Thanks Joff. I'm actually considering dropping the tank anyway because the top of it was damaged when it was fitted to the car during the engine conversion. There was a very strong smell of petrol in the car and I discovered the cause was 2 holes around the flange for the fuel pump. They appeared to have been made by a chisel which was used to 'cut' a hole in the floor to gain access to the in tank pump! Butchery at its best!
I'll probably fit the normal GTE tank and external pump assembly from the spare car. It'll be a good opportunity to paint the floor and tank too. A job for the winter though.
