FOAD
Mar 27, 2020 18:32:14 GMT
I removed the passenger side wing to see how bad it was underneath. DSC_0033 by srblythe, on Flickr DSC_0034 by srblythe, on Flickr Not quite as bad as the other side but still quite rusty. I wanted to get another one ticked off the list so started on the chassis leg. DSC_0032 by srblythe, on Flickr Initially I thought I'd get away with making a small repair section but after chopping the first part out it was clear to see there was a lot more areas needing attention so more chopping unfortunately... DSC_0035 by srblythe, on Flickr DSC_0037 by srblythe, on Flickr I repaired the chassis leg then made another repair section that is to be sandwiched between the floorpan and the inner arch/A-pillar. DSC_0039 by srblythe, on Flickr DSC_0038 by srblythe, on Flickr And that's about as far as I got...
1981 Vauxhall Chevette 1984 Mercedes S123 230TE 1988 Peugeot 305 GR 1988 Hyundai Stellar 1992 Subaru MV BRAT 1992 Peugeot 205 D-turbo 2004 Ford Ranger retroshite.wordpress.com/
FOAD
Mar 27, 2020 19:07:34 GMT
FOAD
Mar 28, 2020 17:42:00 GMT
FOAD
Mar 29, 2020 17:47:40 GMT
Mar 29, 2020 21:51:06 GMT
Do you think it perhaps had a less than rigorous MOT last time or just that everything got to the point where it was no longer pass and advise or hidden with underseal at the same time?
FOAD
Mar 30, 2020 10:53:00 GMT
Do you think it perhaps had a less than rigorous MOT last time or just that everything got to the point where it was no longer pass and advise or hidden with underseal at the same time? RJC_8581 by srblythe, on Flickr RJC_8585 by srblythe, on Flickr RJC_8588 by srblythe, on Flickr RJC_8584 by srblythe, on Flickr RJC_8451 by srblythe, on Flickr This was it a year ago so it was rusty back then but a lot worse now, I think it has deteriorated quite rapidly but also had some very lenient mot's in the past. When I bought the car a year ago I should have been starting this kinda work but instead I chose to enjoy driving it without doing any kind of work to it.
Mar 30, 2020 13:03:05 GMT
Ouch hadn't noticed that crease in the rear above the arch, have you managed to pull it back to get it out?
FOAD
Mar 30, 2020 15:42:16 GMT
Ouch hadn't noticed that crease in the rear above the arch, have you managed to pull it back to get it out? Pulling out a dent is the least of my concerns with this car.
Mar 30, 2020 19:58:14 GMT
I was thinking it might be easier before you put all the strength back
FOAD
Mar 30, 2020 21:50:10 GMT
I was thinking it might be easier before you put all the strength back I'll be cutting out that wheel arch so should make it a little bit easier to straighten.
FOAD
Mar 30, 2020 21:50:24 GMT
Mar 31, 2020 17:09:50 GMT
Blimey - you'll be starting a retro Vauxhall garage soon!
I do like a Shove-it, but also partial to a Subaru - how frilly's the Brat?
FOAD
Mar 31, 2020 19:21:59 GMT
RJC_4829 by srblythe, on Flickr RJC_4830 by srblythe, on Flickr RJC_4832 by srblythe, on Flickr RJC_4836 by srblythe, on Flickr RJC_4845 by srblythe, on Flickr RJC_4849 by srblythe, on Flickr RJC_4864 by srblythe, on Flickr RJC_4866 by srblythe, on Flickr RJC_4867 by srblythe, on Flickr RJC_4869 by srblythe, on Flickr RJC_4870 by srblythe, on Flickr RJC_4871 by srblythe, on Flickr RJC_4872 by srblythe, on Flickr RJC_4876 by srblythe, on Flickr I paid near enough £700 for that! I need to get my head examined!
Mar 31, 2020 19:24:51 GMT
I think I may have cried if I paid 700 for that, you're doing well on the blue one but that gold one is proper grotty...
FOAD
Mar 31, 2020 20:40:36 GMT
I think I may have cried if I paid 700 for that, you're doing well on the blue one but that gold one is proper grotty... I knew it was going to be knackered but It's a great source of spares. I needed headlights, steering rack, bumpers, fog lights, front end, engine, gearbox, mirrors, carpets and a bunch of other tat for the blue one so can almost justify it.
FOAD
Mar 31, 2020 21:29:31 GMT
That looks like it's been swimming! Well, if you think about what the cost for all those spares would be if you got them separately...
FOAD
One of the heaviest things I've lifted, I managed to move a Vectra v6 with most of its ancilliaries on my own into my garage, my bro bought a spare 1256 for his Chevette, took 2 of us, no wonder they were slow
FOAD
