I'm on my own today so I'm a little limited on what I can actually achieve. Plenty of time before work, Saturday is always a very late start and finish, which is good for tinkering. It was also fortunate that the parts that would enable tinkering arrived today, we could finally complete the ignition leads and see if we could get to the bottom of the car's running issue.
The Lanchester is running modern 'bullet' type spark plugs with the old 'acorn' style distributor cap. I ordered parts to make leads to fit both of these things since the plugs look fairly new and the cap is in excellent condition, there's no real cost saving replacing the cap to accomodate more modern leads and I've always wanted to have a go at making my own ignition leads so this seemed an ideal opportunity. The acorn type fitting is new to me, 'acorn' referring to the screw fitting that goes into the distributor cap. You trim back the sheath of the wire, feed a little brass disc onto the wires and then fan them out as evenly as you can to provide your connection. The screw fitting keeps everything very secure and while it's a little fiddly, it's quite pleasing to do. At the spark plug end, I opted for screw on caps rather than crimp on ones, I liked the look of these and it meant I could avoid crimps, which I don't really enjoy doing. As it turns out, it's quite easy to install these and in a matter of minutes I had a nice new set of matching leads.
The distributor cap was in surprisingly good condition, I don't think it's a new item as there's some signs of wear. Likewise the rotor arm and points, neither of which look like they're in need of anything at all.
The leads are on the long side, I guessed at the lengths since what was fitted before wasn't really a good template. Once I know everything is good and working I will shorten the leads accordingly, because of the acorn fittings that's actually really easy to do. The red actually turned out to be a good choice, it's much easier to see what you're doing because of the contrast they provide. Unfortunately I'd made one mistake which is I bought what I thought was a straight coil connector to match the plug elbow connectors, what I'd actually bought was a straight plug connector, so it doesn't fit the coil. No bother, I stole the king lead from the Princess which actually fit the acorn cap surprisingly well and allowed me to test the new leads.
The good news is the car cranks so much more willingly now. Unfortunately, it didn't want to play ball and the starter motor just eventually gave up and wouldn't do anything. I can't use the hand crank because, as spotted by a reader, it looks like the front engine mount is worn out because the pulley sits low, which makes it pretty much impossible to line up the crank handle. Never mind, an attempt was made and I've learned these new wires are a significant improvement over the old. Part of the reason the old wires weren't working was them having the wrong connectors at the distributor cap end, another was that one of the connectors had broken apart, and another issue was that they tried to plug one of the leads into an acorn fitting that was still in the distributor, the barest bit of old lead wire sticking out was just about making a connection. Really, it's a miracle the car ran at all.
I was going to order a new coil cap for the lead I'd done incorrectly when I had a brainwave and realised I could just salvage a crimp fitting and boot from one of the old leads, which is exactly what I did. Following the way the old lead was put together, I stripped back the lead sheath and folded the wire back so it made a good connection with the crimp, and then crimped it. The lead and boot fits the coil very snugly and should, I hope, be a good solution.
I do suspect the starter motor's issue could be down to the old wiring. We've had a few things like the lights that were working now not, and the wipers have stopped working too, which leads me to believe there's some very poor connections around the car. At least we have heard it running so we know that it does, it's just a little frustrating not to have it running again so we can carry on with the tidy up and problem solving. Speaking of the wipers, the new blades arrived, I've never fitted this type of wiper before so I just did what looked correct. They're quite wibbly-wobbly, seemingly by design, and the new blades come with a protective film you have to peel off before fitting. The blades rely entirely on a little rubber peg that you push through a hole to keep them held in the arms. It's not a fantastic design, I can see why more cars use the bayonet type.
I had hoped to test the wipers, unfortunately they're now not working which is likely down to a poor electrical connection somewhere. However, the washer jets are entirely manual, so I wanted to see if I could get those going. The washer bottle slides into a bracket screwed to the bulkhead, it was sitting a bit loose so I knew the bracket was sprained, I've seen that on newer cars. Removed the bottle, straightened the bracket, and then saw some old yellow glue that looked like it had been used to pack out the back of the bottle to fit the sprained bracket. My assumption was incorrect, the old yellow glue on one side was hiding a massive crack where someone has used too much forst on the bottle. This can probably be repaired with some care, though a new bottle would be better.
There's a little hand pump on the dash for the washers, a few pumps to prime the line and then all at once the button went quite firm and four perfectly aimed jets of clean water hit the screen. I was honestly expecting them to be blocked, or to fire out sludge, or to leak. Nothing of the sort, they just work and work exceptionally well, certainly no need for an electric upgrade. I'd love to show you the wipers in action, but sadly until we get to the bottom of the wiring I can't do that.
They're only small steps forward, but steps forward nonetheless.
There's a couple of items to add and a couple to remove from the list now, so here we go:
Service and Mechanical
Change oil and filter
Flush and replace coolant
Rebuild carburettor
Full set of tyres and inner tubes
Adjust brakes
Acquire/repair washer bottle
Acquire front engine mount
Acquire grease gun and grease
Repair/replace exhaust
Tool roll (original if possible, equivalent if not)
Electrical
Inspect dynamo
Inspect starter motor
Replace wiring loom - ordered new
Acquire battery clamp
Indicator/sidelight combination LED bulbs for front (hidden item)
Indicator/high level brake light combination LED for rear (hidden item)
Replace bulbs where necessary
Inspect wiper motor
Cosmetic
Door handle gaskets
Boot seal
Pedal rubber seals
Stud/bolt for bonnet release/mascot
Bolt for rocker cover to air cleaner
Fixings for bonnet side panels
Rear view mirror
Window winder escutcheon (driver's side front door)
Carpet set
Clean out and underseal all arches
Clean engine bay
Polish and wax bodywork to preserve
Repair seat leather
Revarnish interior wood
Re-scumble instrument cluster
After I'd had a bit of a read and a think about various issues that it might be I decided, on the off chance, to have another go at starting the car. A neighbour then appeared and we got (socially distanced, almost shouting) chatting, he's into Jags and such, seemed a nice sort, knew his stuff. Time rather got away with us and by the time I'd left the ignition on for about 20 minutes. Nothing ventured, nothing gained, I pulled the starter knob and the car... started. It idled, it responded well to throttle. I was caught so off guard I went to grab my camera quickly and realised I'd left it in the house, automatically turned off the car before going to grab it. When I came back and tried to start the car it wasn't having it at all and I suspect it's the old wiring just being worn out so it's causing some odd issues, like the wipers not working, or the dash lights going off and coming back on. That said, I'm delighted at how well the car started, idled, and ran with the new plugs. It wasn't dropping a cylinder or more any more and it was happy to chug away on whatever it is in the fuel tank so I feel fairly confident that the problem isn't a mechanical one. Some fresh fuel and the new wiring loom should see things up and running properly.
