Sept 16, 2014 12:39:05 GMT
Desperately need xr2i load sensing valves
My xr2i has recently failed the dreaded mot as the above load sensing valves for the brakes are leaking. Ford do t sell them and there are no patent parts can anyone help the part numbers are below. These parts sit on the rear beam and apparently allow more braking pressure to the rear if there's more weight.
6181557
6181561
Kieran
Sept 16, 2014 12:41:04 GMT
Remove them from the circuit?
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Sept 16, 2014 12:53:21 GMT
I'm beginning to think that how would you reccomend doing it ?
bortaf
Sept 16, 2014 20:23:17 GMT
Last Edit: Sept 16, 2014 20:40:42 GMT by bortaf
R.I.P photobucket
Sept 16, 2014 21:38:49 GMT
Bortaf thanks for the link that's the kind of thing but it's only one side I'm trying to get both sides but haven't had much luck yet
Sept 16, 2014 21:49:38 GMT
Sept 16, 2014 21:56:13 GMT
Transit ones also look similar mate
Sept 16, 2014 22:57:39 GMT
The be fix one is the right type but they only have one I'm starting to contemplate 2nd hand units. I think due to the 23 year old brake fluid being flushed out recently and new put in it's dislodged a load of gunk holding it together ![???](//storage.proboards.com/forum/images/smiley/huh.png) ?
Sept 17, 2014 6:17:55 GMT
lesser cars had a non ajustable reducer valve ...just like a small tube inline at one end
80-90s vw had them , some fords did too , ive got some focus ones here if you want em ?? should do the job
Last Edit: Sept 17, 2014 6:18:38 GMT by steveo3002
Sept 17, 2014 20:47:58 GMT
Just buy two for the same side and strip out the cylinder and seals to repair your original opposing side
Sept 23, 2014 16:29:11 GMT
Well tried by passing the valve , err that wasn't the wisest of moves lots of back end screeching. Going to try to clean up the valves reassemble as it's just weeping
Sept 23, 2014 19:03:41 GMT
open the bonnet of any non-ABS Rover 25/45 (or similar model of Rover) and they've got a nice compact brake pressure regulator. Same part was fitted to drum and disk models, with varying piston sizes. Two pipes in, two straight out (for the fronts) and two for the rears. Really simple to fit, and even come with a handy mounting bracket ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Sept 23, 2014 19:54:00 GMT
I had the same problem with my mk4 escort van the valve is no longer available the parts guy at ford said to use the valves they fit in line on the mk4 fiesta that screw into the brake master cylinder they have a male thread one end and a female the other end on my escort van I was able to just remove the leaking compensator and in place fit the valves same size threads brakes worked fine without locking up and past 3 mots with them fitted if you want I can try to find the part number of them if I can find my old invoice for them hope this helps.
Sept 24, 2014 4:49:19 GMT
If you could find the part number it would help I'm going to try to get the compensator refurbed but I'm not holding out much hope
Sept 24, 2014 12:09:43 GMT
ebay.to/1prXtrNTry that one matey can see the reducers on the cylinder itself in pics And well worth stripping old ones as will probably clean up fine and just need new o rings mate which are easily available cheaply
Sept 24, 2014 19:50:46 GMT
Well hopefully it works my mechanic has picked up a mk4 servo today so fingers crossd
Sept 25, 2014 8:59:09 GMT
ebay.to/1prXtrNTry that one matey can see the reducers on the cylinder itself in pics And well worth stripping old ones as will probably clean up fine and just need new o rings mate which are easily available cheaply Thanks for the advice I've got the master cylinder and presented it to my mechanic. I hardly ever work on brakes for fear of the obvious. He reckons it'll fit but new brake lines will have to be run to the rear of the car does this sound right ? He's also suggested using a brake bias valve adjuster as a solution
Sept 28, 2014 0:19:47 GMT
Corsa mk1 vans have these on the rear beam. ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Sept 29, 2014 15:44:50 GMT
I had the same problem with my mk4 escort van the valve is no longer available the parts guy at ford said to use the valves they fit in line on the mk4 fiesta that screw into the brake master cylinder they have a male thread one end and a female the other end on my escort van I was able to just remove the leaking compensator and in place fit the valves same size threads brakes worked fine without locking up and past 3 mots with them fitted if you want I can try to find the part number of them if I can find my old invoice for them hope this helps. Vtec at the risk of sounding like a dullard where do I remove them from the mk4 cylinder to attach them too
Sept 30, 2014 18:47:56 GMT
The valves are removed by unscrewing them by using a large spanner on the end of the valves there are flats for spanner to fit on at the male end if that makes sense the parts guy at for said the male end must connect to the master cylinder I fitted my ones above the rear axle and they worked fine a mate fitted a pair to his mk5 a escort but the union sizes were wrong so we made a some adapter pipes up to convert the pipe sizes they did the job if you don't have a pipe flareing tool then visit a local garage should be able to make you some adapter pipes to connect to the valves if the union sizes are wrong saves running new pipes under the car.
You could use a bias valve to adjust down the rear brake effort but you might find that it won't adjust down enough I had one on a classic mini and even fully closed on heavy breaking would still lock the rear wheels the ford valves don't seem to suffer the same issue if you need anymore advice just ask I will try to help if I can.
