£350 NO OFFERS
1998 Mazda MX5
1.8 Engine
Manual Gearbox
Full LPG conversion fitted (Tank in boot)
Convertible
Rare RS8 Wattanabe 14" Split Rim alloys. (All need a refurb)
Needs work or take parts off it, it is what it is but I'm losing a lot of money and will take £350 firm. If you don't want the LPG conversion on the car it can be removed, I have a standard undrilled inlet manifold that can be suppled with the car.
Had a new clutch installed that has done less than five miles.
Brand new discs and pads all round.
New Wiper linkage installed (common fault)
The engine was replaced when I bought it, the car does run however it appears to smoke on overrun. When it was purchased it had a blown engine that put out clouds of oil smoke, the car has done no miles since the replacement engine was put in place so I don't know if it is oil in the CAT that needs to burn off. However I am listing as a project and saying the engine needs attention to avoid dissapointment.
The bodywork is showing signs of rust, rear arches need replacing fronts would too.
The interior is dirty but in useable condition and the roof is starting to show signs of wearing but with correct treatment would probably come up well but there are no tears and the rear glass window is in good condition.
There are various little bits that would probably need doing on the car and I am not sure what it will require for an MOT. Started at a fair price as the wheels are worth half the start price and the LPG conversions can cost upwards of £1000. It will drive if you put a battery on it, but you will need to bring a traile to collect.
Collection from Basingstoke Hampshire.
