Nov 24, 2018 11:12:48 GMT
I know exactly how you feel. I have that itch too lately.
Wrote a long post here which didn't seem right to bomb your thread with so I'm off to TNC now to re-post it there.
vulgalour
Club RR Member Number: 146
Nov 25, 2018 14:20:54 GMT
A non-picture update on things.
The Princess had lost all but the weakest and most intermittent spark recently which meant it wouldn't start. Initial testing made it seem the condenser was at fault and, having had issues with poor condensers, it seemed sensible to replace that. However, on fully removing the condenser in readiness for replacement, the earth wire inside the distributor decided to part company with one of the eyelets. The wire, which had been replaced many years ago to replace the bare wire wrapped in electrical tape the car came to me with, had gone brittle and fractured right at the crimp. This meant that the earth connection was incredibly poor. Over time, this has steadily been getting worse and visual inspection had revealed nothing amiss, the symptoms manifesting as though other parts were at fault.
The solution was simply to replace the wire with new. I'd already bought a replacement condenser but rather than fitting that straight away, we put the new wire and the old condenser back on just to be sure it's not the old condenser at fault. Happily, the old condenser is fine and the car starts quite willingly now. There's also no sign of the occasional stutter/stumble that's been bothering the car for the last year or two and that I couldn't track down so I suspect that's also been due to that poor earth wire.
I shall continue to monitor the situation, hopefully this has resolved the issue.
Nov 25, 2018 15:05:15 GMT
Bitter experience has taught me that wire is often the hidden culprit in mystery misfires.
Nov 26, 2018 12:05:07 GMT
i know people balk at the thought of going electronic triggering, non original and all that, nowt wrong with well setup points etc etc. but its literally one of the best things i have done to both land rovers. owned them for a combination of 8 years now, never touched the ignition for maintenance once after installing them.
Last Edit: Nov 26, 2018 12:06:03 GMT by darrenh
vulgalour
Nov 26, 2018 15:14:07 GMT
Yeah... but I sorted this out for free so...
vulgalour
Nov 29, 2018 19:57:40 GMT
I had been, and still am, considering moving the Rover on. However, I'm being sensible. Sort of. I've decided to use the Princess as my only car for as long as it permits, or for as long as I want it to be my only car. Should I want, or need, to use the Rover within the next 6 months then it will get to stay. If I go 6 months without stepping foot in the Rover well, it'll be time to move it on.
25th of November was the official start point of this experiment, purely because it's a point at which everything on the car is working as it should so seemed a sensible point to begin the experiment.
So far, it's going very smoothly, as you might expect in the honeymoon period. I haven't yet dreaded getting in the car, no matter what the weather is doing. I do have some observations.
- Starting. Since replacing the earth wire, the car now starts, idles, runs, and generally behaves much better. The occasional stutter/stumble thing it was doing it no longer does. Less throttle is required to make progress and to accelerate from a standstill and a very quiet tick I couldn't place beyond 'the top of the engine somewhere' is now gone. Perhaps the tick was the old earth wire sparking out and earthing where it shouldn't, perhaps it's merely coincidence.
- New tyres are amazing. They're the best I've ever driven on and I don't feel like I've even come close to their limits. I'm continually impressed with them, especially in the rain.
- Oil pressure switch I replaced has cured an oil leak. Previously, I wasn't entirely certain if it was the cause of the oil down the belt side of the engine, now I am, because that side of the engine and the driveshaft are all oil-free. I'm pleased about this as it means I'm losing less oil than I was.
- Brakes are good. However, the braking habits of other drivers aren't so much. I find myself driving slower than I might normally because of how unpredictably, and how quickly, other drivers stop. The plus side to that is it means I'm paying a lot more attention when I am driving and therefore driving more defensively which has meant I've avoided situations that may have become a close call, or worse.
- Island style speed bumps are less of a problem because of the width of the Princess, in most cases the track is wide enough that it's like they're not even there. Bar type speed bumps are a little more annoying, especially the ones with a harsh drop off and rise, but no more so than in any other car.
- I feel generally less vulnerable and more visible to other road users than I do in the Rover. This in turn makes driving considerably more relaxing.
So now the problems, since I can't pretend it's been entirely plain sailing.
- My old regime was to check the fluids once a week or every 100 miles, whichever came first. Because the Rover never needed this attention, I'd slipped to a more loose once a month or every 500 miles and that doesn't stick with the Princess. Today, the gear change was notchier than usual and reverse became difficult to select when the oil had warmed up and on checking, the oil was barely at the bottom of the dipstick. Thankfully, a glug of fresh oil resolved this. I suspect the car is consuming a little oil, though not alarming quantities, and I know there are still oil leaks I haven't been able to find the source of. I suspect one or more of the gaskets that were replaced when we did the clutch are the culprit since the minor leak I do have is on that side of things, it's just proving difficult to find since it takes a while to manifest. I shall continue to monitor the situation, at any rate.
- Sidewinds are tedious. It can be easy to forget how much power steering compensates for small corrections, so you are more prone to a little bit of lane wandering when it's as windy as it's been today.
- Although there's no noticeable coolant usage, I did notice a very small spot of coolant under a pipe join today. It's something to monitor, the one spot wasn't even enough to constitute a weep, let alone a leak.
- Parking is still a chore. The biggest issue I face here is no longer the lack of power steering. The combination of the Princess' C-pillar blind spot and the sheer bulk of modern cars causing big visual obstacles can make reversing out of a parking space a bit of a gamble, especially when other drivers seem intent on paying no attention whatsoever to a car slowly exiting a parking space. The bodywork on most modern cars is so high that I can't simply look through the cabin of neighbouring vehicles to see if it's safe to exit a parking space, so it has to be done with caution.
That's it. Overall I'm quite happy to hop in and use this car. The biggest problem I encounter on a daily basis really is other inconsiderate road users, the sorts everyone else encounters too. If anything, being behind the wheel of the Princess again is making me think a lot harder about hazards and driving and, I hope, making me a better driver in the process.
Nov 29, 2018 20:10:50 GMT
Start making it a habit to reverse in to parking spaces, rather than out. Occasional awkwardness getting stuff into the back of the Land-Rover is a small price to pay for being able to see when I leave.
Nov 29, 2018 21:51:51 GMT
I must admit I nearly always reverse into parking spaces - its easier. Seems to be a lost art with modern drivers though.
Nov 29, 2018 23:32:52 GMT
And I must admit that I have a wife who does internet shopping from Ocado ('cos we is dead posh and everything) so parking isn't a problem. Not for for me anyway. Bloke with the van dropping my tinned beans off might think differently!
vulgalour
I do keep an eye out for 'drive through' spaces when parking. It's not always an option and sometimes, like today, you can't reverse into the parking bay because of how it's laid out. Exercising caution is usually enough, and if someone is daft enough to walk behind your car while it's moving, and paying more attention to their phone call than their surroundings, a prolonged lean on the horn is sufficient to really fox-picture them off. Which is gratifying in a childish sort of a way.
MiataMark
Club RR Member Number: 29
Nov 30, 2018 17:49:11 GMT
Start making it a habit to reverse in to parking spaces, rather than out. Occasional awkwardness getting stuff into the back of the Land-Rover is a small price to pay for being able to see when I leave. Reversing into parking slots (not parallel parking) was recommended to me as a personal safety thing, if you're being chased you have the car door between you and your attacker and can also exit the space quicker. Some car parks mandate it.
Nov 30, 2018 18:17:53 GMT
Start making it a habit to reverse in to parking spaces, rather than out. Occasional awkwardness getting stuff into the back of the Land-Rover is a small price to pay for being able to see when I leave. Same with th capri - reversing out is horrible...I reverse into spaces with most stuff. Having now been a biker for a year I realise that you have to think about your exit strategy beforehand!
vulgalour
Nov 30, 2018 20:37:47 GMT
How are you finding spaces you can reverse into? Whenever I've tried someone appears out of nowhere and sits too close to the back of me for me to get into the space I'm trying to reverse into! Had good luck today, got 2 drive-through spots and a parallel park at the end of a row instead of having to shuffle between parked cars. Of course, that sort of luck can't last.
A couple of minor issues today. The first was that on doing a lights check, the hazard telltale has decided to stop working, even though the hazards themselves function perfectly normally. Shall have to give the bulb/wiring a wiggle and see whether or not the bulb has blown. At least it's the easy bulb to get to.
The second was that for some distance I was driving with my reversing light on without realising it. The new switch was not provided with a locking ring and I'd lost the old switch so couldn't swap it over. As a result, the new switch has self-adjusted into a position where it's permanently on. Since it's dark and very wet, Mike and I decided to unplug the bulb and sort it out tomorrow, especially since I've since found the old switch so I have the ring to swap over and stop this happening again.
Headlight aim is too low. I had set them at home on the drive but forgot to account for the slight incline of the drive. An easy enough job to raise them up a bit now that I actually have working adjusters.
So realistically, everything is fine
melle
South West
It'll come out in the wash.
Nov 30, 2018 21:01:07 GMT
How are you finding spaces you can reverse into? If you can reverse out of a space it must be possible to reverse into it as well I'd think?
Nov 30, 2018 23:18:05 GMT
I almost always reverse into parking spaces, even when parallel parking. So much easier even when driving my van which has no rear windows, I just use the door mirrors.
joeytalent
ITB Everything.
All my friends in the US are horrified when I reverse into spots; I personally find it much easier. Even in the Datsun with no PAS and only one mirror... Best of luck with your experiment, hope it works out
vulgalour
I can reverse into a parking bay, you know, I just tend to end up with people appearing and sabotaging my attempts. The other issue is that many of the bays are simply too narrow and too short to get your shopping down the side of the car and into the boot, so driving in is preferable.
It's almost like car parks are designed to maximise the number of bays rather than the practicality of getting things in and out of your car.
Parallel parking, which I don't have to do that often, is always done best by reversing in first, on that I will agree. Reference points for turning in are much easier to find and I've had the car long enough that I've a good 'feel' for where the corners are, much to my housemate's confusion. Mind you, he's the sort of person who finds reverse-parking so difficult he'd have parking sensors fitted to a Peel Trident.
vulgalour
Hazard telltale - now fixed. Pulled the bulb, tweaked the tines out, plugging the bulb back in and it now works normally. It's either the bulb or holder that's a bad fit, or both, this seems to have fixed it.
Auxilliary belt - squealing. I thought it was because of the wet weather until I checked and it's gone a little slack. I'll tighten it tomorrow when I can see what I'm doing, it's probably stretched a little.
If it ever stops raining I'll get the reverse switch and headlight alignment sorted.
Last fuel up after about 150 miles of all urban driving is just shy of 22mpg. Not great, not terrible, just normal for what it is.
vulgalour
- Auxilliary belt. Retensioned using a couple of 13mm spanners. Charging improved and screechy belt noise gone, predictably. - Headlights aim. Improved by adjusting the aim higher. I'm not entirely happy with where the headlights are pointing so I will get a local garage to set them properly for me in the MoT bay rather than make a best guess. - Reverse light switch. Reinstalled the old switch. Reason being, the new switch has collapsed internally (broken spring?) which is the actual reason the reverse light wouldn't turn off. The old switch actually works perfectly fine, the problem wasn't with it, the problem was with the broken wire which we have resolved. The new switch managed to last all of about 30 miles, which is frankly rubbish.
Mr V, What's the actual dimensions of your wheels and tyres? I'm going to replace the debica nevergrips
Been there with poor quality brass reverse switches. Had one fall apart just removing it from its box. COI china. Just like narrow parking spaces for ncp infact...
Last Edit: Dec 3, 2018 9:35:46 GMT by darrenh
