edk83
The braided lines are all the Teflon type so completely sealed. I do have about a foot of rubber braided but that's in the engine bay Up yours Photobucket! I should have moved to flickr sooner.
edk83
Jun 30, 2017 17:33:04 GMT
Happy days! The garage makes it sound like a tractor and the phone can't handle it lol
Jun 30, 2017 17:41:44 GMT
Wow really getting there now.
jamesd1972
Club RR Member Number: 40
Jun 30, 2017 18:14:30 GMT
Whoo and indeed hoo ! Sweet
edk83
Just had it running again with a remapped ecu, sounds even better and idles better. Started stripping my other donor zr this morning.
edk83
I'll have to go through all the photobucket images and swap to flickr. Annoying.
On a brighter note my spare engine is almost ready to lift out my other zr, what could I park there after the shell is gone? Hmm
Finally got all the engine wiring figured out, it wasn't charging but just needed a live to the alternator via an led to get it going. Also tested the fan works, managed to get obd working just needed an extra earth adding.
Tested the vvc by revving it to 7k, all good seeing as I changed the vvc cam belt along with the main cam belt.
Now to get soldering and mount the Ecu, fuse box etc. Keeping the engine wiring separate from the car wiring, just borrowing couple of live feeds for relays to pass power to the car.
Last Edit: Jul 2, 2017 21:02:01 GMT by edk83
Excellent news! All that electrickery sounds like a black art to me, bit I'm colour blind so I start out at a loss and it goes downhill from there!
edk83
It might not matter with Rover they just used whatever colours they fancied on the day!
It's running at the moment but not very well. I think the o2 sensor in the stainless exhaust I bought is knackered. Getting p0135 on the obd which is front o2 sensor, it's not fueling right when cold so struggles till it's warm.
New on is one order, I did remove the cat and downpipe with a new looking one from my green zr last week but sold it on Saturday. Doh!
edk83
Well that took forever :/
All images now migrated to Flickr
edk83
So had some issues with the K series not fueling right, the ecu reported misfire low fuel and cold starting was not great. Turned out to be a bad 02 sensor (the only sensor that wasn't on the engine when it ran in the blue zr)! I was under the impression the 02 sensor is ignored until fueling reaches closed loop but it defiantly effected cold starts in my case, it could be because the ecu was unable to learn fuel trims. I now have a space on my driveway, the lad helped me lift my spare 160 engine out today and the shell was collected by a scrapper, engine worked out pretty much free This afternoon I was on baby duty while the mrs was out, needed somewhere to put all the stickers that came with parts I've bought and the rear / boot area sealing panel is galvanised so didn't like paint sticking to it, now looks like this
edk83
Got all this lot mounted today, one good thing about the Allegro is there is lots of space around the inner wings. Wiring is still all in the engine bay with just a switch and a button, now things are mounted I can get routing it.
Jul 16, 2017 21:07:00 GMT
Excellent news! All that electrickery sounds like a black art to me, bit I'm colour blind so I start out at a loss and it goes downhill from there! Do what a friend did some years back, he just used blue :-)
Jul 16, 2017 21:08:16 GMT
Got all this lot mounted today, one good thing about the Allegro is there is lots of space around the inner wings. Wiring is still all in the engine bay with just a switch and a button, now things are mounted I can get routing it. Jealous about all that space! :-)
edk83
Yes it's not bad at all, problem is I have no excuse for it not being mega neat lol.
Did almost 8 hours on the wiring this weekend, it takes sooo long! Garage wall now plastered in wiring diagrams, most things now tinned up with solder. Ran out of heatshrink and wire. I've ordered 3 of the ebay led blade fuse boxes, the nasty old glass fuses will not be going back in.
Last Edit: Jul 17, 2017 9:48:13 GMT by edk83
edk83
Fitted new handbrakes cables, lots of wires tinned up but run out of heatshrink! Some bedtime reading on my garage wall
Jul 18, 2017 10:41:35 GMT
What's wrong with glass tube fuses? BMC cars only need two fuses after all. One for things that work all the time and one for things that only work with the key on.
Jul 18, 2017 10:52:53 GMT
BMC cars only need two fuses after all. One for things that work all the time I'm not sure there are any BMC cars where things work all of the time Cracking build this, nice to see a properly sorted Allegro.
Jul 18, 2017 11:11:48 GMT
curse word.
Jul 18, 2017 11:12:38 GMT
The automatic censorship on this forum sucks yak balls big time.
edk83
Jul 18, 2017 15:17:57 GMT
What's wrong with glass tube fuses? BMC cars only need two fuses after all. One for things that work all the time and one for things that only work with the key on. Not far off, the car had 5 glass fuses
I'm having 3 fuse boxes, 2 ignition switched with a relay each and one always on.
