rattling on with stead progress, nice it makes my skin itch just seeing pictures of people who use grinders without the guard on (not saying yours doesnt, just in general)
vulgalour
Club RR Member Number: 146
I'll be honest, the grinder I'm using doesn't have a guard on it. Trouble is, when you fit the guard you can barely get any use out of the disc before it's in the way and it really hampers using a flapwheel, particularly in tight areas. I compensate for that by wearing enough protective gear that I've been mocked for it - usually leather jacket, gauntlets, eye protection, bandana, ear defenders, work trousers and boots - and being very cautious about how I cut. I never force the grinder to do a cut, I let the disc do the work for me and really avoid digging into anything where there's going to be lots of surfaces meeting at the same time on different parts of the disc.
I'm wondering if in this instance it was a minor disc defect since the cut I was making was, for once, on a piece with really good access and it was just a straight cut but something made the disc grab and jump. Looking at the piece I was working on and the disc I can't see what would have caused it, perhaps I had a momentary lapse of focus, I have been burning the candle at both ends lately.
ftz313
I've used like this for years. When cutting or grinding if holding in your right hand then the contact should be between 5-7 o'clock. Anything else it'll snatch out your hand. I always work with my finger on the off button.
vulgalour
I'm pretty much the same with it, grinder was off as quickly as reflexes allowed, the placement of the slidey button on the side might be annoying for accidentally turning it off in use but brilliant for killing it in a hurry. I bet I'd turned it just a bit too far without realising as I was working along and that's what made it snatch now you've mentioned the 5-7 position
melle
South West
It'll come out in the wash.
Trouble is, when you fit the guard you can barely get any use out of the disc before it's in the way and it really hampers using a flapwheel, particularly in tight areas. If you feel bad for not using a guard, you could try and adjust it? I mostly use ø125mm/ 1mm cutting discs, always have guards on my grinders and I wear the discs down right to the spindle. No issues with grinding or flap discs either.
vulgalour
I don't know how you do it then because I find the guard is almost always in the way of what I'm working on. Thinking about it, I don't even know if this grinder has a guard, it's not actually mine.
To Do list is considerably shorter than it was. Here's an update on that.
Bodywork - bulkhead mounting point for heater to repair - rear boot floor seam to clean and repair as necessary Driver's side - fit front outer wing - repair/replace front floor pan - front subframe mount on heelboard to investigate and repair if required. - small inner sill repairs to complete - sill closing panel to buy and attach - rear lower outer wing/arch area to replace - boot floor to inner wing section to repair Passenger side - repair outer sill under door - sill closing panel to buy and attach
Mechanical and Electrical - identify cause of inoperable horn and driver's side indicators. Potentially earth problem and/or dirty connections - obtain and fit correct battery, current one much too large - acquire and fit battery clamp (may have a Princess one in stock that suits) - acquire and fit new tyres - flush and replace coolant - bleed brakes
Cosmetic - repair and retrim door cards - repair and retrim parcel shelf - acquire and fit new carpetting - apply paint where required
Guards spin round in grinder to allow access at whatever angle you need. Personally I would never use a grinder without a guard.
Rich
Club RR Member Number: 160
Guards spin round in grinder to allow access at whatever angle you need. Personally I would never use a grinder without a guard. Likewise. I foolishly used a guard less grinder with a flap wheel, I thought 'it's only for a second' while I fettled some anti-Luce fasteners to fit right and now I have a funny little dent in the end of my thumb where more skin aught to be. Don't do it, kids.
ive found very little times when i had to remove the guard, madness using a cutting disc without one
vulgalour
Bad Vulgalour, no biscuit. Gotcha. (seriously though, safety is important, listen to those people^) --- After what was achieved today I've decided to have a weekend off from the Austin. I've been working flat out to get through as much of the front end as I could in the shortest time and now that's all done I have the luxury of time on my side. The remaining welding can be done at a more sedate pace since none of it will need me to disturb the bits that make the car run, with the exception of disconnecting the battery when welding, of course. The various earth points and wiring stuff was tidied up in the engine bay so, apart from potentially cleaning any less-than-perfect earth points, we're done under here. 20170804-01 by Angyl Roper, on Flickr More importantly, the wing is fitted. It's a scruffy used panel so it's less than perfect but it's far better than what was there before and was free, so it makes sense to use it. I'm very happy with that, all told. The headlight was reinstalled along with the sidelight unit with clear lens and the grille was refitted. I need to get a couple of bulbs for the sidelight-indicator unit so it matches the other side and we can check all the lights work. 20170804-02 by Angyl Roper, on Flickr 20170804-03 by Angyl Roper, on Flickr 20170804-04 by Angyl Roper, on Flickr There's very little to go through now, the boot is mostly empty. Acquired a scrap of funky old carpet that might get repurposed in the car as heel mats or something. 20170804-05 by Angyl Roper, on Flickr I feel pretty happy about the progress over the last couple of weeks. It's a relatively solid little car now in need of just a bit of sill and floor attention. Big thanks to Mike for helping out so much by doing those little jobs and some not-so-little jobs that might have otherwise slowed down the progress. It definitely helped get over the scary hump of work the front end needed.
If you feel bad for not using a guard, you could try and adjust it? I mostly use ø125mm/ 1mm cutting discs, always have guards on my grinders and I wear the discs down right to the spindle. No issues with grinding or flap discs either. same, had my grinder for nearly 10 years and only taken the guard off once. it saved my bacon one time when a 1mm disk snagged in a floor pan and shattered. i also find it quite useful to "funnel" the grinding dust/ spray. hard to explain but the fiery dust exits the grinder in a certain direction dependant on how you "clock" the guard. when you want it on the floor rather than melting your 40 quid dickies work trousers, its quite helpful
Last Edit: Aug 4, 2017 19:02:10 GMT by darrenh
melle
South West
when you want it on the floor rather than melting your 40 quid dickies work trousers, its quite helpful Pfff, fashion victim. What you need is not a guard, but proper work trousers.
vulgalour
Been considering splitting this thread into individual ones for each car rather than this big lumbering thing for all three. What's the preference of the readership?
Me? I like it as it is.
But then I enjoy threads that skip around a bit. I never know what's coming next. Besides, that's how mine seem to turn out.
If you split them I may think, "Oh I'll bookmark the Princess and 1100, but not the Rover." Then I'd have missed the whole red/white/gold thing. And that would have been a shame.
It's the whole journey that does it for me.
Feel free to ignore this completely though! 😊
melle
South West
Yeah, keep it as it is.
Me? I like it as it is. But then I enjoy threads that skip around a bit. I never know what's coming next. Besides, that's how mine seem to turn out. If you split them I may think, "Oh I'll bookmark the Princess and 1100, but not the Rover." Then I'd have missed the whole red/white/gold thing. And that would have been a shame. It's the whole journey that does it for me. Feel free to ignore this completely though! 😊 What he said.
personally i don't really like mashup "my garage" type threads, they are confusing to read and unnecessarily busy / watered down. as a resource for the author and for readers the information gets lost too (for example i had to check some of my threads loads of times to remember what i did !, if i had all 4 cars in one thread it would be a nightmare, 4 times the content, 4 times chit chat inbetween mixed updates)
i do agree with george though that you get exposed to stuff you wouldnt normally want to read about (this is far from a dig, but one example is the rover 200) i would not bookmark a rover 200 thread, but i've read all about yours.
the "1993 Litton Corse I - Strato's Replica & Ginetta G15,G21,G27" thread is an example that sprigns to mind, i have it bookmarked but i don't know the difference between a stratos replica chassis and a ginetta G21 chassis, so when an update comes up and its a close up of some deft mig welding on a chassis tube i'm not really sure what i am reading about.
Last Edit: Aug 5, 2017 15:30:41 GMT by darrenh
vulgalour
darrenh: That's pretty much my thoughts behind considering the split. If I do split the thread - and I'll only do that if feedback is in favour of it - then the Princess will stay here and the Rover and Austin will jump off into their own threads. Rover - least popular. It's still seen as rather boring and conservative in the styling and performance department which is a bit strange because it sticks out like a sore thumb in the real world. A bigger engine, a turbo and Honda badges might change that but we're not going down that route. It's just my daily driver and proof you can have a cheap old car that's easy to get on with. I doubt a thread on this car would get much attention outside of the owner's club, perhaps in another 10 years or so it would, when there's hardly any left. Princess - This car is basically me, most people I've met from forums have been because of this car. I'm surprised at the following it has, though perhaps I shouldn't be, it's been a very visible part of my online presence for five years. It's also the most modified and perhaps the most technically interesting of the three with its own unique set of problems and solutions. With interest and values on the rise with them I've noticed the sort of interest it gets is slightly different with a few more of the "you've ruined that" types popping up now that people have started paying a couple of grand for really nice original cars. This one will stay afloat in its own thread, she's got fans. Austin - The newbie. Possibly the most popular too, going off the feedback over the last few weeks. I'm not really sure why, it's the most horrible of the three cars I've got, and likely the slowest and definitely the least modified. The response has been overwhelmingly positive and it's not all nostalgia driven, even people too young to remember them being on the road like it. Some of this is because people want to know if it's a "big Mini", which I suppose it is. This would probably also stay afloat in its own thread if I did the split. The biggest concern with splitting the thread is having one of them sink without a trace. Comments, chat and likes all help with motivation when the cars are being irksome and of course being able to share pictures to highlight a problem or a solution can be really beneficial to all concerned. One thing I would like to do is occasional video posts. I have no idea how to do this, or what equipment and software I need to make something entertaining and informative. I'd also have to get over being video shy, that's why on the short clips I have posted you don't really ever hear me talk.
melle
South West
To be honest, I find none of your cars as such very interesting, but I like following along your adventures with them. I think most of the threads I follow on this forum are about cars I would never want to own myself. "Chance encounters" with different cars and their owners are what differentiates this forum from brand specific forums and make it worth sticking around here.
vulgalour
You've got SAAB V4s, your perception of 'interesting' is going to be just a little different to everyone else .
