vulgalour
Club RR Member Number: 146
The box on the driver's side collapsed, which allowed it to all come out by dropping the wheel what little it will when you unbolt the supporting bracket. Unfortunately, now the box is repaired we can't put the dash back in the same way it came off and you can't fit the box when the dashboard is in situ because you can't access the fitting screws.
It's one of those awkward things where it all needed to come apart to be sorted out anyway so there was no avoiding it, and a lack of experience has meant it's proving a little tricky to put back together. Also, now that we've ruined all the brass screws we got to dismantle everything to fix that anyway. Furthermore, it's likely this all had to come out for the new wiring loom too so we don't think any of this was really avoidable as a job.
stevek
Yorkshire and The Humber
I’ve been away from the forum for a few years but it was a lovely surprise to see your ‘new’ Lanchester when I returned, it took me about a week to catch up but it was a good read, you’ve done it proud. I’m glad to report you hold your self well infront of the camera! Tricky filming that linkage detail but I got the gist of it. I was sort of expecting a top hat and Victorian collar but some red chinos will do 😉, smarter garage attire than 99.9% of the population!
-Steve-
vulgalour
Oct 16, 2020 23:27:55 GMT
OMGHGF happened a month ago. I still have no desire to do the job, and since I've had the time to really think about things I've decided to decline the offer of help to just swap the head gasket etc. in favour of getting the engine fully rebuilt. A little drastic, perhaps, but there's good reason for it. The engine has always consumed a little oil and that consumption has been steadily increasing so something is worn out somewhere. The head gasket issue has really knocked my confidence in my own abilities a lot and since engine work isn't something I enjoy to begin with, you can well imagine why I don't want to venture back into it. Also, if I give the engine to someone I can trust (someone I trust has offered to help when he's able) then that takes some stress out of the whole endeavour.
Since I'll also be repainting the car when the weather allows - paint, brushes, and sundries are all got for the job now - it will be alot easier to get a nice finish in the engine bay if the engine isn't in there.
Other big expenses are the suspension regas that I cancelled the booking off when OMGHGF happened, and a new windscreen to go in with the new windscreen seal I STILL haven't fitted.
My goal at the moment, at least, is to finish the existing projects before starting new ones and since I can get by with lifts from the other half and my own legs, I can live without a car of my own for a few months I reckon. It's annoying, but at the end of it I should have a nice car I like a lot. If all else fails, work on the Lanchester will be progressing alongside this anyway and if it's ready before the Princess is then I shall just use that instead.
There's also the engine I was linked that's basically new. If I go that route it would want to be inspected anyway to check it was good, engines and storage don't make good bedfellows after all, so it might be better to stick with what I've got and repair it if possible.
I think that I’d buy the new engine...
Oct 17, 2020 13:16:18 GMT
The thought here is why did the car survive in the first place? It was parked up when it was in relatively good condition, and for why?
There's the potential for an inherent problem (porous casting, crack etc) that's not made itself visible that has plagued that engine in a minor but persistent way.
If you have the option for a replacement with few miles on, I would say jump at it. Dropping a new engine in and giving it a try is easier than pulling another apart at fractions for an extended period while it punctuates actually being able to use the car.
Yes, you put work into that one but possibly it's time to throw in the towel on the headaches it's caused and just drop another one in and see what happens.
Phil
Last Edit: Oct 17, 2020 13:16:34 GMT by PhilA
vulgalour
Oct 17, 2020 13:44:20 GMT
Storage is the next issue. If it weren't for the Lanchester I could just use the garage, as it is the garage is properly full and I haven't got the space for the spare engine let alone the crane and possibly stand I'd also need. Hiring/loaning tools isn't something I want to do either, I'd rather buy them and then I have them if I need them in the future.
I suppose if I get the new engine, fit it, and just hope for the best I've always got the old engine to fall back on as a spare and the old engine can be pulled apart, inspected, and rebuilt at leisure that way, ready to go back in should it need to be in the future, or even into another car since I'm not ruling out ownership of another wedge at some point in the future.
At least I know the gearbox is good, so that's one thing not to worry about, though manual Princess gearboxes rarely cause problems anyway, they seem to be fairly robust.
Oct 17, 2020 13:55:26 GMT
Do the engine in the living room, nice & warm in the winter that way Seriously, buy the new engine & drop it in.
Oct 17, 2020 14:40:53 GMT
Yup. That gives a spare, a source of spares, a chunk of change to the scrap man or eBay. Engines by themselves aren't huge and tuck into corners out of the way.
Phil
vulgalour
Oct 18, 2020 12:39:08 GMT
Another NOS 1700 engine has appeared. This time more locally than the other supplier so much easier to go and collect: www.ebay.co.uk/itm/Morris-Marina-O-Series-Engine-s-Naylor-MGTF-1700CC-New-N-O-S/274536318338 As far as I'm aware, the only difference between this and the Princess engine is the sump since the Princess keeps the gearbox in there while the Marina has the more conventional kind. I shouldn't need any adaptors for connecting the clutch housing bit on the Princess, I should be able to just swap the bits off my engine and stick them on this one. Space for the engine has been found in the garage, just, it's amazing what you can make space for when you really want to, I just don't have an engine crane so will likely have to rely on grunt for moving this about until I'm ready to fit it. Puts me back to square one saving for the suspension again, which is a bit annoying, but I could potentially have a sorted engine at the end of it so it'll be worth it. I've no idea if the listing start price is fair or not, it seems reasonable for a whole unused engine to me and I'm willing to pay that so it probably is.
Oct 18, 2020 13:12:22 GMT
I'd offer £500 see if it gets it for you.
Oct 18, 2020 14:59:13 GMT
I'd agree offer £500 they have 2 to get rid if and there can't be that much demand. At the end of the day you are taking a risk, it might be perfect on the other hand it's probably been in storage for 30+ years, at the very least I expect the rubber seals to need replacing.
80kg is pretty easy for 2 of you to move around if you can get some sort of trolley even better, last week I was easily pushing a land rover series engine around on a dolly and they must weigh a couple of hundred kg.
Oct 18, 2020 15:06:16 GMT
With wheels, that'd move easily.
Suggestion would be of its not too far and you've got a vehicle with a low load bed, haul it with that rather than have it shipped, or see if someone you trust can do it, because that would need to be strapped to a pallet to be shipped properly.
vulgalour
Oct 18, 2020 16:00:15 GMT
I do have a new head gasket set, new cambelt, fluids, etc. which was got for redoing the original head/engine so I can just use those on this one.
Rubber bits are, as far as I'm aware, restricted to valve stem seals, camshaft seal, crankshaft seal, auxilliary and camshaft belt, distributor o-ring, and oil filler cap o-ring. This engine uses the earlier cap and the square profile rubber seal in the cap needs replacing every X miles/years, my engine uses the later 'mushroom' filler neck and cap and they aren't so prone to the o-ring failing. It having the earlier style oil filler is actually something I prefer because it looks tidier so that's a bit of a bonus, even if the later design is better in practical terms.
A trolley should be easy enough to get hold of at least, we've got a wheelbarrow which would do in a pinch, but a little pallet with wheels on or something like it would be better. Shall have to see what we can scrounge up from odds and ends I guess.
Oct 18, 2020 16:12:09 GMT
I think I know where there is a 1700 marina engine. Its near Preston though but I bet its cheaper than 500. www.minitech.co.uk/. I spoke to Craig that owns it a few weeks ago. This car had been placed on top of a tower as an advertisement for a scrap metal place. Craig got the car and got the engine running. He may crate it to you. Worth a call tomorrow anyway.
jamesd1972
Club RR Member Number: 40
Oct 18, 2020 16:18:12 GMT
If you get a spare engine worth making a frame to store it - the LR engine can only be described as bloody heavy but the frame with some wheels on one end and a sack truck on the other it was OK to move about. Good luck with getting a good engine. James
vulgalour
Oct 18, 2020 16:28:16 GMT
I think I know where there is a 1700 marina engine. Its near Preston though but I bet its cheaper than 500. www.minitech.co.uk/. I spoke to Craig that owns it a few weeks ago. This car had been placed on top of a tower as an advertisement for a scrap metal place. Craig got the car and got the engine running. He may crate it to you. Worth a call tomorrow anyway. Given the option, I'd rather spend more and get a new engine, it feels like a safer bet even if it's more pricey, and Buckingham is considerably closer and easier to arrange the logistics of getting the engine here than Preston is. A used engine is probably fine, it just feels like a bigger gamble to me when there's the option to get a new one.
Oct 18, 2020 17:15:47 GMT
Lidl and Aldi both regularly have little trolleys. I have one that currently has my ZF lorry gearbox sat on it. It’d manage a Marina/Princess engine no bother. link
Oct 18, 2020 17:23:18 GMT
Furniture dollies work well. Larger rubber castor wheels, a decent strength and carpet to soak up the oil*. They're often cheap, or are pretty cheap to make up. Ratchet strap stops it from falling off.
Phil
Oct 18, 2020 17:31:08 GMT
80kg would even go in a skateboard!
logicaluk
Oct 18, 2020 20:06:18 GMT
80kg would even go in a skateboard! I keep a skateboard in the workshop for just this sort of job, just tighten the trucks up first. Dan
