a few months or so.
Jul 19, 2016 21:40:20 GMT
lovely lovely job
sleag40
I've no longer space for any more!
Jul 20, 2016 17:41:42 GMT
Nice Ive never had any luck getting membrane to stick to silicone long term. Always comes off. It will stick to the door lovely though. Might be worth checking them in a few months or so. I've just found out something called "Plumbers Mait" is the stuff to use - if they come unstuck, I'll give that a go. lovely lovely job Thank you very kindly! I gave the rear panel a bit of satin black paint this afternoon. The area to be painted was scotched, then panel wiped, then hit with the black stuff. I unmasked it while the paint was still soft. Once the paint has hardened, I can put the lights, trims and letters back on.
Last Edit: Feb 17, 2020 20:22:48 GMT by sleag40
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1973 Renault 15TS 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
sleag40
Jul 21, 2016 17:22:56 GMT
Rear end starting to look like a Cavalier again. I'm told there's a good chance my boot lid will be painted at the weekend - that would be nice!
Last Edit: Feb 17, 2020 20:24:05 GMT by sleag40
sleag40
Jul 22, 2016 19:08:56 GMT
I found a new radiator for very little money on eBay - a lot easier than trying to smarten up the old one. It's identical in every respect other than cosmetically! It was soon in position, complete with a shiny new cap.. Unfortunately I'm still awaiting the completion of spring compressor version 2, but she'll be run up as soon as all four wheels are on.
Last Edit: Feb 17, 2020 20:27:17 GMT by sleag40
sleag40
Jul 23, 2016 17:02:11 GMT
I trial fitted the wing against the new door - it fits perfectly! I wasn't expecting that! Got a call to say the second spring compressor was ready, so I went straight over to fetch it. It's a lot better now, but still took a little trial and error to get it right - it doesn't matter now though, its in! Theres a couple of bits of touching up to do from when the first compressor broke, but it's no biggie! I had to leave as soon as it was all bolted up, but it will definitely be back on its wheels tomorrow. Oh, the bonnet and boot lid have been painted too!
Last Edit: Feb 17, 2020 20:29:28 GMT by sleag40
sleag40
After a ridiculously early start, I finally got back on with this. Back on four wheels for the first time this year. Boot lid now in paint Carpets back in Fuel is next on the list.
Last Edit: Feb 17, 2020 20:32:00 GMT by sleag40
Jul 24, 2016 18:50:21 GMT
Good progress is being carried on, is the carpet getting a deep clean before the seats go in? It'll make it far easier to do it now.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
sleag40
Jul 24, 2016 20:32:56 GMT
Good progress is being carried on, is the carpet getting a deep clean before the seats go in? It'll make it far easier to do it now. Cheers! The carpet will get a decent clean before the seats go in. They'll be coming out again when I get the seats re-covered though. I'm gonna try re-dyeing them, as the sun has bleached parts of them in a similar way to the tops of the seats. Fitted the front shocks late morning, not so bouncy any more! Back on the car this afternoon, petrol in hand - it was time to get her started. Oil went in, new battery fitted, and water in the radiator (in case of any leaks!). I turned the key and......lots of clicking and occasional slow turning of the engine. The battery is new, so it could only have been a bad earth or a dead starter motor. The bell housing to chassis leg earth strap wasn't very tight, so I tightened it up, and now the motor cranked over nicely. The fuel pump at the front of the engine is gravity fed from the tank, but the fuel line runs up the chassis leg before it drops down to the pump. I only put 5 litres of fuel in, so I needed to make sure it was reaching the pump - it wasn't. A clear plastic tube was inserted into the end of the fuel line, and I syphoned it through, it didn't need much help - now we were in business! After 5 seconds or so of cranking, she burst into life, and with a couple of tweaks of idle + mixture adjustment screws, settled down to a nice even tickover. Belter! I left it running with the heater on for half an hour or so to bleed the air out, the thermostat was working nicely, and best of all - no leaks of either water or oil. Flushed with success, I fitted the anti roll bar next. It was something of a faff, but I got there in the end. Another one of those jobs that would have been a lot easier with an extra hand! ^^^ Here you can clearly see the curve the spring needs which made the spring compressor so difficult to get right. All in all, a good day!
Last Edit: Feb 17, 2020 20:36:59 GMT by sleag40
Jul 24, 2016 21:42:35 GMT
best resto for me on here
Jul 25, 2016 16:26:11 GMT
Brilliant to know that she lives, i can sympathise with you regarding doing the ARB. That is one hell of a pig to do, when i did mine it took me and a mate a fair bit of effort, and swearing to refit. Also the carpets will look a treat dyed, the same mate redid his Dolomite carpets and they look absolutely mint.
sleag40
Jul 25, 2016 20:10:50 GMT
Brilliant to know that she lives, i can sympathise with you regarding doing the ARB. That is one hell of a pig to do, when i did mine it took me and a mate a fair bit of effort, and swearing to refit. Also the carpets will look a treat dyed, the same mate redid his Dolomite carpets and they look absolutely mint. Having three hands would have been useful, but there wasn't anyone around! Not a lot to show you today, my time was spent doing up all the front suspension bolts with the weight on the wheels. New split pins were fitted to the steering arm ball joints and the chassis to cross member nuts. After a bit of gassing, I was given my freshly painted bonnet back, so I'll probably fit that and the boot lid next. After that, once the braking system has been filled and bled, I can fit the wings, then it can have its flat and polish.
Last Edit: Feb 17, 2020 20:39:45 GMT by sleag40
andy-v
i like cookies :D
Jul 25, 2016 20:17:59 GMT
great read and great resto
Jul 25, 2016 20:30:58 GMT
Snap !! sorry to do a thread hijack When i refurbed the bay in mine a couple of years back i discovered that the engine mounts were suppose to be blue. Vauxhall Pale Blue (a 70s colour) was an identical match. The drop links, rack gaitors, and track rod ends were replaced in this area as it was easier access now than when together .
sleag40
Jul 25, 2016 20:33:16 GMT
My engine mounts were black, maybe early ones were black and late ones blue?
sleag40
Jul 26, 2016 19:54:44 GMT
best resto for me on here Many thanks! great read and great resto Cheers! Glad you enjoyed the read. More stuff that can't be seen today - first all the rear suspension bolts were done up tight. Next all the brake pipe unions were checked for tightness ready to fill the system, then the boot lid went on. Before I left, I made sure I could remember how the jack/wheel brace/spare wheel are fitted. I need to hijack another pair of hands to fit the bonnet - maybe tomorrow!
Last Edit: Feb 17, 2020 20:42:21 GMT by sleag40
sleag40
Jul 27, 2016 19:38:43 GMT
Not a lot to report today, time was short. Filled the gearbox with oil, then had a go at the brakes. The fronts filled nicely under gravity, but nothing at all made it to the rears. Gonna try an easy bleed set up next - or a helper! Being very careful not to get any on the new paint -
Last Edit: Feb 17, 2020 20:43:32 GMT by sleag40
Jul 27, 2016 21:13:38 GMT
Silicone fluid would have been better and seeing as you had replaced the lines this would have been an ideal chance. It can be spilt on the paint and makes no difference plus it won't degrade and therefore never needs changing. That in turn also means it won't attack any of the rubber seals or hoses.
sleag40
Jul 27, 2016 21:27:46 GMT
Silicone fluid would have been better and seeing as you had replaced the lines this would have been an ideal chance. It can be spilt on the paint and makes no difference plus it won't degrade and therefore never needs changing. That in turn also means it won't attack any of the rubber seals or hoses. If every line and component had been replaced, I'd have used it, but I only replaced the lines that were damaged. The compensator valve and the rear cylinders are the originals too.
sleag40
Jul 28, 2016 19:02:38 GMT
We now have a brake pedal! I've not found any leaks, but I'll give the pedal a good mashing, then check for leaks again before I consider it job done. A new bonnet stay clip arrived today, thanks to Keith at VauxhallGreenParts. I'd forgotten that the original one had disintegrated when the car was stripped, but luckily he had one left. I couldn't resist cleaning the dust off the car - I'll probably have to clean it again when it goes over for polishing, but hopefully that will be done soon - just need to fit the bonnet and wings now.
Last Edit: Feb 17, 2020 20:46:16 GMT by sleag40
