Gem
East Midlands
Sept 17, 2014 21:30:41 GMT
Swapped my golf for this and so far really liking it, it's not a bmw I know but it's good on fuel. It's a 1.9 D Turbo. Stuff I've done:Smoked indicators Phase 3 headlights Plans:Lows (obviously) Private plate Respray Wheels Not doing anything engine wise yet. Treated it to smoked indicators so swapped them over [emoji14] Few sceney pics Phase 3 lights turned up today, fitted my players sticker and it's booked into Constella for lows on Friday, got 60mm springs for the front And that's it so far..
Sept 17, 2014 21:39:48 GMT
Ace.... Remember a time when everyone wanted one of these ! Will look ace with the added lows
I'm not curse word, i just fell off my shoes
Gem
East Midlands
Sept 17, 2014 22:27:35 GMT
Hopefully, chose the new colour today so that will be in process soon
djefk
Sept 17, 2014 23:56:14 GMT
Agree, these are great cars and are starting to become rarer, I think snobbery is the real thing not welcome here thank you.
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
Sept 18, 2014 7:16:14 GMT
Back to the car, looks really tidy mate. Good ones are hard to find, especially in 3 door D-Turbo spec, and with a straight rear beam which yours looks to have. Fit a boost gauge, increase the max fuel until you have some black smoke and then adjust the wastegate. Even 18-19psi will make a huge difference to power and driveability, you can go further but you run into issues with heat soak, head gasket failure and turbo death without other mods. I've had 5 of these and usually 19psi will give you about 115bhp and improve fuel economy.
Have a look on 306oc.co.uk, loads of info on tuning and modifying there, and you won't get as many negative pissy comments from the lords of retro.
Last Edit: Sept 18, 2014 10:01:42 GMT by HoTWire
Gem
East Midlands
Sept 18, 2014 9:57:40 GMT
Wow, in all the time I've been on here and considering all my other cars have been retro, didn't see a problem, I was asked to put up a build thread so if you don't like it, don't read it.. The_Liam cheers dude, I'm already on there, not touching the engine for a while as only had it a few weeks but black smoke is on the list
Sept 18, 2014 10:04:25 GMT
Deleted some posts in here... the usual rules apply if you don't like it, don't post. I notice also those that posted negativity in here have hardly posted anything on all the other cars in this section, which says a lot about their hateful attitude towards other car enthusiasts. Hope it turns out nice Gem, your previous cars have been cool
THE_Liam
Sept 18, 2014 11:24:59 GMT
Wow, in all the time I've been on here and considering all my other cars have been retro, didn't see a problem, I was asked to put up a build thread so if you don't like it, don't read it.. The_Liam cheers dude, I'm already on there, not touching the engine for a while as only had it a few weeks but black smoke is on the list Oh sweet, who are you on there? Surprisingly, my username is the same everywhere.
Sept 18, 2014 12:50:22 GMT
Nice, I had a green HDi DTurbo a few years back, it flew when it reached 175bhp. No smoke, no poke.
Sept 18, 2014 13:11:21 GMT
I had a very early phase 2 gold (blaze 'yellow') ... Best car I have ever had, did nearly 60k in 3 years in it, (until a drink driver crashed into the side of it, writing it off!) Brilliant cars, yours is exactly the same as mine was (except the colour) with the phase two, little upgrades I found make all the difference, silver centre consol, changing the speedo surround and needles for the sliver, makes it look so much more modern inside, Keep the pictures and updates coming!
Sept 18, 2014 13:27:14 GMT
I to had one of these when young.
Deleted the back box with a straight pipe. Popped a cone filter on with a cold air feed ( the standard snorkel likes to suck up water ) and uped the boost.
Fitted some 307 front breaks. They bolt straight on and are so much better.
Gem
East Midlands
Sept 18, 2014 18:32:45 GMT
Thanks guys, working on a budget so it's a case of as and when. Fitting the lights tomorrow hopefully Oh sweet, who are you on there? Surprisingly, my username is the same everywhere. xGem, not been on there long
Gem
East Midlands
Sept 19, 2014 9:13:52 GMT
Getting some lows
JohnK
North East
Sept 19, 2014 10:00:01 GMT
I always wanted one of these when I was younger, but it was a car I never bought. Looks a clean example, looking forward to seeing how this progresses.
------------------------------------------- 1999 'V' Rover 620Ti 1999 'T' Mercedes E55 AMG 1997 'R' Ford Probe 24v 1994 'M' Nissan Maxima 3.0 1992 'J' Honda Prelude 2.0iS 1986 'C' BMW 728i Auto 1985 'C' Talbot Solara 1.6 Minx 1984 'A' Talbot Horizon LE Ultra 1.3 1978 'S' Ford Cortina 1.6 GL
THE_Liam
Sept 19, 2014 13:05:36 GMT
Getting some lows God I hate that job, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch...
Sept 19, 2014 17:55:35 GMT
Getting some lows God I hate that job, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch, slide hammer, blow torch, slide hammer, blowtorch... nut abs spacer is a bit more time consuming but causes less damage to the bearings But as Liam says a load of good advice on 306oc and some mad derv builds
Gem
East Midlands
Sept 20, 2014 17:33:35 GMT
Didn't get lows, everything was seized and ran out of time, bought a new rear axle and having it delivered straight to the garage so he can have a play, so not lowered for players annoyingly
Sept 20, 2014 17:36:18 GMT
It's not uncommon for them to be seized. Though it all depends how the garage set about lowering it , just have to hope that the new beam is in an easier to dismantle state.
Sept 20, 2014 18:00:40 GMT
not yet had one I haven't been able to take apart.
a lot easier with the beam off the car however.
Gem
East Midlands
Sept 24, 2014 8:38:37 GMT
I've decided against lowering it, ordered a new rear axle but just gonna include everything in the sale.
