^ hopefully not rusty if it's an oddball car. Imagine trying to find a NOS transmission tunnel for something like a 70's Fiat? No chance, guess you'd have to grab anything you can find that's about the right size & shape from a scrapper or Bay'o'E and make it fit. Edit : just noticed you've got a MGB, not sure if you can get new tunnels for them or if you'll have to fit the nearest you can find
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
MOT's and SVA informationmk14dr
@mk14dr
Club Retro Rides Member 85
Apr 14, 2015 11:38:22 GMT
Aren't MGBs separate chassis anyway?
Last Edit: Apr 14, 2015 11:38:32 GMT by mk14dr
bstardchild
Club RR Member Number: 71
MOT's and SVA informationbstardchild
@bstardchild
Club Retro Rides Member 71
Apr 14, 2015 11:57:32 GMT
Aren't MGBs separate chassis anyway? Not as far as I am aware - monocoque
Apr 14, 2015 12:15:13 GMT
Aren't MGBs separate chassis anyway? mga is seperate chassis mgb is not
mk14dr
@mk14dr
Apr 14, 2015 12:17:32 GMT
Aren't MGBs separate chassis anyway? Not as far as I am aware - monocoque Hmm, I'd never even given it a second thought before, I'd always just assumed. What of the ones with MX5 gear under them? Are they essentially double chassied?
bstardchild
@bstardchild
Apr 14, 2015 12:38:28 GMT
Not as far as I am aware - monocoque Hmm, I'd never even given it a second thought before, I'd always just assumed. What of the ones with MX5 gear under them? Are they essentially double chassied? MX5's are moncoque too
Apr 14, 2015 13:02:42 GMT
Hi, mk14dr is talking about the MG LE50 Which is not separate chassis it just has the Mazda 2 litre engine and box fitted with modified suspension.
Colin
mk14dr
@mk14dr
Apr 14, 2015 13:10:35 GMT
I'm sure I've seen MGBs and maybe Heralds converted to MX5 running gear with a sort of backbone chassis from under an MX. Or have I imagined that whole thing?
Nathan
Club RR Member Number: 1
MOT's and SVA informationNathan
@bgtmidget7476
Club Retro Rides Member 1
Apr 14, 2015 13:22:13 GMT
I'm sure I've seen MGBs and maybe Heralds converted to MX5 running gear with a sort of backbone chassis from under an MX. Or have I imagined that whole thing? Yes that's been done a few times, however with the SVA I have not seen any recent projects in fact I measured it up when I did my conversion. However Frontline to a bolt on kit for the rear now, so how that get's around the issue I don't know. Myself I just put the Engine and box in my GT, the rest is just polybushed MGB stuff etc.
Apr 14, 2015 13:22:44 GMT
What about additions to body shells? Wide body kits e.c.t?
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Apr 14, 2015 14:49:54 GMT
Heralds do have a separate chassis and so just come under the '8 points rule'
MGB's would also come under this rule UNTIL you alter any structural part of the monocoque. If any conversion parts fitted simply bolt on to original mounting points, then no issue.
If the wings are bolt on, then there's no real issue regarding arch kits etc afaik
