Yes still for sale! I'm sorry if it seems I'm changing my mind every two minutes however I keep getting messed about!
Was running 9-10psi, unsure of bhp but estimate around 170.
The standard turbo can be upped to around 12psi with no issues. After that it just blows hot air! Larger turbos are easily sourced from many more modern Volvos.
Once you change the turbo the limit on standard internals is around 300bhp which is incredible considering the car left the factory with 135bhp!
Yours is the later model, so it should have the ludicrously strong bottom end, good for far more than 300 ponies
Would you still consider a swap?
