zook71
Sept 30, 2016 7:22:49 GMT
Re the tar, depends what Avgas you're using. Naphtha based ie Jet B & the smells not too bad, Kero based ie Jet A & it reeks. Whatever you use make sure you're well ventilated, no egg sucking lessons here, but I work in a kero plant & the stench of it in close quarters makes me want to hurl. Note to myself, good career choice ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
1974 Triumph 2000
ivangt6
Club RR Member Number: 132
Triumph GT6ivangt6
@ivangt6
Club Retro Rides Member 132
Sept 30, 2016 20:34:10 GMT
Re the tar, depends what Avgas you're using. Naphtha based ie Jet B & the smells not too bad, Kero based ie Jet A & it reeks. Whatever you use make sure you're well ventilated, no egg sucking lessons here, but I work in a kero plant & the stench of it in close quarters makes me want to hurl. Note to myself, good career choice ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Avtur F34. Kerosene based. Removes old sticky hyd oil pretty well so I'm hoping it should work. Completely forgot to get some though. I'll just have to get more thinners. It seemed to eat my gloves quicker than avtur anyway. That or grind whats left away
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
ivangt6
Triumph GT6ivangt6
@ivangt6
I have gas!(snigger) Only got it midday today though so not much welding has occurred I'm still chasing the rust back but I think or hope I've hit solid metal The inner arch has had to come off and a lot of filler has come off around the arch strengthening panel. Originally this is where the rear shock mounted. This as torn off like they all do and has an MOT looking patch covering half of it. It looks like it's been put on with an oxy acetelene welder and I'm pretty sure its hiding the rusty remains of original steel underneath. It's coming out. New panel ordered ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0250_zpsih6adsmc.jpg) Until that gets here I want to sort the rear of the inner wing. Cue more rot chasing ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0251_zpsxzzwdazl.jpg) And new steel. ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0252_zpsluxl76gk.jpg) Looks like I'm going to be chasing the rot all round the wheel tub Might get some more done tomorrow. Depends on what her indoors has planned for me There's always bloody something....
Last Edit: Oct 8, 2016 19:46:49 GMT by ivangt6
Good work , thats a proper job you can be satisfied with , you know you are doing it all properly . Keep these photos for if you ever sell it !
ivangt6
Triumph GT6ivangt6
@ivangt6
Good work , thats a proper job you can be satisfied with , you know you are doing it all properly . Keep these photos for if you ever sell it ! Cheers. I had no idea the car was this bad. A gearbox swap seems to have turned into a semi restoration!
Well i my self always have that nagging feeling with cars that something i have not investigated is festering away/about to go pop etc so you will know its not going to unexpectedly fail a mot or burst out in rust scabs !
ivangt6
Triumph GT6ivangt6
@ivangt6
Cars from this age are definitely prone to it regardless of the manufacturer. Plenty of rust traps, unpainted bits and the age of it. This one is 44 years old now so its not doing badly really
ivangt6
Triumph GT6ivangt6
@ivangt6
Oct 10, 2016 20:11:25 GMT
tiny bit of progress from sunday ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0255_zpsn8tneqvx.jpg) ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0254_zpskrhcbjvr.jpg) chipping away
Last Edit: Oct 10, 2016 20:12:35 GMT by ivangt6
ivangt6
Triumph GT6ivangt6
@ivangt6
Oct 22, 2016 22:21:43 GMT
Managed a small amount today in between the rain. Really struggling with the weather at the moment ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0265_zps0gfz7smi.jpg) So thats the boot solid again. Now onto the inner wheel arch ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0266_zps48jfsrvh.jpg) ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/DSC_0268_zpsbjjmfvmf.jpg) And thats as far as the weather let me go unfortunately. Hopefully it stays dry tomorrow as I could do with letting the car and cover dry Why has the summer gone?
ivangt6
Triumph GT6ivangt6
@ivangt6
Jan 22, 2017 15:32:10 GMT
Its been a while since my last update. My phone oil soaked, weld splattered phone decided it had enough so I haven't been able to take any pics. So last update I was chasing rust around the inner wheel tub. I would have definitely been better off replacing it. It would have been a lot quicker and easier. Anyway. Most of the area mating the inner wheel arch to the floor got replaced along with what was left of the metal festering under a couple of big MOT patches inside and out where the original shock mount would have been(GT6 rust trap). An awkward compound curved panel it wasn't easy to make and its a bit wobbly as you can see from the inside picture. After that a reinforcement panel went on and then a new lower seat belt mounting point for inertia reel seat belts. ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143638_zpsqucylsu5.jpg) ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143616_zpslp5thak6.jpg) Next up was to recreate the mounting point for these brackets in the boot. they're fairly thick so I presume there some sort of crash protection? Originally they'd bolt to the bumper. Managed to get all the tar out eventually with a heat gun and rag. Just needs seam sealer now. ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143625_zpsk7yet2lh.jpg) That done, on to the other side which I thought was in better nick MOT patch on inner arch ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143653_zpslk4jawms.jpg) Hole ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143705_zpsgb0znr6x.jpg) Hole ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143713_zpswhxszdfj.jpg) So having established that I got on with removing the wing, which I was able to mostly pull off by hand. This blokes welding is horrendous. And surprise surprise another tacked on inner wing repair ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143724_zpsk7smyztu.jpg) And worse than that there's this outer wheel arch which I'm removing with nothing more than a screwdriver. It may as well be blu-tacked on. This outer wheel arch is actually part of the inner wing pressing so this repair panel should be seam welded to the inner wing AND spot welded to the inner arch tub. Essentially this is just floating there. ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143731_zpslkjfg4r5.jpg) Some more zero penetration pigeon wibblepoo welding to the rear of the sill ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143741_zps8j0egxvy.jpg) On the subject of sills, I could never get the drivers side door gaps right at the front Passenger sill ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143822_zpslco1ndpk.jpg) Drivers sill ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143837_zpsfka3qovr.jpg) Using the door hinge mounting points you can see the sill below is further forward on one side. I believe the passenger side sill is in the correct place. However the welding done on both is awful and they're bound to be hiding rot so they'll be coming off Looks like I need to order some more cutting discs. I'm hoping by the end of this week I might be able to get a better place to work on it too. As a side project I'm in the process of turning this ammo tin into a workshop radio. Should be able to do it with a 12V battery, car radio and speakers. Because what I need now is another project apparently ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_140909_zpsemqnxjji.jpg) Cheers!
Last Edit: Jan 28, 2017 18:24:24 GMT by ivangt6
ivangt6
Triumph GT6ivangt6
@ivangt6
Jan 22, 2017 15:48:53 GMT
Forgot to add this as well. MOT style patch under the master cylinder. Luckily you can get a repair panel that goes right up to the edge ![](http://i376.photobucket.com/albums/oo205/Ivan_Brennan/20170122_143950_zpswhjpxpbe.jpg) The more I take this car apart, the more I quite like the original colour of Emerald Green. Like this It reminds me of Fords Modena Green which I love only this is slightly darker. As for the final picture I'd like to get the same sort of look to this. Loosing the rear bumper really shows of the shape and painting some of the chrome bits black seems to simplify the lines a bit. That and a drop in altitude really transform the car I think
79cord
Not a fan of the blackend chrome personally unless ALL chrome is done, probably even bumpers, but a shame to lose that jewellery. GT6 shape will always look good anyway!
dapser
Very nice looking job you're doing there.
Have you seen the two sets of alloys in your PCD I have in the classifieds?
Might give you the look you're after and at the same time a little different to the more usual minilite replicas.
dapser
ivangt6
Triumph GT6ivangt6
@ivangt6
Jan 28, 2017 18:29:53 GMT
Not a fan of the blackend chrome personally unless ALL chrome is done, probably even bumpers, but a shame to lose that jewellery. GT6 shape will always look good anyway! Yeah I get what your saying. These come with some bits chrome and some bits black though. The trim that goes along the top of the rear wings is black as are some things inside like the gauge trim rings. A lot of the chrome on the car is in poor condition so it makes sense for now to paint some of it black. I'll see how it looks anyway and if looks curse word I'll source decent chrome or re-chrome what I've got
Triumph GT6glenanderson
@glenanderson
Club Retro Rides Member 64
Jan 28, 2017 22:59:06 GMT
I've always preferred the look of the rear ends on the Mk 1 & 2 GT6s (and the 1, 2 & 3 Spitfires), and have never been a big fan of the seventies restyle that all the Triumph range got with the squared off rear end; but that Mk3 looks good without the bumper. Very "purposeful".
Keep it up, it'll soon be summer!
dikkehemaworst
Club RR Member Number: 16
Triumph GT6dikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
Man your persistant. And Great metalskills. All the luck
MK2VR6
Mk2 Golf GTi 90 Spec
Feb 11, 2017 13:33:51 GMT
Bloody hell, this refurb looks to be getting rather involved! Great work though, and I like the idea of returning to emerald green. Personally speaking though, the mk3 is perfect in red, with bumpers retained. Keep going!
Feb 11, 2017 20:25:23 GMT
I like the later Spitfire & GT6's and the black trim looks good. I like bumper less cars but if it was me I would fill and smooth the bumper mounts but the car looks great. I love the colour
cap78
Feb 11, 2017 22:30:39 GMT
Why haven't I noticed this thread before?? Brilliant read, but not so brilliant the work from previous owner, jeeezzzz, that would not end well in a crash! Keep up the good work fella
Feb 12, 2017 14:00:16 GMT
Fantastic work going on there, thanks for the pics and words !
1994 Mercedes e220 petrol estate, daily driver. 1998 Peugeot 406 Coupe 3.0 v6, shopping car.
