Aug 25, 2016 18:14:15 GMT
Lastnight this happened This was what it lead to at lunchtime today Followed by a bit of groovy groovy and a pocket for the bearing to reside in. Clutch bell complete
Aug 25, 2016 18:17:51 GMT
Bearing installed
Aug 25, 2016 23:13:39 GMT
Sorry to fawn, but I do love your engineering in this thread.
logicaluk
^^ Your wish is my command, Dan. I need to sort out another server power supply for someone else,so will do a mini build on that. It's a couple of hours at best,so will take a couple of pics and post it up. Not holding too much hope in getting the psu much before the end of next week,but request duly noted.... Thank you sir.
Aug 27, 2016 17:06:23 GMT
Plans for big machining weekend have been scuppered. Have a job with a bridge that was built in the late 1800's that is in dire need of attention. Couple of important parts for a lifting beam need milling. All 3D like tapered, blah blah blah. So that's got my full attention. All is not lost though. Went and looked at a woodworking bandsaw yesterday. Something I don't want and don't need. Ok,well I could have use for it on a little job I need to do for a friend. Me and woodworking? I only need one of two tools, dependant on the size of woods, either an axe or a chainsaw....then into the barbecue you go..... Anyway, it was advertised for not a lot of money and further away than I originally thought,when I agreed to go and see it. Delightful Oldboy,who, I think has been given strict instructions from her indoors to tidy up and get rid of in his triple garage. Anyway,it turns out it was in lovely working condition ,as advertised,right up until he switched it on that morning. Last time he used it ,it was fine ,I was told. Anyway,turns out the tyre on the top wheel had lunched itself. But, it's in really good condition apart from that. Ok, so, how much are you prepared to drop the price? £2,50......Yeah right, look out the window? See that squadron of pigs? All fed and ready to fly.... I then looked at the guide bearings. Not for the faint hearted. Looked like the blade had been put on teeth first. Pointed it out to him,he squirmed a little,and then with great joy showed me his dewalt cordless drill powered bicycle with the chuck driving the tire and a modified bicycle brake caliper pushing the trigger to make it go. He managed to find a new,one owner,never been seriously raced or rallied bandsaw blade that would come with the machine. I took it and did the quick trick of getting it to jump into three rings. Said my goodbyes and started to leave. Not ,to me worth the hassle.... Was genuinely walking away, having said it wasn't for me and it isn't in my nature to haggle,so would rather cut my losses at having travelled further than anticipated and call it a day. Got called back, please take it, it's your for nothing,just want rid of it....probably a good thing, because if he is half as deaf as he is blind,he wouldn't hear his own screams once he cut his fingers off.... Magically coiled up blade and remains of tyre Well knackered guide bearings with guide blocks totally worn away
Last Edit: Aug 27, 2016 17:12:29 GMT by Deleted
Aug 27, 2016 17:17:44 GMT
Anyway. Plans are to make new guides. Have ordered new urethane tyres from the states. Will put it back together to cut the limewood blanks I need to make. Then rip it apart and set about converting it to a metal cutting bandsaw,something I really need when I make the inlet manifold and exhaust collectors....Apart from the speed of the blade needing serious reduction,the chassis needs a bit of stiffening up, the guides need attention, the table needs beefing up, but it will be perfect for my uses once done... Oh, and I found another one of these..... Motor/ gearbox might just be what I need......
Wilk
Aug 27, 2016 17:34:43 GMT
ooh that's a nice baby band saw. The one I used at work has wheels bigger than that casting. I would have to walk into the blade when folding it up and then let go VERY quickly so it didn't come back at you! Folded dia was around 4ft. Old boy showed me the folding trick which I've now passed onto my son for when we change the blade on the hobby saw at home
Teeth pointing upwards blade in front of you, hands on the underside outside edges with thumbs pointing upwards, move forward whilst crossing your arms one over the other. The blade will coil and do the rest. Easy when you know how eh?
Aug 29, 2016 15:18:15 GMT
Managed to continue with the clutch today Drilled some holes and counterbored them They even line up with the existing holes. My very near gauge is super accurate Then needed to make some rivets. Never made cold forming rivets,so thought I better make one just to see if the material I had in mind to use ,would work. Quick tool to form the head over Worked a treat
Aug 29, 2016 15:24:24 GMT
Made a little jig to hold it together whilst riveting All the bits ready including the rivets Cut a mullered tap in half to make a tool to round the heads over Ground a radius into the end with a die grinder with the old tap in the lathe Worked a charm. All riveted back together Assembled and hooked up to the Makita test bed It works! Just need to broach the key way and that's the clutch finished. Getting there slowly...
Aug 29, 2016 17:37:24 GMT
I have lost the plot of what piece of car re-manufacture machinery you are tinkering with at the moment but none of that matters in the slightest. Fantastic work, even doing the simplest of things means the camera does not get a look in.
logicaluk
Aug 29, 2016 17:50:05 GMT
Wounders will never cease, especially where Johnny B is concerned..... not only a riviting tool but the rivits as well. Simply awesome chap well done.
Aug 29, 2016 18:37:30 GMT
I have lost the plot of what piece of car re-manufacture machinery you are tinkering with at the moment but none of that matters in the slightest. Fantastic work, even doing the simplest of things means the camera does not get a look in. Its ok,most of us have forgotten at one point that there is actually a car involved!
Aug 29, 2016 22:28:30 GMT
pretty sure we are on tools to fix the tools to fix the car
Aug 29, 2016 23:26:46 GMT
Soon he'll need to build a car to go get bits to make the tools to make the tools to fix the car.
Nice work, though. Something simple but not many people would think of making their own. So how hard is the steel for the rivets then? Did you need to use a press to form the heads or just a hammer?
Rivets made out of En8 which is a good grade of mild steel. Used for shafts etc,it's nice to turn,contains no lead,is case hardenable but will bend before it breaks. I worked on the assumption that if it bends before it shears,it's good enough for rivets....riveted over in the press ,but could have hammered them over. Would have been a bit tricky as they are recessed in a hole. Didn't like the idea of hammer forming them with a soft punch that might mushroom or bend and the get stuck in the hole. Also didn't cherish bludgeoning a cut down punch made from a hard,but brittle,cut down tap. Chances are you show that a hammer and it will put itself back in kit form very quickly,hence using the press.
Wilk
My 'ole man was an engineer. I remember him snapping a tap in a hole whilst trying to retap something for me, which was devastating to me as a non-engineer. I had the understanding that drilling out a toughened tap wouldn't be possible My dads answer was to break up the tap with a punch and hammer..... Would never have thought of that solution, I thought the part was scrap
Aug 30, 2016 19:46:38 GMT
Some days you are the statue. Other days you are the pigeon. Today was a statue day. Endured the most mind numbingly boring afternoon in a meeting that quite frankly was a total waste of time and half a rainforest for the amount of paper it generated. Having spent the last four hours trying to devise a way to top myself with a piece of paper,I got home in ,shall we say,a mood very close to sense of humour failure. That's when I opened this.... A beautifully colour copy of a magazine article on an Rx2, copied and sent to me by a RR member who I have never met. Thank you Wilk for making my day. I really appreciate the time and effort you took to get that article to me. It turned my day around. Perfect timing.....
Last Edit: Aug 31, 2016 3:36:53 GMT by Deleted
mattiwagon
Just got a work truck
Aug 30, 2016 20:26:52 GMT
Nothing in the worls like good Karma!
If they cant be nice f**k em!
84 low t25 panel 1.9td beige and rust combo 97 Goped Bigfoot G260RC with clutch conversion 97 Impreza turbo 2000 builders wagon 76k sold 04 Fabia vRs 50mpg pocket rocket 04 battered T5 pickup in blue! Chainsaws lotsa Chainsaws
Aug 30, 2016 23:50:38 GMT
Oooh. So if you can break a tap like that, could you also break an easy out that's snapped off? Because they're hardened, too?
Oooh. So if you can break a tap like that, could you also break an easy out that's snapped off? Because they're hardened, too? Breaking taps out with a punch does work but most times the thread is mullered. Just make sure you have a pair of safety glasses on because the hardened fragments of tap fly everywhere. Best advice for getting easy outs out? Don't get them out the cupboard... Inherently flawed idea at best. Seem like a good idea to screw something into something tight to get it out,when the thing you are screwing in gets tight by tightening up on a taper ,into the already tight thing,forcing it tighter into an already tight thread? Dutch Irish logic at best..... Broken drills and taps can be drilled out ,if you can get the part with the broken tap into the milling machine. Stellite drill,5000rpm and watch it glow as it goes.
