May 16, 2007 11:37:17 GMT
standard style pressed steel wheel, 4.5" PCD *Four* stud, on a 15" diameter.
TR6 has a steelie which is 15" but they are fancy ventilated things.
Some J-tin pickup perhaps?
Last Edit: May 16, 2007 11:37:52 GMT by akku
May 16, 2007 12:21:11 GMT
Early Hillman Minx series? Not sure about PCD though but the early series cars had 15"s changed to 13"s later in production.
May 16, 2007 12:25:45 GMT
They are 4.25" PCD so will not do
May 16, 2007 12:58:19 GMT
Earlier TRs had 15" steels too, the works Triumph 2000 MK1 rally cars had 15 steels from a TR2 or 3 , they're 4.5 PCD
The Doctor
Club RR Member Number: 48
May 16, 2007 13:11:03 GMT
i believe Neeessan Primera had 15" steelies in 4x114,3/4,5" Have to check to be sure, but i thought a friend of mine had some.
May 16, 2007 13:17:18 GMT
aha, that might be cloer to what I'd need...
markbognor
Club RR Member Number: 56
May 16, 2007 13:20:25 GMT
Last Edit: May 16, 2007 13:21:37 GMT by markbognor
May 16, 2007 13:27:43 GMT
Perfect. Thanks!
markbognor
May 16, 2007 14:22:50 GMT
So what's the plan for these then AK?
May 16, 2007 14:33:56 GMT
Its a fine plan and if it looks like coming anywhere near fruition then I will stick up a thread in readers projects.
I have to convince SWMBO that its a good idea first
May 16, 2007 17:10:30 GMT
Indeed the primera wheels will do, I have a primera and my spare wheel is a 15x6 steel 4x4.5", I believe lesser models have them all round but not older p10 as they have 14's I believe................. Thats my 10 pence worth.
bobz
May 16, 2007 17:16:09 GMT
Saab 99,90 & 900 upto '87 (front wheel handbrake) are 15" 4 x 4.5, and look quite cool
Don't plan anything, it'll start raining!
ta. Apparently A90 Westminster does a 15" and thats 4x4.5
Pid363!
Madness is all in the mind!
May 17, 2007 10:29:26 GMT
Ive also been wondering this, ive got TR6 wheels on my Magnette but always wanted a set of plain 15" steels. Westminsters are 5 stud so they wont be any good.
Stupid is as stupid does!
sav
May 17, 2007 10:44:34 GMT
I'm pretty sure the earlier A50/55 (pre farina) Austins had 15" steels. Certainly an old van I went to see years ago had them, so probably goes for the saloon and pick up variants of the time as well.
koppak
May 17, 2007 22:56:03 GMT
Pre Farina a40/A50 s had 15s as standard, A55s had 13s and the early commercials had 15s pre 58ish then went on to 14s. Fintail A55s ran 14s to.
sav
May 17, 2007 23:18:15 GMT
Thanks koppak I had forgotten about the A40 Cambridge, and the switching to 13" wheels on the A55s.
