Jan 17, 2016 20:52:40 GMT
Feb 18, 2016 17:10:48 GMT
MK2VR6
Mk2 Golf GTi 90 Spec
Feb 25, 2016 20:47:42 GMT
Looking good. I spotted your ad on eBay for it the other day. Possibly not the best time of year to sell! Looks lovely all the same.
Feb 25, 2016 21:57:37 GMT
I am going to start this post with an example of my stupidity. Sunday morning I rushed out and bought my Mum some flowers for mothers day. On the way home I stopped for petrol and as the sun was splitting the sky I decided to put the roof down.......Pity I had forgotten about the flowers on the back parcel shelf! Heres what I saw when I turned round to reverse into my space What a tit! At least the outside still looks good, even in the scarier parts of Glasgow. derelict 3 by Dave Campbell, on Flickr Dave.
May 16, 2016 18:55:08 GMT
Been a while without updates as all I have been doing is driving the car. Biggest bill since last update has been insurance which thankfully was only £130. We had some sunshine here over the weekend so me and the Mrs went to a car show in Stirling and on the way back took a blast over the A821 (Dukes pass) from Callander to Aberfoyle, one of the best roads in the world. The Dukes pass by Dave Campbell, on Flickr The Dukes pass by Dave Campbell, on Flickr The Dukes pass by Dave Campbell, on Flickr The Dukes pass by Dave Campbell, on Flickr In other news, its MOT time this week. From what I can see the offside front shock looks damp and there was something greasy on the nearside front wheel after the run over the pass so might be a ball joint/ track rod boot or CV joint boot away. Dave.
May 19, 2016 13:55:18 GMT
MOT results are in. One leaky front shock. Think I can deal with that :thumbs:
May 19, 2016 18:10:38 GMT
Love those photos! Living in the South East I miss that kind of driving...
Friend of mine used to have a white Clipper, really did covet that car. Nice work on the MOT too!
May 23, 2016 21:18:02 GMT
Sept 13, 2016 20:59:16 GMT
Finally I have a substantial update to the thread. Parts arrived today to fix the fuel filler pipe rust so first part of the job was to get fuel out of the tank, especially as I filled it on Sunday before finding the rust; Using this wee pump syphon I managed to get 30 litres out; With the rear offside wheel off I could get a proper look up into the wheel arch. From here you can see why I missed the rust. Still looks OK from here but on closer inspection the breather pipe is no longer connected to the filler pipe as the union has rusted through; So its time to remove the steel filler pipe. Step one, remove the sticker covering the three screws around the filler and then remove the screws; Step 2, further down the pipe is a 10mm bolt holding the pipe to the inner wing; Step 3, remove the jubilee clip holding the rubber pipe to the metal filler neck. The clamps here will probably be seized so have new clamps ready and if the rubber hose is damaged or perished, now is a good time to change it (I had a new one from VWHeritage but it wasnt long enough so re used the rubber pipe that was there). With the filler neck off the true extent of the rust can be seen; What was also obvious was the reason for it rusting out. The area around the top of the pipe was absolutely caked in dirt, most of which went up my sleves and in my hair but some made it to the ground; The filler neck I ordered was for a saloon as it was less than half the price of the cabrio version. With the old and new side by side you can see the difference; The way to modify the saloon pipe to fit the cabrio is to mark the length of the old on the new then cut off whats not needed; (there are some sellers on ebay charging over £100 for cabrio pipes that are sold as "genuine modified saloon filler pipes to fit clipper". Avoid these unless you want to pay over £60 for somebody to cut the end off a pipe). When refitting, you will need to bend this bracket slightly to make it fit; New jubilee clip on the breather hose; If I had the time I would have given the pipe a coat of paint but as I needed the car mobile again I chose to fit it and coat it with wax and I will keep an eye on its condition; All that was left to do is check everything was done up tight, re-fit the wheel and get the 30 litres of fuel back in the tank. So far I can report that the job is a good one, I just hope there is not a lot of water at the bottom of my tank.
Sept 13, 2016 21:11:11 GMT
They're great little cars which really come into their own on a fine day. A gift to boot! It'll be a cracking car for an enthusiast.
Sept 21, 2016 18:04:19 GMT
I need to be more careful about what I say. Less than a week after saying "finally, a substantial update to this thread" and posting the process of fixing the rusty filler neck I have another pipe to fix on the car. Monday night at 10pm I was on my way back from dropping off the engine for the Beetle at Ed's when my car went from sounding normal to having a rasp. Then it had a rumble followed by a growl and ended up at full on roar within 5 miles on the M77. I made it home and woke up the neighbour hood with the noise and left it to check what the problem was on Tuesday. I had expected to see the joint at the cat hanging down but these were intact. It wasnt until I got right underneath that I found the problem, the down pipe was in 2 parts; So I set about taking the exhaust off. The nuts at the front of the cat were really rusty and rounded off so I undid the nuts after the cat. I then removed the heat shields and guards; This gave me the access to cut the studs and remove the cat but wiith the pipes out the way I had to deal with the dreaded C clamps that were holding on the downpipe flange. Leverage and struggle got the C clamps removed but this turned out to be the easy part of dealing with the clamps. More to follow on that subject..... Pipe and flange in hand (snigger) I could see what went wrong. Amazingly the pipe had split cleanly around the weld line; Normally I would expect to be replacing an exhaust pipe that had split but because the metal was in good order I decided to fix what I had. You can see here the 2 parts sit together perfectly; So I cleaned up the surface at the join; Dug out my welder; And with a zap and a grind it was one piece again; While I had the welder plugged in I quickly added a couple of washers to the hanger bracket as the holes were rusting through; By this point it was 5pm on Tuesday evening and I had visions of glory that the pipe would be back on and re-assembled before dinner........ How wrong was I? An hour of fighting with, swearing at and losing skin on the C clamps it was getting dark and I was thinking of setting the car on fire to stay warm and avoid ever having to deal with the bloody things ever again. I would like to meet the designer of the C clamp down pipe fitting and take a poo in his coco-pops. In a huff and in the house I came across the solution on the Mk1 Golf forum so Wednesday lunchtime I was back under the car and using this solution (I know there is a proper tool but I didnt have one). The C clamp which needs opened out to go over the flange (snigger); The solution, an exhaust clamp; Remove nuts, remove slider, replace nuts and replace the slider upside down and you get this; Insert the high tech C clamp tool inside the C clamp and wind out the nuts to apply pressure to the inside of the clamp; Now the clamp can be fed over the flange (snigger) before releasing pressure on the nuts and the clamp will hold the down pipe. The last sentence sounded simple but in reality with the limited access and the amount of tension on the clamps I think I spent a full hour faffing about with my arms in the air applying skin strips to my engine block. The rest of the exhaust was re-assembled with new nuts and after a test drive I can confirm the car no longer sounds like a WW1 Bi-plane. I will keep an eye on it for a few weeks and if it split once it may well split again but its working for now and didnt cost me anything so jobs a good one. Dave
Dec 13, 2016 22:12:54 GMT
Nothing exciting to report, the wee car is behaving itself and touch wood it will continue that way. Used it at the weekend to go for the tree, infinite headroom has its advantages; Holidays are coming 11 by Dave Campbell, on Flickr Holidays are coming 3 by Dave Campbell, on Flickr That should give me plenty of needles to find through out 2017. Dave
I have let this thread go without updates now for over 2 months for one good reason.......... The trusty wee Golf has been performing its duties without drama through the winter (famous last words). I did however take this amusing picture last week; Odometer palindrome. by Dave Campbell, on Flickr All the while I have been puting the miles on going up and down to the workshop where I am restoring SWMBO's Beetle (which will be getting MOT'd on Wednesday) seats in 6 by Dave Campbell, on Flickr seats in 7 by Dave Campbell, on Flickr Golf at night by Dave Campbell, on Flickr Dave
May 16, 2017 16:45:36 GMT
Today the wee Golf went for its third MOT in my ownership. Not bad for a car I didnt really know I wanted. Only three issues to sort and I am looking for some knowledge if you are able to help I would be grateful, stay tuned. 1st issue is easy. N/S number plate light. Changing a bulb should be a piece of curse word but now I have typed this it will probably be a nightmare. 2nd issue. N/S front spring is broken. I hate working with coil springs but needs must and I have the loan of a proper spring compressor, not the threaded rods of certain death. 3rd issue is the odd one. Rear brake imballance and they are only working at 54% and 32% efficiency. Handbrake is fine so its not the shoes and I replaced flexi lines 3 years ago so thinking I need to swap out the rear cylinders. This is where I need to tap into the collective knowledge. The usual sources are listing 2 types of cylinder. For cars with pressure regulator and cars without. How do I identify if my car has a pressure regulator and could the car have been fitted with the wrong cylinders in the past and this is why the efficiency is low? As said, its not a bad list for another years motoring but whats the betting I order parts from GSF the day before a 50% off weekend? Dave. P.S. I also tried to give the car a coat of turtle wax last week but didnt know which end the wax came from. I turtle waxed the Golf. by Dave Campbell, on Flickr
jpr1977
Club RR Member Number: 18
May 16, 2017 17:46:02 GMT
Last Edit: May 16, 2017 17:46:41 GMT by jpr1977
May 16, 2017 19:58:17 GMT
jpr1977
Last Edit: May 17, 2017 9:43:26 GMT by jpr1977
May 17, 2017 10:03:32 GMT
Thank you for this, I will give that a check when I finish work.
