vulgalour
Club RR Member Number: 146
Aug 15, 2020 20:25:02 GMT
More trivia: The Briggs bodied LD10 like Jim's have opening windscreens, while the Barker bodied cars like mine don't.
Whoever did the washer jet install did a nice job of it, looks like it's always been there (new looking bottle aside) so I never thought to question it.
v8jim
Aug 15, 2020 20:33:40 GMT
More trivia: The Briggs bodied LD10 like Jim's have opening windscreens, while the Barker bodied cars like mine don't. Whoever did the washer jet install did a nice job of it, looks like it's always been there (new looking bottle aside) so I never thought to question it. Oh that’s interesting I wander why they did away with the opening screen. Another piece of trivia, mine has a steel dashboard not wood
Max sig pic size: 80px
melle
South West
It'll come out in the wash.
Aug 15, 2020 21:16:44 GMT
You don't need any of the manky wiring harness to run the engine. Just make sure there is power at the starter and the coil and the block is earthed, and you can start it by connecting the terminals on the starter with a screwdriver. If you're bored you can also build a posh remote starter, this is one I made:
vulgalour
Aug 16, 2020 11:13:32 GMT
Surprising stroke of luck with the washer bottle, turns out it's Unipart GWW906, as fitted to Minis and Minors. Ordered a NOS one for a tenner.
vulgalour
Aug 16, 2020 18:15:53 GMT
Today I had some help so we determined to try and get a few things done on the Lanchester. First up was trying to find something lying about that would quieten the exhaust down where the flexi has snapped. Looking underneath the car the exhaust is a patchwork of pipes and silencers, the whole thing needs to be redone properly. We had set aside some tin cans to put around the exhaust and found they were actually much too big. A silicone hose joiner, however, was a close enough diameter to at least reduce the noise if not seal the exhaust properly. This is a temporary addition just until we've dealt with more important items and is just to reduce the noise output a bit. We had suspected there was a problem with electrical connectors and started going through what was easy to get to in the engine bay, cleaning up whatever we could reach. Another attempt was made to start the car and it was then we noticed a couple of sparks and whiffs of smoke from the battery area. Turns out, there's too many leads back there and the original braided earth strap was sparking and shorting against the battery box. We also learned that the newer lead a previous owner had fitted had chafed through the protective sheath, had previously been repaired with electrical tape and chafed through again. After a considerable amount of time we eventually removed the new red strap from the chassis, the nut and bolt holding it to the chassis well and truly stuck together and no access for power tools. Then a thunderstorm arrived. This demonstrated quite rapidly that the water that had appeared around the passenger side A-pillar when I washed the car was actually from the windscreen seal which is leaking quite badly. To mitigate this I improvised with some rubber car mats at least until we could push the car back in the garage. The storm didn't last long, thankfully, and the mats did a reasonable job. After that, we fitted a better positive earth strap and re-routed the negative cable following the path that matched the p-clip on the cable and shape of the cable itself. The old braided earth strap clamp broke so we trimmed that back as far as we could to the bolt that held it to the body mount. We didn't want to risk trying to undo the body mount bolt and since everything is nice and secure it seemed wiser to trim the old earth strap back than to potentially shear the body mounting bolt and creating more work for ourselves. We plan to fit new, appropriate length battery cables rather than relying on what's there now. That done, we also topped up the fluid flywheel. I'd previously thought the engine had dropped too far for the starting handle to locate in the pulley, it turns out I'd missed that there was a second bracket with a hole to guide the handle through behind the number plate and was simply putting the handle in the wrong place. Turning the crank brought the flywheel fill plug into line with the viewing window inside the car and we could top it up. Well, I say top it up, it must have been empty for how much oil we had to put in and nothing came out underneath the car. Since we didn't have a syringe type filler, we improvised with a funnel and a spout and using two pairs of hands we could fill the flywheel. We were optimistic we'd be able to run the car today after all this, which had taken far longer to acheive than seems reasonable due to the difficult bolt for the old red positive battery lead. A video was taken, though I apologise in advance for the poor recording, my camera is very old now and not great. We now have a car that's incredibly willing to crank, producing a good spark, delivering fuel, and coming very close to actually starting. The biggest problem was that while the car would almost run, even with some new fuel, we couldn't quite get it to idle and, after a while, we flattened the battery since we've barely been able to put any charge back in it while we've been trying to get the Lanchester going. Our main suspicion now has turned to the carburettor which likely needs a good clean out and rebuild. Since the car is so willing to crank, providing a good spark, and delivering plenty of fuel to the carburettor, it seems sensible that the carburettor is the bottleneck in the system and preventing the car from running. Rebuild kits are available for the Zenith 30 VIG-3 that the Lanchester uses and we have an ultrasonic cleaner which will help get the carburettor as clean as possible.
Aug 16, 2020 18:37:49 GMT
Test it by just pouring a little fuel down the carb while cranking. If it then runs for a few seconds it confirms the carb is not working........or sell it to me
vulgalour
Aug 16, 2020 18:42:57 GMT
Fresh fuel in the carb does indeed improve matters, which is another reason we suspect it's a bit gummed up and in need of a rebuild.
Aug 16, 2020 19:00:49 GMT
Test it by just pouring a little fuel down the carb while cranking. If it then runs for a few seconds it confirms the carb is not working........or sell it to me Your really up for this lanchester ownership thing aren't you 😂
vulgalour
Aug 16, 2020 19:27:22 GMT
One carb service kit ordered now too. Burlen have all the relevant bits needed at good prices and having used them before I trust their quality. It is very strange being able to just go online and order what I need without having to hunt for days for the correct part.
I think we have to find BPR a Lanchester of his own (not mine) so that he can be happy.
Aug 16, 2020 19:27:54 GMT
Great progress, so *very* close.
I'm guessing you have checked the pump is getting fuel up to the carb? Try using your hand to strangle the carb inlet when cranking, it sometimes sucks fuel and clears blockages. Is there an easy way to get the top off the carb - bowl should be full but I often find stuck fuel inlet valves?
melle
South West
Aug 16, 2020 19:33:52 GMT
Brake cleaner usually works well to encourage starting.
Aug 16, 2020 19:34:05 GMT
I think we have to find BPR a Lanchester of his own (not mine) so that he can be happy. How about a woody?
vulgalour
Aug 16, 2020 19:39:12 GMT
Pump is working great at getting fuel up to the carb and I've tried using my hand on the inlet while cranking to moderate success. All out of brake cleaner, easystart, and similar substitutes. It's kind of adorable when we're working on the car because the local old men appear to see if they can help and have all been cheering us on and trying to figure out just exactly what combination of little problems is keeping it from running. We've got a married couple at the bottom of the street who are both really keen on seeing the Lanchester running and delighted that us "young people" (we're both pushing forty now) are into the old cars.
If nothing else, owning the Lanchester has been making us more friends than enemies so its worth owning just for that!
Aug 16, 2020 19:47:21 GMT
I actually want Jims one as it's all steel, easier to modify than the ally body.
Aug 16, 2020 19:52:53 GMT
Pump is working great at getting fuel up to the carb and I've tried using my hand on the inlet while cranking to moderate success. All out of brake cleaner, easystart, and similar substitutes. It's kind of adorable when we're working on the car because the local old men appear to see if they can help and have all been cheering us on and trying to figure out just exactly what combination of little problems is keeping it from running. We've got a married couple at the bottom of the street who are both really keen on seeing the Lanchester running and delighted that us "young people" (we're both pushing forty now) are into the old cars. If nothing else, owning the Lanchester has been making us more friends than enemies so its worth owning just for that! When i started building my MGB V8, i had a garage a few km away without power so most of the work was done outside in front of the house. It was a kind of anonymous neighbourhood where people did not know their neighbours. During working on the MG i got to know most of the people who came to have a look or a chat.
A nice car you have. Its a really classic car and it looks like its in fair condition and good priced. You also are good in doing these threads with good pics and text!
Peter
Aug 16, 2020 19:57:29 GMT
The mats look a bit like a sun visor. Looks like it would really suit one. I wonder if a minor one would fit?
Aug 16, 2020 22:33:33 GMT
If I go down to the barn today what am I likely to find (actually it was Friday) 4 new 16" tyres that should fit a Lanchester that's what I'll find I will get them taken off the rims tomorrow And samta22 is visiting me on Wednesday so that's a lump of the logistics sorted for getting them back to you
Last Edit: Aug 16, 2020 22:34:28 GMT by Deleted
vulgalour
Aug 16, 2020 22:48:29 GMT
Excellent. Simply excellent. You're a gent, Grumpy.
melle
South West
Aug 17, 2020 10:31:19 GMT
@grumpynorthener , what width and offset are those wheels, and are they easy to come by? 16" would look good on my Saab 95, which I plan to lift a little. If the offset is way off I can correct that.
Aug 17, 2020 12:20:16 GMT
@grumpynorthener , what width and offset are those wheels, and are they easy to come by? 16" would look good on my Saab 95, which I plan to lift a little. If the offset is way off I can correct that. - I just had the tyres taken off those rims so I will go and have a measure for you - the Jupiter rims with the drilled holes are pretty scarce - however the Javelin has the the same rim but without the holes - I have gone to the extent to make a Jupiter rim from a Javelin rim by drilling the holes myself before today - tedious but effective - good news is Javelin rims are in a plentiful & cheap supply and I could readily acquire you a set through the club spares scheme - back with some measurements later - pic in the interim
Last Edit: Aug 17, 2020 12:22:18 GMT by Deleted
