May 14, 2007 19:32:57 GMT
Help....
The extra weight of the 1108 engine on my Fiat 500 is causing the arches to rub on the rear tyres. Can anybody out there help me with an arch roller, I would be happy to part with a few beer tokens or can you recommend somebody to do it?. I'm in N/W london / Middlesex area.
Thanks
Nigel
markbognor
Club RR Member Number: 56
May 14, 2007 20:24:14 GMT
Slater made one to use on his metro, search for his thread in the readers rides, there's quite a good pic of it in there of it but its an epic tread to search through.
markbognor
May 14, 2007 20:53:12 GMT
Found it for ya, Quality job, right down to the pool ball handles.
B-8-D
down to one car!!
May 14, 2007 21:48:49 GMT
ive read lots about keeping the wheels/tyres on and using a wooden baseball bat! apparently one holds the bat and another pushes the car backwards and forwards pulling the handle of the bat out till its stretched!! all the pics ive seen of this looks like very good results have been achieved. ive yet to try this myself but i will let you all know when i attempt this on my rover si
tigran
In rust we trust. Amen.
Club RR Member Number: 142
May 14, 2007 22:19:39 GMT
If you're in that part of Laandan, you can do a LOT worse than speak to the nice chaps at R-Tec in St Albans/Hatfield. Their arch rolling skillzorz are renowned, and pretty cheap to boot.
ive read lots about keeping the wheels/tyres on and using a wooden baseball bat! apparently one holds the bat and another pushes the car backwards and forwards pulling the handle of the bat out till its stretched!! all the pics ive seen of this looks like very good results have been achieved. ive yet to try this myself but I will let you all know when I attempt this on my rover si I've often been tempted to take a baseball bat to the car but never thought about using one to roll the arches! I am trying to do it on the cheap and without breaking the paint, I have a set of flared arches for the car which I am going to fit in the autumn which will involve tubbing the arches properly, lower springs – shallow winged sump etc so I need a quick (and cheap) fix for the summer.
Graham
ive read lots about keeping the wheels/tyres on and using a wooden baseball bat! apparently one holds the bat and another pushes the car backwards and forwards pulling the handle of the bat out till its stretched!! all the pics ive seen of this looks like very good results have been achieved. ive yet to try this myself but I will let you all know when I attempt this on my rover si one of our members on the 100e site done it this way and swears by it he is in the states and i will see if i can find his topic and paste it on here
Maximum signature image height: 80 pixels
May 15, 2007 17:29:49 GMT
May 15, 2007 18:06:04 GMT
i cant get ma head around the baseball bat idea??
B-8-D
down to one car!!
May 15, 2007 22:43:05 GMT
if you're careful -and slow- you can do it with a small hammer from the inside while holding a soft block of wood on the outside. baseball bat is intruiging, but that might suggest you have too much gap between the tyre and arch the idea is you use the std wheels/tyres and when streatched fit the biggies.... si I know it works.. ive seen pics before/after and during.. great effects.. and somewhere when I was in the states,, said they use a baseball bat rather than a proper arch rolling tool because they get a batter roll that is more variable..!! #si
Last Edit: May 15, 2007 22:43:54 GMT by B-8-D
May 16, 2007 19:11:26 GMT
ive read lots about keeping the wheels/tyres on and using a wooden baseball bat! apparently one holds the bat and another pushes the car backwards and forwards pulling the handle of the bat out till its stretched!! all the pics ive seen of this looks like very good results have been achieved. ive yet to try this myself but I will let you all know when I attempt this on my rover si one of our members on the 100e site done it this way and swears by it he is in the states and I will see if I can find his topic and paste it on here Now thinking of giving this a try, did you manage to locate the thread from the 100e site? I figure if all goes pear shaped I can move onto plan B, tub the arches and use the fiberglass flares I have. Nigel
May 16, 2007 20:05:01 GMT
could someone maybe please explain the bat arch rolling idea to me please?
B-8-D
down to one car!!
ha ha ha..... pink car... dodgy music..... those crazy japs...
si
Quality clip! slinging the inner protectors back in could be a little issue, or maybe you just don't! worrying that he got the bar from beside the seat! crazy! also i'd squidge some wax oyl in there too.
May 17, 2007 11:02:40 GMT
Its easy. Cut a baseball bat in half-ish down its length so its got one flat surface. Jack the car up slightly. Put the baseball bat on the rearmost edge of the arch lip which is catching, with the handle sticking outside the arch. Let the jack down. Push the car forwards. Jack the car up, pull the baseball out a bit, let the jack down, roll the car forwards. Can be repeated as much as needed.
Matt
May 17, 2007 11:39:30 GMT
ahh, i thought you left the baseball bat whole so it could roll between the tyre and the wheel, hence "rolling the arches"??
May 17, 2007 11:46:32 GMT
No if it could roll it would stay in one place lol needs to grip the tyre.
Matt
Dez
Club RR Member Number: 34
May 17, 2007 13:01:04 GMT
wrong.
you don't cut the bat in half. it stays whole so it can roll between tyre and arch- infact you turn it backwards to make it roll along as you do it.
edit- ive just watched the weird J video and he shows how its done perfectly.
Last Edit: May 17, 2007 13:01:59 GMT by Dez
May 17, 2007 14:47:40 GMT
Oh lol. I did it on my old 106 worked perfectly with the bat cut in half? The full bat wouldn't fit between the tyre and arch tho.
Matt
slater
Club RR Member Number: 78
May 17, 2007 17:00:39 GMT
I did it with a bit of 1" bar when i did the fiesta. Worked on the back but the wing just flexed on the front
