May 19, 2007 19:45:09 GMT
Yea, well aware of that btw - hence me saying along those lines, was just one of those things that might be oddball in a motor's components if you don't really know it's history
v8ade
May 19, 2007 20:00:58 GMT
what should the gap be do you know? I think I will have to strip it back down again tommorow and try it You need to speak to Nightmares really.... What V8 is it ? What Pistons ? Piston manufacturers website should have ring gaps thinking about it its a ford 351 windsor with forged trw pistons
Last Edit: May 19, 2007 20:42:29 GMT by v8ade
V8 on open headers at full throttle "Heaven"
Jaguar xf SportBrake rover 820 Turbo vitesse
May 19, 2007 23:04:57 GMT
from memory should be 0.005" per inch of bore +0.001"
v8ade
May 20, 2007 10:44:41 GMT
from memory should be 0.005" per inch of bore +0.001" got the pistons out ring gap is .65 mm i only have metric feelers which i think works out to 0.025" which i think is about right you still have to knock the pistons down the bores with a rubber hammer is this normal on a rebuilt engine ? the rings seem very stretched open nearly wider than the piston itself and they have to be squashed in quite a bit to get them in the bores is that normal ? can you tell i never mess with engine internals normally?
May 20, 2007 22:25:57 GMT
yes all normal 0.025 sounds about right for a 351
v8ade
took the engine back to pieces the crank spins freely and the big ends on the crank are free running to, its deffinatley the pistons in the bores that are holding it back it will know turn with a ratchet on the front pulley though so I'm going to get a high torque starter and give it a wizz and see what happens.thanks for all your help
remember that with forged pistons you should have a little more "slack" than with cast ones as they expand more when warmed up.
I'm concerned if the starter motor won't spin the assembly with the heads off!
Measure everything I think something's tight...
