logicaluk
Aug 12, 2016 19:32:02 GMT
Found the missing ingredients Cleft two of the rings in twain Then made some of these Ready to be parred off in the lathe One done Answers on a postcard as to what they are....No, they are not counterweights for a 1/10th scale Wankelling motor... Castor limiters? Or some kind of layflat turney key lervery things Dan
Last Edit: Aug 12, 2016 19:36:07 GMT by logicaluk
Aug 12, 2016 22:11:49 GMT
Lock stays? Turn through 180 degrees one way and they lock a gas bottle or welder in place, turn 180 the other and you can lift said item out?
Darkspeed
Club RR Member Number: 39
Some sort of super elaborate tensioning locking do-dab for the bottle chains.
Aug 13, 2016 14:49:48 GMT
Quick lick of paint after loctiting a grubscrew in And into position,hahaha
Aug 13, 2016 14:54:04 GMT
Holy poo. You certainly don't do things by halves do ya. I am now looking at my welding trolley/table with its welded together furniture tube and thinking it aint that flash. I might have to at least paint it now.
bstardchild
Club RR Member Number: 71
Holy poo. You certainly don't do things by halves do ya. I am now looking at my welding trolley/table with its welded together furniture tube and thinking it aint that flash. I might have to at least paint it now. It certainly sets the bar fairly High!!!
Aug 14, 2016 10:45:05 GMT
didnt even have to go to vegas
Aug 14, 2016 16:20:22 GMT
Set this lot up first for welding That's where the fun started. Usual story at work that you need to fix a welder before doing a job. The mind boggles as to how that department runs,and the mentality of some of the people in it. A mig welder should sing when properly set up. Like a v12. This was singing alright. It was after all Sunday,so maybe fitting that it was singing a hymn. Fark hymn....300A welder turned up to 9 out of a possible 12,and it pops and farts and barely melts a1.6mm wall tube. Surely the guy using it on Friday might have thought something is wrong? Quick look at the earth showed this Wasn't in the mood to fix it. So plan B to get it to work for me was implemented. Changed back to how it was after I finished,as operator obviously likes his set up...
Aug 14, 2016 16:24:29 GMT
That was plan B. Turned welder back down to 5 and its purring like aV12 again,not like it was earlier where it sounded like half the plugs were missing.
Aug 14, 2016 16:28:07 GMT
Made some oldschool style brackets Looks like someone needs to sort out the JavaScript for loading photos from an iPad to this forum. It's got progressively worse the last month or so......
Wilk
Aug 14, 2016 16:28:17 GMT
Lol, nice one. Some folk make you wonder how they co-ordinate enough to be able to breathe
Aug 14, 2016 16:30:08 GMT
Looks like I might have the Australian version.... Welded the chassis together and the two rings
Aug 14, 2016 16:31:37 GMT
Sorted out the top plate
Aug 14, 2016 16:48:14 GMT
Made some little brackets,welded them in and then that was that. Fabrication finished. Put it all together. I am happy. Oh, look....
Aug 14, 2016 16:50:42 GMT
Suppose some of you want to see it then? Hahaha
Aug 14, 2016 16:51:40 GMT
Aug 14, 2016 16:57:08 GMT
At least my days of fixing welders before use are nearly over. As for raising the bar like Yoeddynz and bastardchild said,about giving theirs a lick of paint. I won't raise the bar on paintwork. Off to strip it down and send it to the powdercoaters....hahaha
Aug 14, 2016 16:57:27 GMT
You can really go off some people. i'm struggling to sort this out ...... ( oh and i'm on I-Pad, seems to upload ok for me?)
Aug 14, 2016 17:19:54 GMT
I worked at a place with may welding sets , about 30 all in , and you might be in a different place every shift . Most always had burnt out earths from lazy buggers .
The best i found was one with a cable with a diameter of 20mm or so shoved in a earth clamp which had a internal diameter of about 30mm . The grub screw obviously would not hold that in so some bright spark had made up the diameter difference by wrapped it in 3M aluminium tape !!!!!!
The thickest of some people knows no limit , especially if they think they can just get through the shift and some other curse word would fix it ! I spent 25 minutes most days filling up water coolers , changing cracked ceramics , pulling out stuck tungstens , swapping dead machings , earth cables , clamps etc .
Do noy underestimate stoopid and lazy ! The best i found was a chap bending welding wire into a weld prep then welding over it !!!
COWBOYS !!!!
